Spoilers or Airbrakes - Whats in a name?
Old May 17th 08, 02:53 PM posted to rec.aviation.soaring
Tony Verhulst
Default Spoilers or Airbrakes - Whats in a name?
user wrote:
I'd continue to use them interchangeably .....
If during a positive control check the pilot corrects your call
of "spoilers," look under the wing for the extra control surface.
Yes, I've seen at least 2 books (FAA Glider Flying Handbook and Russell
Holtz's Glider Pilot's Handbook of Aeronautical Knowledge)where the
writer claimed that if the ..um.. "device".. extended top surface only
it was a spoiler and if it extended from both survaces it was an air
brake. Seems dubious to me.
Tony V LS6-b "6N"
Old May 18th 08, 12:10 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Way back when ... there were terminal velocity dive brakes on gliders. (I
believe another term was DFS dive brakes, but am not sure about that).
These brakes would hold the glider below VNe in a vertical dive. At some
point, as air foils became thinner, manufacturers agreed that the air
brakes would be designed to hold the glider below VNe at a 45 deg. descent
angle. I believe this was sanctioned by JAR, IGC, or some such.
Spoilers will place no limit on speed and cannot be used in a steep or
High Parasitic Drag Approach, whereas airbrakes can be.
No one has mentioned an important difference between flaps and airbrakes
(whether spoilers, divebrakes, airbrakes, or your term of choice). This
difference is the effect had on closing them after having established a
stabilized descent under their use.
Retracting the airbrakes causes the stall speed to be lowered and the
glide angle to improve. If you are low and slow, retracting improves
EVERYTHING.
If you are low and slow and retract flaps, stall speed goes UP and you
might find yourself in the woods, creek, fence, or whatever is short of
the touchdown point.
control surface.
Russell
surface only
>Tony V LS6-b "6N"
Old May 18th 08, 02:25 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Poorly stated; corrections inserted.
(I
some
descent
>Spoilers will place no limit on speed and [will not be effective] in a
steep or
airbrakes
This
a
>EVERYTHING.
>If you are low and slow and retract flaps, stall speed goes UP [the
lift DECREASES]
and you
of
call
>control surface.
>Russell
top
>surface only
air
>>Tony V LS6-b "6N"
Spoilers, no spoilers? Amine Piloting 39 February 14th 08 02:37 AM
spoilers vs. ailerons [email protected] Piloting 36 August 8th 05 11:24 AM
Airbrakes Pop Out at 115 kts ContestID67 Soaring 13 May 10th 05 01:50 PM
ASW19b best descent rate on approach (full airbrakes) Robert Sharpe Soaring 1 April 30th 05 11:41 AM
L-13 Spoilers Scott Soaring 2 August 27th 03 06:08 AM
