On May 20, 10:27 am, "Ken S. Tucker" wrote:
When thought through, the Mag-Comp is quite the precision instrument. That fluid needs be able to not freeze down to what, maybe -40F. (Ron from Alaska might know). It also sits in an Arizona sun and can't expand to burst, though yours (John) may have. It also has a viscosity that keeps the thing from gyrating all over the place, the one we used had a slow lag while banking, so if you wanted to come to 180 level the wings for 178 and the thing creeps to 180. Ken Good grief. The compass has a diaphragm to take care of expansion and contraction, and its fluid is just a solvent that has a low freeze point. Even plain old gasoline has a low freeze point. Nothing "precision" about that. And as for lag while banking, you haven't studied the Private Pilot groundschool stuff about Northerly Turning Error or anything else. You CANNOT use it to roll out on a heading like you claim. And you can't fly a 150 at 37 Kts indicated on approach. 150s never had knotmeters. anyway. Had airspeed indicators calibrated in MPH. And what is an "indescent indicator?" Does it measure indecent exposure, maybe? Dan |
On May 20, 10:04 am, wrote:
On May 20, 10:27 am, "Ken S. Tucker" wrote: When thought through, the Mag-Comp is quite the precision instrument. That fluid needs be able to not freeze down to what, maybe -40F. (Ron from Alaska might know). It also sits in an Arizona sun and can't expand to burst, though yours (John) may have. It also has a viscosity that keeps the thing from gyrating all over the place, the one we used had a slow lag while banking, so if you wanted to come to 180 level the wings for 178 and the thing creeps to 180. Ken Good grief. The compass has a diaphragm to take care of expansion and contraction, and its fluid is just a solvent that has a low freeze point. Even plain old gasoline has a low freeze point. Mr. Potato Head, we don't put a big blob of flammable material in a cock-pit, your sci-phy-math-chem education is a functional Gr.10. Nothing "precision" about that. And as for lag while banking, you haven't studied the Private Pilot groundschool stuff about Northerly Turning Error or anything else. You CANNOT use it to roll out on a heading like you claim. Duh, that's what your mag-field map is for, it provides the mag-heading relative to true north at the location you're at. I flew alot in ontario and lines are a mess, but that's not a big deal over ~ 50 miles. My required instruction was to use the mag-comp for IFR, including pitch level, yaw constant, and nulled roll, it's a semi skill. It has two spheres, one enclosing fixed to the aircraft that is transparent, but demarkated, and a internal floater also demarkated. The relative equators is what's important. Once the heading and throttle power is fixed, align the equators to maintain a constant pitch and altitude, and that will get you by in foggy night, if you have a flashlight. That's a 1 hour lesson, and I'd be happy to instruct you on that, if you're qualified to understand it. I had a cool instructor and we'd play out worst case scenerios, such as in a dark and stormy foggy night with all normal instruments failed, how do we get back to a base. And you can't fly a 150 at 37 Kts indicated on approach. 150s never had knotmeters. anyway. Had airspeed indicators calibrated in MPH. LOL, Is that a MIAS instead of a KIAS? And what is an "indescent indicator?" Does it measure indecent exposure, maybe? Depends on whether you're using the yoke or the stick, which do you prefer? Ken |
"Ken S. Tucker" wrote in message
news:c47ef4b0-754f-42b8-bdb5- Mr. Potato Head, we don't put a big blob of flammable material in a cock-pit, your sci-phy-math-chem education is a functional Gr.10. Whew, that's good to know. I always thought that dripping form the primer was gasoline. |
On May 20, 11:59 am, "Steve Foley" wrote:
"Ken S. Tucker" wrote in message news:c47ef4b0-754f-42b8-bdb5- Mr. Potato Head, we don't put a big blob of flammable material in a cock-pit, your sci-phy-math-chem education is a functional Gr.10. Whew, that's good to know. I always thought that dripping form the primer was gasoline. You should fix you drip. Ken |
On May 20, 12:16 pm, "Ken S. Tucker" wrote:
Good grief. The compass has a diaphragm to take care of expansion and contraction, and its fluid is just a solvent that has a low freeze point. Even plain old gasoline has a low freeze point. Mr. Potato Head, we don't put a big blob of flammable material in a cock-pit, your sci-phy-math-chem education is a functional Gr.10. Compass fluid is a petroleum product and is flammable. Its MSDS says it's odorless mineral spirits, which would make it similar to household paint thinner: http://www.setonresourcecenter.com/m...4/wcd00445.htm Nothing "precision" about that. And as for lag while banking, you haven't studied the Private Pilot groundschool stuff about Northerly Turning Error or anything else. You CANNOT use it to roll out on a heading like you claim. Duh, that's what your mag-field map is for, it provides the mag-heading relative to true north at the location you're at. I flew alot in ontario and lines are a mess, but that's not a big deal over ~ 50 miles. Magnetic variation has nothing to do with Northerly Turning Error or acceleration/deceleration errors. Nothing at all. You never took groundschool, obviously. And in southern Ontario, where you "flew," the variation is minimal, which you did not know. The lines aren't a "mess." Out in western Canada it gets a little more complex: http://nationalatlas.gov/articles/geology/a_geomag.html My required instruction was to use the mag-comp for IFR, including pitch level, yaw constant, and nulled roll, it's a semi skill. It has two spheres, one enclosing fixed to the aircraft that is transparent, but demarkated, and a internal floater also demarkated. The relative equators is what's important. Once the heading and throttle power is fixed, align the equators to maintain a constant pitch and altitude, and that will get you by in foggy night, if you have a flashlight. That's a 1 hour lesson, and I'd be happy to instruct you on that, if you're qualified to understand it. No, it won't. Ever. No matter how many times you claim it will. I had a cool instructor and we'd play out worst case scenerios, such as in a dark and stormy foggy night with all normal instruments failed, how do we get back to a base. What a bunch of nonsense. It would be funny if it didn't have the potential to mislead normal students. And you can't fly a 150 at 37 Kts indicated on approach. 150s never had knotmeters. anyway. Had airspeed indicators calibrated in MPH. LOL, Is that a MIAS instead of a KIAS? MPH indicated. You should know that. And what is an "indescent indicator?" Does it measure indecent exposure, maybe? Depends on whether you're using the yoke or the stick, which do you prefer? Ken How does that make any difference to an instrument that does not exist? Dan |
On May 20, 6:26 pm, wrote:
On May 20, 12:16 pm, "Ken S. Tucker" wrote: Good grief. The compass has a diaphragm to take care of expansion and contraction, and its fluid is just a solvent that has a low freeze point. Even plain old gasoline has a low freeze point. Mr. Potato Head, we don't put a big blob of flammable material in a cock-pit, your sci-phy-math-chem education is a functional Gr.10. Compass fluid is a petroleum product and is flammable. Its MSDS says it's odorless mineral spirits, which would make it similar to household paint thinner: http://www.setonresourcecenter.com/m...4/wcd00445.htm Anti-freeze. (glycol) Ken |
On May 20, 11:43 pm, "Ken S. Tucker" wrote:
On May 20, 6:26 pm, wrote: Compass fluid is a petroleum product and is flammable. Its MSDS says it's odorless mineral spirits, which would make it similar to household paint thinner: http://www.setonresourcecenter.com/m...4/wcd00445.htm Anti-freeze. (glycol) Ken Glycol is a "slight to moderate fire hazard," unlike petroleum products. It is not the same as paint thinner or compass fluid or anywhere near the same. It's a form of alcohol. http://www.jtbaker.com/msds/englishhtml/e5125.htm Dan |
On May 21, 7:21 am, wrote:
On May 20, 11:43 pm, "Ken S. Tucker" wrote: On May 20, 6:26 pm, wrote: Compass fluid is a petroleum product and is flammable. Its MSDS says it's odorless mineral spirits, which would make it similar to household paint thinner: http://www.setonresourcecenter.com/m...4/wcd00445.htm Anti-freeze. (glycol) Ken Glycol is a "slight to moderate fire hazard," unlike petroleum products. It is not the same as paint thinner or compass fluid or anywhere near the same. It's a form of alcohol.http://www.jtbaker.com/msds/englishhtml/e5125.htm Dan First, does your preflight check list require you ascertain your mag-comp as functional, and if so, why? Ken |
On May 21, 5:02 pm, "Ken S. Tucker" wrote:
First, does your preflight check list require you ascertain your mag-comp as functional, and if so, why? Ken What does that have to do with compass fluid? Compass checks are carried out during taxi, particularly for an IFR flight. Attitude indicator erect and steady; heading indicator set and indicating during turns; turn coordinator functioning and ball free; compass free and floating, altimeter set and indicating proper elevation, radios set. That's about as much as I can remember, since my Instrument ticket lapsed eight years ago. Compass is not part of the preflight. Tell me: what does the compass do in a turn to or from North versus a turn to or from South? Why does this make it useless for rolling out on a heading unless we use a timer? Dan |
: On May 21, 7:21 am, wrote: On May 20, 11:43 pm, "Ken S. Tucker" wrote: On May 20, 6:26 pm, wrote: Compass fluid is a petroleum product and is flammable. Its MSDS says it's odorless mineral spirits, which would make it similar to household paint thinner: http://www.setonresourcecenter.com/m...4/wcd00445.htm Anti-freeze. (glycol) Ken Glycol is a "slight to moderate fire hazard," unlike petroleum products. It is not the same as paint thinner or compass fluid or anywhere near the same. It's a form of alcohol.http://www.jtbaker.com/msds/englishhtml/e5125.htm Dan First, does your preflight check list require you ascertain your mag-comp as functional, and if so, why? Because if it wasn't he might accidentally end up in your neighborhood. Bertie |
DC-3 parts to give away | Robert Little | Restoration | 2 | November 23rd 06 03:30 AM |
Who can give a checkout? | Mark S Conway | General Aviation | 2 | May 9th 05 12:15 AM |
Winch give-away | KP | Soaring | 6 | January 11th 05 08:04 PM |
Did you ever give up on an IR? | No Such User | Piloting | 24 | November 26th 03 02:45 PM |
FS 2004 give away | Ozzie M | Simulators | 0 | November 23rd 03 03:50 PM |
