On May 20, 3:44*pm, Scott Skylane wrote:
IMC - Instrument Meteorological Conditions - Condition under which flight instruments are used to maintain control of an aircraft. *How used: *"Flight into IMC". *One would not say "an IMC rating". *If you can use outside references to maintain flight you are not in IMC... as in "flying in and out of IMC". /snip/ Bob, Where did you get that definition? *The Pilot Controller Glossary states: "Instrument Meteorological Conditions - Meteorological conditions expressed in terms of visibility, distance from cloud,and ceiling less than the minima specified for visual meteorological conditions." Scott, You are correct THE WAY I UNDERSTAND the above. For purposes of logging IMC, I only log it when I am inside a cloud in my log book, but anything less then VMC conditions is considered IMC. So in reality, I have spent many more hours in IMC by legal definitions then what is in my log book. But I am not seeking anymore ratings so I don't mind. And in order to fly VMC, you must be VFR, which means keeping the appropriate cloud clearances based VFR flight rules. So, if you are 20 feet above a cloud deck seeing 200 miles ahead under a glorious sunshine, it is considered IMC because you are not maintaining VFR clearances from the clouds. And when one thinks about it, one is flying by instruments since you have no ground references anyway. To be in and out of IMC conditions, I see that happening on a scattered cloud day at the altitude you are flying. You cannot maintain in and out of IMC on a cloud deck that is considered broken (I.E horizontal cloud clearances wouldn't be met).at that cloud altitude like on a day of scattered cumulus. As far as the official rating, I believe it's IA (Instrument Air) that allows you to fly IFR which of course allows you to fly IMC. |
On May 20, 5:36*pm, romeomike wrote:
You can only log the time if you are in IMC (not legally VFR) AND you have to fly solely by instruments. Let's say you are 50 feet below a cloud deck with 50 miles of forward visibility and nothing obscuring the ground or horizon. This is legally IMC and IFR applies, but you don't log it as such because you can fly it without having to fly solely by reference to instruments. What about the inverse as given in my example? 50 feet above an overcast? |
On May 20, 9:45*pm, romeomike wrote:
IMO, given that an overcast may obscure the horizon and not be "level" or at the same altitude as you progress, I would think you would be justified in logging it. I for one would want to be scanning instruments to make sure I'm maintaining altitude, course, level wings, etc. It wouldn't be quite as intense as if I were in the clouds, but justifiable to the feds if they examined my log book. I'm sure there are scenarios that would generate debate but maybe not this one? While I personally don't log it in my logbook as IMC time, I think like you, it's IMC since like you said, sloping clouds give an illusion of a false horizon. In my training, my instructor said no, it's not, and we were between layers! The second reason I personally think it's IMC, is that you have no ground reference to fly by and have to use instruments to navigate. |
On May 20, 11:21*pm, romeomike wrote:
I'm not an ultimate authority on this, but I don't get your instructor's point of view. If someone else can explain how in this scenario one can safely fly without reference to instruments, you and I are sure to learn something. Yep, I didn't get it either but in the full scheme of things, I wasn't complaining, as at least I had an instructor who wasn't afraid of touching a cloud. He went on to the regionals, and my second instructor wouldn't fly in ceilings less then 1000.and my airport minimums was 1/2 that. On the other hand, the second instructor had much better cockpit management so I did have the best of both worlds. |
Sandblasting reference? | Michael Horowitz | Home Built | 7 | November 20th 07 07:01 AM |
FAR Reference - Self Fueling | Ben Smith | Owning | 8 | April 8th 04 11:07 PM |
Engineering reference: | Richard Lamb | Home Built | 1 | March 14th 04 03:18 PM |
For General Reference | El Roto | Home Built | 0 | February 23rd 04 04:00 AM |
looking for modern F-4 reference | Rob van Riel | Military Aviation | 1 | November 13th 03 08:39 PM |
