Citabria Fuel-Flow Problem
Old May 8th 08, 12:58 PM posted to rec.aviation.owning,rec.aviation.piloting
Maxwell[_2_]
Default Citabria Fuel-Flow Problem
quietguy wrote in news:b8a07cf2-f01e-4dba-9793-
The A/C in question is a 1974 Bellanca 7ECA, re-engined with an O-320
so it's effectively a 7GCAA. It belongs to the Offutt AFB Aero Club
and has seen very little use, often sitting for weeks at a time until
a week ago when I began taking dual in it 2-3 times a week to get my
tailwheel endorsement. The fuel system is not for inverted flight, so
no header tank -- two 18-gallon wing tanks with check valves to a
single vent on the left, crossflow pipes to the aft fuel manifold
under the baggage compartment and crossflow pipes to the forward fuel
manifold on the firewall. Caps are non-vented and the gaskets are
like new.
This A/C is drawing 3-4 times as much fuel from the left tank as from
the right and it's not crossflowing on the ground, even overnight.
We've made right patterns as well as lefts -- makes no difference. We
haven't done any extended S&L flight, just 11 NM to Plattsmouth, NE
for pattern work. The club's A&P has blown out the feed and vent
lines and got a good blast into the right tank from both. We're
getting a free flow of clean gas out of all four drains.
So what's our next move? Anybody had this problem?
seen minor fed variations, but not like this. I have th emanuals out at
the hangar and access to a good AI tomorrow night, so I'll ask him. He's
rebuilt mine so he should know.
Bertie
Of coarse you can Bertie Buttlipp, cuz you know everything, you know
everyone, you've done everything.
Old May 8th 08, 06:04 PM posted to rec.aviation.owning,rec.aviation.piloting
Bertie the Bunyip[_25_]
"Maxwell" luv2^fly99@cox.^net wrote in news:1WBUj.5949$1M1.633
@newsfe23.lga:
9793-
320
until
so
fuel
like new.
from
We
at
He's
Bertie
Not everythingk just more than you, wannave boi.
BTW, you know the answer?
Didn't think so.
Bertie
Citabria Fuel-Flow Problem quietguy Piloting 45 May 24th 08 01:41 PM
Fuel Flow and Peak EGT Kobra Owning 21 May 2nd 07 02:02 AM
fuel flow on the cheap pittss1c Home Built 3 May 7th 06 10:12 PM
V8 fuel flow Robert Bates Home Built 34 January 24th 05 03:41 AM
Fuel Flow Monitoring EDR Owning 4 October 18th 03 03:10 AM
