Ugly Glider
Old May 10th 08, 04:07 AM posted to rec.aviation.soaring
Ed Winchester
Default Ugly Glider
sisu1a wrote:
On May 9, 11:59 am, wrote:
50:1 that you'll never have? Have you looked at a Lak-12? Great
performance for CHEAP!
There's a LAK-12 on W&W for $15k. Then add how much for the refinish
job?
(sigh) I can't even afford this... should try to sell off the kids,
then I'd have more money for flying.
I've seen that Lak 12 (it's been tied out on the flight line
atTehachapi for a long time, but removed for winters) and although
it's finish is far from perfect, it doesn't look all that bad. It
probably knocks it's L/D way down to like 47 or something.
List the family on Cragslist and you can jack the price a little more
since the buyer won't have to pay shipping.
Paul
Except for the fact that it offends your sense of esthetics, I don't
think a bad finish affects performance that much. At Tom Knauff's
Soaring Symposium in State College, PA this march a noted aerodynamicist
(whose name I forget) said that laminar flow was maintained even with a
certain amount of surface roughness. He said that the limit was about
the equivalent of 40 grit sandpaper. Now there's an LS3 that you will
see on OLC out of Blairstown, NJ almost every day the ridge is working,
and he does more miles than anybody. And that glider has the worst
finish I've ever seen flying. And he kicks everybody's butt.
Buy the LAK-12 if it's performance you're after.
Ed
Old May 12th 08, 03:45 AM posted to rec.aviation.soaring
Default Ugly Glider
My biggest concern with any glider is two-fold:
1) Will I fit in? I'm 6'3 and fairly wide.
2) Will it handle my weight? I'm 250 pounds. Granted, I'm slowly
dropping my weight, aiming for 220 pounds. Still, that's the top end
of a lot of ships.
I fit nicely in a Blanik L-33 (well, a bit tight on shoulders, and 1/2
inch of headroom before I bang the canopy); and no parachute. But for
my first bird (if I can ever afford one), I'd like to have a bit
better legs for cross-country.
Old May 12th 08, 03:43 PM posted to rec.aviation.soaring
Frank Whiteley
Default Ugly Glider
On May 11, 11:01 pm, Bruce wrote:
Same physical spec fits in Std Cirrus OK...
There's a Std Cirrus coming on the market soon.
Old May 12th 08, 03:42 PM posted to rec.aviation.soaring
Frank Whiteley
Default Ugly Glider
of a lot of ships.
Depends on whether you have long legs or long torso. You'd best try
one on. Seat back may be trimmed or removed. Big feet are also
something of an issue, but the heel cups on the rudder pedals can be
removed. A BGA/LAK factory communication states adding 3kg to the
tail allows a cockpit load of 130kg.
There's a group, lak12, on yahoo groups for discussion if you're
really interested.
Ugly Airplanes, pt7 - Mi-12.jpg (1/1) Mitchell Holman Aviation Photos 2 March 8th 08 04:26 AM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
MOST UGLY GLIDER ? Malcolm Austin Soaring 75 February 24th 06 08:37 PM
Ugly Trailer Ray Lovinggood Soaring 3 December 19th 05 03:56 PM
