Better scavenging and more power means more fuel flow... - TANSTAAFL
denny |
![]() "Denny" wrote in message ... Better scavenging and more power means more fuel flow... I believe that depends on a number of variables. Lower flow losses means higher efficiency. Higher efficiency can mean lower fuel flow at a given power output, or it can mean higher horsepower output at the same or greater fuel flow. Vaughn |
![]() "Denny" wrote in message ... Better scavenging and more power means more fuel flow... - TANSTAAFL denny When I'm pulling on the collective, looking for more torque, (rpm is constant in my helicopter) there are times when fuel flow doesn't even come into the equation. I will still normally only use the power that I need, but when the density altitude starts climbing up a power reserve is worth a bunch of money.] Stu |
Tuned exhaust for the Lycoming 0320 | Stuart & Kathryn Fields | Rotorcraft | 4 | June 21st 08 04:09 AM |
Lycoming 0-320 Exhaust studs working loose | Mike Spera | Owning | 9 | May 26th 07 03:25 AM |
0320 engine for mockup | Stuart & Kathryn Fields | Home Built | 0 | April 6th 07 03:20 AM |
The Ghost of Andy Granatelli Tuned My Airplane! | Bob Chilcoat | Piloting | 6 | July 8th 06 11:25 PM |
tuned ground plane | John Tvedte | Home Built | 13 | November 27th 04 06:09 PM |
