Citabria Fuel-Flow Problem
Old May 9th 08, 05:12 PM posted to rec.aviation.owning,rec.aviation.piloting
Bertie the Bunyip[_25_]
Default Citabria Fuel-Flow Problem
"Maxwell" luv2^fly99@cox.^net wrote in
OK, talked to my guy. He had several suggestions. One is to drain it
all dry and then blow some air (carefully!) into the right tank and
see if you can hear it coming across into the left tank by listening
at the filler cap.
Possible problems he came up with were a crushed or swollen fuel line
downstream of where you tested previously, or, he thought more
likely, incorrect placement of the little plastic fuel vent deflector
and/or the location of the fuel vent itself. There are specs for the
location of these if you look in the manuals. But for the fact that
the fuel doesn't migrate when parked, I would have said this is
definitely your problem For instance, Cessnas with bent or
incorrectly positioned vents are chronically out of balance.
Bertie
Oh yeah, that's a lot of help.
I know.
Where did you find this wanna boi,
Wikipedia?
Said where i found it wannabe boi.
Aren't we the little prankster!
Bertie
Citabria Fuel-Flow Problem quietguy Piloting 45 May 24th 08 01:41 PM
Fuel Flow and Peak EGT Kobra Owning 21 May 2nd 07 02:02 AM
fuel flow on the cheap pittss1c Home Built 3 May 7th 06 10:12 PM
V8 fuel flow Robert Bates Home Built 34 January 24th 05 03:41 AM
Fuel Flow Monitoring EDR Owning 4 October 18th 03 03:10 AM
