Maintaining altitude
Old May 19th 08, 12:37 PM posted to rec.aviation.student,rec.aviation.piloting
More_Flaps
Default Maintaining altitude
On May 19, 9:11*am, Mxsmanic wrote:
terry writes:
Good point MX , another idea, I could get an inflatable copilot, like
in the *Flying high movie, and fill this with water instead of air.
Then I could just buckle him in! * and if I *get thirsty *I could
just.......no maybe not.... wonder if you can get girl inflatable
pilots?.
I don't see any clear advantage to humanoid ballast.
Help scare off a potential simulated hijacker?
Cheers
  #42
Old May 19th 08, 10:41 PM posted to rec.aviation.student,rec.aviation.piloting
Viperdoc[_3_]
Anthony, in my real Baron, when detecting an updraft, I will immediately
begin a tight circle to stay in the updraft and simultaneously feather both
engines. This saves tremendously on the ever increasing cost of gas.
I can then glide to the next thermal, and am able to accomplish extensive
cross country trips of nearly a thousand miles on just a few gallons of gas.
It is one of the most economical ways of flying multiengine aircraft.
When necessary I can always do a re-start (see unfeathering accumulators).
  #43
Old May 19th 08, 11:39 PM posted to rec.aviation.student,rec.aviation.piloting
B A R R Y
On Mon, 19 May 2008 16:41:06 -0500, "Viperdoc"
Failing a restart, you can always eject!
  #44
Old May 20th 08, 02:17 AM posted to rec.aviation.student,rec.aviation.piloting
On May 16, 9:15 am, wrote:
In rec.aviation.piloting Mxsmanic wrote:
Is it better (in a small GA aircraft) to maintain altitude using minor changes
in pitch and trim alone, or using both pitch/trim and throttle adjustments?
I'm asking just about maintaining altitude once there, not climbing or
descending to an altitude.
Well, if you had actually read any of the books by experts you go on
about, you would know this.
Or had taken actual instruction, but I digress.
Once established in cruise and assuming power and trim have been properly
adjusted, you will in general have two factors that will cause the
altitude to change.
One is vertical wind, i.e. turbulance and thermals. This usually
requires yoke input.
The other is the airplane gets lighter as you burn off fuel. This is
what trim is for.
Theoretically the combination of temperature and pressure could cause
the engine output power to change requiring throttle and mixture
adjustments, but I don't see that happening in the typical C-172 class
flight.
Jim Pennino
Remove .spam.sux to reply.
I find that tiny power changes work better for maintaining
altitude than fooling with small trim changes. If the airplane is
climbing a bit, cranking in nose-down trim will increase speed and
upset the whole equilibrium somewhat. If one does this to descend back
to target altitude, the extra speed obtained will be a pain to deal
with as the airplane is retrimmed nose-up to stop the descent. Speed
will bleed off and the airplane will sink below altitude. Up and down
we go. Small---really small---power changes work better.
Dan
  #45
Old May 20th 08, 02:35 AM posted to rec.aviation.student,rec.aviation.piloting
altitude to change.
what trim is for.
flight.
Jim Pennino
I can see that if your throttle is capable of making tiny changes; mine
isn't.
I already replaced the mixture control with a vernier because I didn't
like the corseness of the old push-pull and one of these days I'm going
to do that to the throttle control.
Jim Pennino
Vector altitude for ILS below GS intercept altitude? M Instrument Flight Rules 23 May 20th 06 07:41 PM
GPS altitude vs altimeter altitude Chris W Piloting 37 April 19th 06 10:45 AM
Maintaining currency/proficiency after getting my Instrument rating Gary Drescher Instrument Flight Rules 0 March 2nd 06 12:49 PM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
Say Altitude. Hankal Instrument Flight Rules 26 April 8th 04 07:01 AM
