Citabria Fuel-Flow Problem
Old May 9th 08, 08:32 PM posted to rec.aviation.owning,rec.aviation.piloting
Bertie the Bunyip[_25_]
Default Citabria Fuel-Flow Problem
"Maxwell" luv2^fly99@cox.^net wrote in
Yeah, gotta be, really. I have to say, i wouldn't consider the
airplane airworthy in this state, though.
Bertie
Yeah buddy, like ANYONE would be stupid enough to give a rat's ass
what you think.
Surprisingly, they do.
Go figure.
Bertie
"Maxwell" luv2^fly99@cox.^net wrote in news:uB1Vj.71398$y05.6116
@newsfe22.lga:
Citabria caps aren't vented.
Bertie
No, but your head is wannaboi.
I know, you're obviously isn't, though.
Bertie
Old May 9th 08, 08:56 PM posted to rec.aviation.owning,rec.aviation.piloting
Maxwell[_2_]
Bertie
what you think.
Go figure.
Bertie
Bull****. They've all got you killfiled!!!
Old May 9th 08, 10:20 PM posted to rec.aviation.owning,rec.aviation.piloting,alt.usenet.kooks
"Maxwell" luv2^fly99@cox.^net wrote in news:302Vj.71404$y05.62546
@newsfe22.lga:
Bertie
what you think.
Go figure.
Bertie
You've killfiled me?
How do you keep finding my poasts?
Bertie
Old May 10th 08, 03:21 PM posted to rec.aviation.owning,rec.aviation.piloting,alt.usenet.kooks
Maxwell[_2_]
Bertie
Your a liar. I don't killfile anyone.
Old May 10th 08, 04:15 PM posted to rec.aviation.owning,rec.aviation.piloting
Stealth Pilot[_2_]
On Fri, 9 May 2008 17:34:02 +0000 (UTC), Bertie the Bunyip
Stealth Pilot wrote in
On Wed, 7 May 2008 11:17:24 -0700 (PDT), quietguy
The A/C in question is a 1974 Bellanca 7ECA, re-engined with an O-320
so it's effectively a 7GCAA. It belongs to the Offutt AFB Aero Club
and has seen very little use, often sitting for weeks at a time until
a week ago when I began taking dual in it 2-3 times a week to get my
tailwheel endorsement. The fuel system is not for inverted flight, so
no header tank -- two 18-gallon wing tanks with check valves to a
single vent on the left, crossflow pipes to the aft fuel manifold
under the baggage compartment and crossflow pipes to the forward fuel
manifold on the firewall. Caps are non-vented and the gaskets are
like new.
This A/C is drawing 3-4 times as much fuel from the left tank as from
the right and it's not crossflowing on the ground, even overnight.
We've made right patterns as well as lefts -- makes no difference. We
haven't done any extended S&L flight, just 11 NM to Plattsmouth, NE
for pattern work. The club's A&P has blown out the feed and vent
lines and got a good blast into the right tank from both. We're
getting a free flow of clean gas out of all four drains.
So what's our next move? Anybody had this problem?
does the fuel situation change if you swap the caps to the other tank?
Bertie
that is what I was getting at bertie. looking as though they seal isnt
necessarily sealed.
if one is leaking and you swap the caps around the pattern of the
problem should change.
a cheap check
Stealth Pilot
Old May 10th 08, 04:18 PM posted to rec.aviation.owning,rec.aviation.piloting,alt.usenet.kooks
"Maxwell" luv2^fly99@cox.^net wrote in news:ObiVj.93$CE1.63
@newsfe23.lga:
Bertie
You're the one that said everyon has killfiled me.
I'm a troll, moron, I troll for k00ks.
And I got a big one.
Bertie
  #28
Old May 10th 08, 04:39 PM posted to rec.aviation.owning,rec.aviation.piloting
necessarily sealed.
a cheap check
Ah, OK. Makes sense.
Bertie
  #29
Old May 10th 08, 05:07 PM posted to rec.aviation.owning,rec.aviation.piloting
Maxwell[_2_]
"Stealth Pilot" wrote in message
m:
like new.
Bertie
necessarily sealed.
a cheap check
Stealth Pilot
You would probably find it easier to explain to MX.
  #30
Old May 10th 08, 05:36 PM posted to rec.aviation.owning,rec.aviation.piloting
"Maxwell" luv2^fly99@cox.^net wrote in news:BLjVj.72955$y05.14344
@newsfe22.lga:
320
Club
until
my
so
fuel
like new.
from
We
tank?
Bertie
isnt
necessarily sealed.
a cheap check
Stealth Pilot
Awww, he;'s giving me another lashing there.
Ouch.
Bertie
Citabria Fuel-Flow Problem quietguy Piloting 45 May 24th 08 01:41 PM
Fuel Flow and Peak EGT Kobra Owning 21 May 2nd 07 02:02 AM
fuel flow on the cheap pittss1c Home Built 3 May 7th 06 10:12 PM
V8 fuel flow Robert Bates Home Built 34 January 24th 05 03:41 AM
Fuel Flow Monitoring EDR Owning 4 October 18th 03 03:10 AM
