On May 20, 6:39*am, Ed Winchester wrote:
nimbusgb wrote: On May 20, 2:25 am, "Bob Salvo" wrote: It seems to me that Mylar may only be necessary on the top of the stab/elevator, since the top surface is the high pressure side. *Has anyone tried this? The top side is the low pressure side Bob! I don't think so, as the tail of just about every airplane or glider has a download. *That's how they achieve stability. *So it's backward at the tail, the top surface is indeed the high-pressure side. Just to add to this "pressure" discussion, my elevator has a shape similar to the trailing edge of my wing. The top-side is convex, and the bottom-side is concave. Wouldn't that be a clue as to where the high and low pressure areas are? I would think the convex side is the low-pressure side, which is on top. Dave P.S. Any other thoughts on using mylars and safety tape on the elevator gap? |
As long as the elevators produces a force downwards, the low pressure side
is on top. This is typically the case for speeds higher than best L/D. For speeds closer to stall speed, the elevator produces lift, and the low pressure side is on the bottom. For an optimum design, the elevator produces no force at all (except drag...) at the speed of best L/D. But then, not all designs are optimum... Bert wrote in message ... On May 20, 6:39 am, Ed Winchester wrote: nimbusgb wrote: On May 20, 2:25 am, "Bob Salvo" wrote: It seems to me that Mylar may only be necessary on the top of the stab/elevator, since the top surface is the high pressure side. Has anyone tried this? The top side is the low pressure side Bob! I don't think so, as the tail of just about every airplane or glider has a download. That's how they achieve stability. So it's backward at the tail, the top surface is indeed the high-pressure side. Just to add to this "pressure" discussion, my elevator has a shape similar to the trailing edge of my wing. The top-side is convex, and the bottom-side is concave. Wouldn't that be a clue as to where the high and low pressure areas are? I would think the convex side is the low-pressure side, which is on top. Dave P.S. Any other thoughts on using mylars and safety tape on the elevator gap? |
On May 20, 8:17 am, Eric Greenwell wrote:
trim tab). In his 1989 article on increasing performance, Peter Masak talked about reducing drag by filling in this bottom concavity. No mention of the expected drag savings, but lots of words about flutter concerns. Not to mention changing the pressure distribution on the aft section of the wing/tail - thus changing its Coefficient of Moment (i.e. its desire to rotate/torque around the center of lift). That effect is less critical on the tail than on the main wing (doing so on the wing might require an increase in tail volume to control the added moment); but the bottom line is that you're essentially making a custom airfoil when you fill that cusp. It isn't necessarily a bad thing, but if you don't know what you're doing you could just as easily make it perform worse... --Noel |
On May 20, 8:44 am, "noel.wade" wrote:
On May 20, 8:17 am, Eric Greenwell wrote: trim tab). In his 1989 article on increasing performance, Peter Masak talked about reducing drag by filling in this bottom concavity. No mention of the expected drag savings, but lots of words about flutter concerns. Not to mention changing the pressure distribution on the aft section of the wing/tail - thus changing its Coefficient of Moment (i.e. its desire to rotate/torque around the center of lift). That effect is less critical on the tail than on the main wing (doing so on the wing might require an increase in tail volume to control the added moment); but the bottom line is that you're essentially making a custom airfoil when you fill that cusp. It isn't necessarily a bad thing, but if you don't know what you're doing you could just as easily make it perform worse... --Noel Dick Johnson changed the amount of cusp on his Nimbus 3 to reduce the pitch up at higher speeds. Jim Phoenix has a nice note on it. http://www.jimphoenix.com/jimphoenix...Nelevator.html Craig |
Mylar seals for PIK20D | culverflyer | Soaring | 5 | May 19th 04 06:25 PM |
Mylar seals installation | John W | Soaring | 2 | May 5th 04 09:03 PM |
mylar seals wing to flap/ Aileron | culverflyer | Soaring | 2 | May 5th 04 02:52 PM |
ZZ Mylar seals | Mike | Soaring | 3 | March 29th 04 03:45 PM |
mylar seals | D.A.L | Soaring | 1 | February 23rd 04 07:15 PM |
