On May 16, 8:31*am, ContestID67 wrote:
I am not an aerodynamicist and therefore I could be wrong (and probably am), but I have always thought of airbrakes being terminal devices. That is, they will limit speed, such as in a dive or on glidepath. My old BG-12 had terminal flaps and with them all the way out, you could not go more than about 60 kts no matter where the nose was pointed. It has been 25 years since I flew one, but if I recall correctly, doesn't the 1-34 also has terminal dive brakes. By extrapolation therefore, spoilers are speed devices which spoil lift and slow the aircraft down but do not limit dive speed. Airbrakes will limit speed, and that is why you have to be so careful not to open them when you are too fast. If I am wrong, so what? I am an idiot anyway. I spotted the following statement in Wikipedia. http://en.wikipedia.org/wiki/Spoiler...%28aircraft%29 "Spoilers differ from airbrakes in that airbrakes are designed to increase drag while making little change to lift, while spoilers greatly reduce lift while making only a moderate increase in drag." I had always used the terms spoilers and airbrakes interchangeable. This statement makes it seem like they are not. *So what does the typical sailplane have? *Spoilers or airbrakes? - John "67" DeRosa |
Spoilers, no spoilers? | Amine | Piloting | 39 | February 14th 08 02:37 AM |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 01:50 PM |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
