#171
Steve Foley writes:
The NTSB does not produce 'Special' reports on 'most pilots who kill themselves'. From NTSB/SS-05/01: Accident, Incident, and Violation History A review of the accident and incident history of study pilots indicated that 19 percent of accident pilots had an accident or incident before the study accident. In four of these cases, the event included in the study was the pilot's third recorded mishap. In contrast, figure 14 shows that a smaller proportion of pilots in the nonaccident control group were ever involved in an accident or incident. The differences in accident and incident history between groups was statistically significant, .2 (1, N = 207) = 3.99, p = .046, with a larger percentage of accident pilots having been involved in a prior occurrence. In addition to accidents and incidents, FAA records indicated that 6 of the 72 study accident pilots had civil aviation violations on their records, in contrast to only 3 of the 135 nonaccident pilots. The descriptive comparison suggests that a higher percentage of accident pilots had violation records, but because of the small numbers of all study pilots with violations, statistical analyses were not conducted for these values. |
#172
Steve Foley writes:
I have. In fact, I'll be taking the written test in a few weeks. Good luck. |
#173
"Mxsmanic" wrote in message
... Steve Foley writes: The NTSB does not produce 'Special' reports on 'most pilots who kill themselves'. From NTSB/SS-05/01: Accident, Incident, and Violation History A review of the accident and incident history of study pilots indicated that 19 percent of accident pilots had an accident or incident before the study accident. In four of these cases, the event included in the study was the pilot's third recorded mishap. 19 percent is not 'most'. Two previous mishaps in four cases does not equate to a long history of incidents. This does not support the statement that: "Most pilots who kill themselves have a long history of incidents prior " |
#174
... Steve Foley writes: I have. In fact, I'll be taking the written test in a few weeks. Good luck. Getting back to the point, I don't see any airways 20 miles southeast of Aspen. What was your route? I also saw (I think) in a post that you leaned the mixture prior to take-off. Did you continue leaning as you climbed? |
#175
Steve Foley writes:
Getting back to the point, I don't see any airways 20 miles southeast of Aspen. What was your route? ETL.V68.MTJ.RIL.DBL I wasn't flying an airway in the 172. I prepared a route that avoided the high mountains to the east. I have since flown IFR via ETL.V68.MTJ.V361.DBL at 12000 in the Baron, with no problems (although KASE was VFR at the time). I also saw (I think) in a post that you leaned the mixture prior to take-off. Did you continue leaning as you climbed? I leaned the mixture for take-off because of the altitude. Held the brakes, full throttle, adjusted mixture for 10° rich of peak. I did lean it slightly more during the flight, but there isn't much difference in mixture between 9000 and 12000 feet. I always lean the mixture for peak EGT and then back off 5-15 degrees. |
#176
news ![]() Steve Foley writes: Getting back to the point, I don't see any airways 20 miles southeast of Aspen. What was your route? ETL.V68.MTJ.RIL.DBL How did you end up southeast of Aspen? |
#177
Mxsmanic wrote in
: Buster Hymen writes: Instrument procedures are NOT the only way to fly, you moron. Nobody said otherwise. I simply pointed out that the design criteria for airways are discussed in the Instrument Procedures Handbook. It explains the type of terrain and obstacle clearance that airways nominally provide. Even someone who doesn't want an IR would still be well advised to read this book. You really are a ****ing idiot Anthony. You don't know **** from shinola about aviation. The terrain and obstacle clearance on the airways are designed for instrument flight. The fecal matter you call a brain can't distinguish between VFR and IFR. |
#178
Steve Foley writes:
How did you end up southeast of Aspen? I didn't. I crashed southeast of Garfield County, as I've already explained. |
#179
Mxsmanic wrote in
: Steve Foley writes: You stated you were flying VFR You said that you were not taught about safety margins for terrain in airways. I pointed you to an official publication that describes those margins. The best terrain clearance is normally not along an airway. Mountain passes don't care where the VORs are. Read the book. Not only have we read the book, Anthony you dumb ****, we've actually flown airplanes. You don't know **** from shinola about flying an airplane. All you do is play a game while yanking your joy stick. |
#180
Mxsmanic wrote in
news ![]() I have since flown IFR via ETL.V68.MTJ.V361.DBL at 12000 in the Baron, with no problems (although KASE was VFR at the time). LIAR. You have NEVER flown a Baron. You just pretend to fly a Baron while jerking your joy stick. |
Uncontrolled Engine Compartment Fire Possible for Cessna 172R, 172S, 182T, T182T, 206H, and T206H Models | Larry Dighera | Piloting | 0 | April 19th 07 04:31 PM |
'99-'00 172R vs 172SP: R is good? or the weak little brother? | XrayYankee | Owning | 9 | May 1st 06 06:07 AM |
C-172R to SP upgrade | Greg Farris | Owning | 5 | May 6th 05 10:17 AM |
172P vs 172R for instrument platform..... | Jonathan | Instrument Flight Rules | 6 | July 22nd 04 01:52 AM |
FS: 1997 Cessna 172R | Alan Adamson | Aviation Marketplace | 1 | June 1st 04 12:57 PM |
