Spoilers or Airbrakes - Whats in a name?
Old May 16th 08, 09:37 PM posted to rec.aviation.soaring
Andy[_1_]
Default Spoilers or Airbrakes - Whats in a name?
On May 16, 12:46*pm, Brian wrote:
Take a glider at approach speed about 5 feet off the runway in steady
state (at least for a glider) level flight with all drag devices
retracted..
If you deploy the spoilers and do not change attitude the glider will
drop onto runway, speed will change very little.
if you deploy airbrakes the glider will slow and settle to the runway.
If you deploy flaps the glider will balloon up.
Maintaining a constant attitude in the test you describe will require
a pitch control input and that input controls what happens to the
glider as the devices are deployed. To put it another way,
maintaining pitch attitude is an arbitrary choice. You could have
specified constant sink rate, constant glide path, constant airspeed,
etc etc. That close to the ground my intent is to control sink rate
and the controls interact to achieve that.
In my experience deploying my top surface devices with stick free
results in nose down pitch, increased sink rate, and airspeed remains
essentially constant. Who can define the name of the device that
causes that?
Andy
Old May 16th 08, 10:27 PM posted to rec.aviation.soaring
Brian[_1_]
snip
glider as the devices are deployed. *To put it another way,
maintaining pitch attitude is an arbitrary choice. *You could have
etc etc. *That close to the ground my intent is to control sink rate
causes that?
Andy
Yes, I specified constant attitude simply because I can obviously stop
the descent by pitching back up. I was just trying to Isolate the
effects of the various drag devices which as you point out is simlar
no matter what the initial steady state is.
One other feature I have noticed on Spoilers is they tend to be ON/OFF
as opposed to Airbrakes that tend to be more proportional. I.E. in my
example if you slowly apply the Spoilers at a certain point the glider
will just drop. Where as the Airbrakes will tend to gradually become
more effective.
Brian
Spoilers, no spoilers? Amine Piloting 39 February 14th 08 02:37 AM
spoilers vs. ailerons [email protected] Piloting 36 August 8th 05 11:24 AM
Airbrakes Pop Out at 115 kts ContestID67 Soaring 13 May 10th 05 01:50 PM
ASW19b best descent rate on approach (full airbrakes) Robert Sharpe Soaring 1 April 30th 05 11:41 AM
L-13 Spoilers Scott Soaring 2 August 27th 03 06:08 AM
