On May 9, 2:26*am, "Al G" wrote:
"Mike Noel" wrote in message news ![]() On AvWeb: New GA Fuel Promises Better Range, Lower Cost "Not only can our fuel seamlessly replace the aviation industry's standard petroleum fuel [100LL], it can outperform it," says John Rusek, a professor at Purdue University and co-founder of Swift Enterprises. The company recently unveiled a new general aviation fuel that it says will be less expensive, more fuel-efficient and environmentally friendlier than any on the market. Unlike other alternative fuels, Rusek said, SwiftFuel is made of synthetic hydrocarbons that are derived from biomass, and it can provide an effective range greater than 100LL, while costing about half as much to produce. "Our fuel should not be confused with first-generation biofuels like E-85 [85 percent ethanol], which don't compete well right now with petroleum," Rusek said. Patented technology can produce the 1.8 million gallons per day of fuel used by GA in the U.S. by using just 5 percent of the existing biofuel plant infrastructure, the company said. The synthetic fuel is 15 to 20 percent more fuel-efficient, has no sulfur emissions, requires no stabilizers, has a 30-degree lower freezing point than 100LL, introduces no new carbon emissions, and is lead-free, Rusek said. In addition, he said, the components of the fuel can be formulated into a replacement for jet/turbine fuels. The company now is working with the FAA to evaluate the fuel. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel * * I saw this. It sounds almost too good to be true. I am curious about the process used. Biomass? What kind of biomass? It actually makes sense for a startup company to shoot for a market that already has a high price, and is about to lose it's only source. There are 5 components all from biomass. Here is a link to the patent. http://www.wipo.int/pctdb/en/wo.jsp?...2008013922&DIS... |
On Sat, 10 May 2008 17:17:23 -0700 (PDT), terry
wrote: On May 9, 2:26*am, "Al G" wrote: "Mike Noel" wrote in message news ![]() On AvWeb: New GA Fuel Promises Better Range, Lower Cost "Not only can our fuel seamlessly replace the aviation industry's standard petroleum fuel [100LL], it can outperform it," says John Rusek, a professor at Purdue University and co-founder of Swift Enterprises. The company recently unveiled a new general aviation fuel that it says will be less expensive, more fuel-efficient and environmentally friendlier than any on the market. Unlike other alternative fuels, Rusek said, SwiftFuel is made of synthetic hydrocarbons that are derived from biomass, and it can provide an effective range greater than 100LL, while costing about half as much to produce. "Our fuel should not be confused with first-generation biofuels like E-85 [85 percent ethanol], which don't compete well right now with petroleum," Rusek said. Patented technology can produce the 1.8 million gallons per day of fuel used by GA in the U.S. by using just 5 percent of the existing biofuel plant infrastructure, the company said. The synthetic fuel is 15 to 20 percent more fuel-efficient, has no sulfur emissions, requires no stabilizers, has a 30-degree lower freezing point than 100LL, introduces no new carbon emissions, and is lead-free, Rusek said. In addition, he said, the components of the fuel can be formulated into a replacement for jet/turbine fuels. The company now is working with the FAA to evaluate the fuel. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel * * I saw this. It sounds almost too good to be true. I am curious about the process used. Biomass? What kind of biomass? It actually makes sense for a startup company to shoot for a market that already has a high price, and is about to lose it's only source. There are 5 components all from biomass. Here is a link to the patent. http://www.wipo.int/pctdb/en/wo.jsp?...2008013922&DIS... It appears to be a patent of a formulation of conventional renewable components so I'm surprised they were issued a patent. It's not what I'd call a "synthetic fuel", but rather a formulation of organic components (unless I missed something) "To Me" synthetic indicates non organic compounds used in the fuel. This I might call unconventional, but not synthetic. As to the energy component, that depends on the molecular structure of the compounds. Just as diesel fuel has a much higher energy content than gasoline I see no reason whey with the formulation of components listed they couldn't get more (or less) energy per unit volume/Gallon. OTOH whether that extra energy would actually be useful in a standard aircraft engine is something else. Roger (K8RI) ARRL Life Member N833R (World's oldest Debonair) www.rogerhalstead.com |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Owning | 0 | January 26th 04 07:48 AM |
