Mxsmanic wrote in
: A Lieberman writes: Read my ILS rational, where you feel the applied power to capture the glide slope. If you don't feel it in the seat of your pants, you got a bigger issue. If you are above the glide slope, and you reduce power, the lack of pressure in your butt should happen, but if the opposite happens, you have a problem. To capture the glide slope, you watch the needles on your instruments. Good example, though not likely, but very possible is having the trim set in the nose down position rather then nose up. Apply power and instead of maintaining level altitude, you just accelerated downhill and you wouldn't get that firm seat of the pants feeling. Applying power will not accelerate you downhill. Power controls altitude, pitch controls speed. At constant pitch, increased power produces increased lift, and thus produces a climb. The building airspeed and the ABSENCE of an expected seat of the pants feeling doesn't bode well. This would be an extreme example, but very pluasible. Just look at the instruments, and forget the seat of the pants. Your altimeter will tell you about changes in altitude, and your airspeed indicator will tell you about changes in speed. Remember, that the above sensations helps CONFIRM the instruments, NOT the other way around. No. The instruments confirm. The instruments are the final authority. If you are looking at the instruments to begin with (as you will be in IMC), you don't need anything else, and paying attention to sensations of movement will only get you into trouble. You can't. Yes, you can. You can fly entirely with instruments. You _have to_ fly entirely with instruments in IMC. Doing anything else is dangerous. It's a combination that makes it all work. No combination is necessary. If you put 100 percent faith in instruments and ignore what I am describing above, then you are failing to recognize instrumentation or airplane setting errors, and that will lead to a not so good ending. Failing instruments in IMC usually lead to a not-so-good ending. The seat of your pants won't help you. It's a combination of instruments AND what you feel in the seat of your pants (NOT your inner ear feelings) that makes a difference between landing at minimums or butching up an approach. No, it's instruments. Again, go up with an IA rated pilot, see what the real deal is all about. That hood just doesn't do it any justice, nor will any MSFS desktop simulator do it. This is unrelated to simulations or hoods. In the real world, in IMC, you fly by instruments. Look at the cowling, and it was straight and level relative to the camera, but in reality, I was in a climbing right turn. If the cowling starts to move while you're flying, you have worse problems than just failing instruments. In my case, I verified the VSI reading with the feeling in my rear end. Your rear end is useless for measuring rate of climb. Just try getting kicked in the ass and see.... Bertie |
DC-3 parts to give away | Robert Little | Restoration | 2 | November 23rd 06 03:30 AM |
Who can give a checkout? | Mark S Conway | General Aviation | 2 | May 9th 05 12:15 AM |
Winch give-away | KP | Soaring | 6 | January 11th 05 08:04 PM |
Did you ever give up on an IR? | No Such User | Piloting | 24 | November 26th 03 02:45 PM |
FS 2004 give away | Ozzie M | Simulators | 0 | November 23rd 03 03:50 PM |
