On May 15, 2:43 am, "Dick" wrote:
how does one decide to use a "cable" versus "spring" for the connection between rudder horn and tailwheel assembly horn? how tightly connected and what strength spring, etc? Thanks Dick (an evolving tricycle driver G) Shouldn't use just cables, as you could lose rudder control if the tailwheel pivot seized up. Springs are better. Springs also allow the tailwheel to move up and down on its suspension without having cables too tight or loose as it travels up and down. That said, I have seen tailwheels steered with a single push- pull rod on some homebuilts. I wouldn't be comfortable with that. The spring takes some experimentation. You need them stiff enough for good control, but soft enough that you can unlock the steering easily when you want to (if it has the full-castering feature). The springs need to allow the wheel to travel beyond normal rudder travel so that the lock will release. Dan |
Vario setup | brianDG303 | Soaring | 1 | April 3rd 08 05:20 PM |
wanted scott 3200 tailwheel /alaskan bushwheel tailwheel | phillip9 | Aviation Marketplace | 0 | June 6th 06 07:57 PM |
Newbie question on trailering Setup | joe | Soaring | 11 | December 26th 04 11:10 PM |
Tailwheel question | Steve B | Aerobatics | 4 | January 30th 04 03:35 AM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
