Transponder Inspection Not Required?
Old May 8th 08, 06:44 AM posted to rec.aviation.soaring
J a c k
Default Transponder Inspection Not Required?
Steve wrote:
This is safety equipment. If you're going to carry it, get it properly
maintained. Do you get your parachute repacked regularly? Same issue.
If it is the "same issue" as the parachute repacking requirement, then
the relevant Transponder/Altimeter FAR's are probably unrealistically
restrictive.
Jack
transponder inspection Matt Owning 10 November 5th 05 09:41 PM
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione Steve Leonard Soaring 2 September 14th 05 03:49 AM
Pre-buy Inspection Jon Kraus Owning 49 September 1st 04 12:42 PM
Pre-buy Inspection Jon Kraus Piloting 46 September 1st 04 12:42 PM
100 Hr Inspection Scott D. General Aviation 6 August 15th 04 01:03 AM
