Outside reference in IMC
Old May 21st 08, 08:43 AM posted to rec.aviation.piloting
Marty Shapiro
Default Outside reference in IMC
Andrew Sarangan wrote in
On May 20, 9:11 pm, Marty Shapiro
"Bob F." wrote
m:
Extra credit points! The statement below is incomplete (hint:
qualification is missing). There are lots of places in US airspace
where you could be IMC and NOT fly under IFR rules, and no flight
plan...where are they?
Glass G airspace. Lot's of it out west.
Even in class G you must still follow all the IFR rules, except you
don't need a ATC clearance.
All of them? Any FAR which states "when operating is controlled air space"
doesn't apply. That still leaves a few, but most of them are gone.
Communication with ATC? Not required in G.
Flight plan? Not required in G. No need to file or activate.
Altitude? Well, yes. But with no ATC communication requirement, you can
change it anytime you want. Unless I missed something in a quick scan,
91.179 doesn't address altitudes below 2,000' AGL and over a flat area,
such as a desert, you only need to be 1,000' AGL per 91.177. So, the rules
on altidude based on direction of flight does not necessarily apply. If
they did in G which only goes to 1,200' AGL, all IFR traffic there would be
one way.
Fuel on board? Well, I guess if you got ramped checked, you should have
statutory IFR reserves on departure, but since you're not required to have
a flight plan in G, what would be used to determine if you met IFR
reserves?
Malfunctions? No report required in G.
Instrument currency? Absolutely must have. No exceptions for class G!
SFAR 97 only applies to published routes, which are at least class E.
So, although it would be very stupid to do so, you can fly IFR in class G
airspace and not follow most of the IFR rules.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old May 21st 08, 06:51 PM posted to rec.aviation.piloting
Andrew Sarangan
Cruising altitude requirements still apply, and I am not seeing where
any exemption is made for 2000' AGL. But it does seem like traffic
has to be only one-way in areas where class G only extends up to
1200'. This is a bit confusing, but perhaps a moot point.
On May 21, 3:43 am, Marty Shapiro
"Bob F." wrote
m:
one way.
reserves?
Marty Shapiro
Silicon Rallye Inc.
Sandblasting reference? Michael Horowitz Home Built 7 November 20th 07 07:01 AM
FAR Reference - Self Fueling Ben Smith Owning 8 April 8th 04 11:07 PM
Engineering reference: Richard Lamb Home Built 1 March 14th 04 03:18 PM
For General Reference El Roto Home Built 0 February 23rd 04 04:00 AM
looking for modern F-4 reference Rob van Riel Military Aviation 1 November 13th 03 08:39 PM
