Way back when ... there were terminal velocity dive brakes on gliders. (I
believe another term was DFS dive brakes, but am not sure about that). These brakes would hold the glider below VNe in a vertical dive. At some point, as air foils became thinner, manufacturers agreed that the air brakes would be designed to hold the glider below VNe at a 45 deg. descent angle. I believe this was sanctioned by JAR, IGC, or some such. Spoilers will place no limit on speed and cannot be used in a steep or High Parasitic Drag Approach, whereas airbrakes can be. No one has mentioned an important difference between flaps and airbrakes (whether spoilers, divebrakes, airbrakes, or your term of choice). This difference is the effect had on closing them after having established a stabilized descent under their use. Retracting the airbrakes causes the stall speed to be lowered and the glide angle to improve. If you are low and slow, retracting improves EVERYTHING. If you are low and slow and retract flaps, stall speed goes UP and you might find yourself in the woods, creek, fence, or whatever is short of the touchdown point. At 13:53 17 May 2008, Tony Verhulst wrote: >user wrote: >> I'd continue to use them interchangeably ..... > > If during a positive control check the pilot corrects your call >> of "spoilers," look under the wing for the extra control surface. > >Yes, I've seen at least 2 books (FAA Glider Flying Handbook and Russell >Holtz's Glider Pilot's Handbook of Aeronautical Knowledge)where the >writer claimed that if the ..um.. "device".. extended top surface only >it was a spoiler and if it extended from both survaces it was an air >brake. Seems dubious to me. > >Tony V LS6-b "6N" > |
Poorly stated; corrections inserted.
At 23:10 17 May 2008, Nyal Williams wrote: >Way back when ... there were terminal velocity dive brakes on gliders. (I >believe another term was DFS dive brakes, but am not sure about that). >These brakes would hold the glider below VNe in a vertical dive. At some >point, as air foils became thinner, manufacturers agreed that the air >brakes would be designed to hold the glider below VNe at a 45 deg. descent >angle. I believe this was sanctioned by JAR, IGC, or some such. > >Spoilers will place no limit on speed and [will not be effective] in a steep or >High Parasitic Drag Approach, whereas airbrakes can be. > >No one has mentioned an important difference between flaps and airbrakes >(whether spoilers, divebrakes, airbrakes, or your term of choice). This >difference is the effect had on closing them after having established a >stabilized descent under their use. > >Retracting the airbrakes causes the stall speed to be lowered and the >glide angle to improve. If you are low and slow, retracting improves >EVERYTHING. > >If you are low and slow and retract flaps, stall speed goes UP [the lift DECREASES] and you >might find yourself in the woods, creek, fence, or whatever is short of >the touchdown point. > > >At 13:53 17 May 2008, Tony Verhulst wrote: >>user wrote: >>> I'd continue to use them interchangeably ..... >> > If during a positive control check the pilot corrects your call >>> of "spoilers," look under the wing for the extra >control surface. >> >>Yes, I've seen at least 2 books (FAA Glider Flying Handbook and >Russell >>Holtz's Glider Pilot's Handbook of Aeronautical Knowledge)where the > >>writer claimed that if the ..um.. "device".. extended top >surface only >>it was a spoiler and if it extended from both survaces it was an air >>brake. Seems dubious to me. >> >>Tony V LS6-b "6N" >> > |
Spoilers, no spoilers? | Amine | Piloting | 39 | February 14th 08 02:37 AM |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 01:50 PM |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
