On Tue, 20 May 2008 13:36:51 +0000 (UTC), Bertie the Bunyip
wrote: Stealth Pilot wrote in : On Mon, 19 May 2008 04:29:11 +0200, Mxsmanic wrote: A Lieberman writes: The danger in instrument flight is that all sorts of things are felt, but none of them is reliable. It is called instrument flight because the pilot ignores things felt and flies exclusively by the instruments. The feeling in your rear end is no more reliable than the feeling from your inner ear. It sounds like your Friday incident has given you a false sense of security. during the history of scientific endeavour there have been many individuals who have arrived at the correct answers for the wrong reasons. anthony you are perpetually one of those people. while you may occasionally say the correct things a careful read of your posts has always revealed the fact that you have inherently an incompetent understanding of what you write about. Stealth Pilot Difference is, he doesn;t arrive at the answer, he starts there. Then he works his way back the Anthony land until he begins with a premise that is straight out of alice in wonderland. Bertie absolutely true bertie. so you, I and others like us take on the duty of correcting his posts, not ever in the hope of educating him but to warn others learning into aviation that he is wrong. personally I think we'd all be better off if we flew to paris and shot the *******. Stealth Pilot |
On May 21, 4:22 am, Stealth Pilot
wrote: Difference is, he doesn;t arrive at the answer, he starts there. Then he works his way back the Anthony land until he begins with a premise that is straight out of alice in wonderland. Bertie absolutely true bertie. so you, I and others like us take on the duty of correcting his posts, not ever in the hope of educating him but to warn others learning into aviation that he is wrong. personally I think we'd all be better off if we flew to paris and shot the *******. Stealth Pilot So you mean it doesn't work because the lift fairies flap their wings and push up on the underside of the aircraft? Are you telling me the sky sucks???? I feel so cheap and used. |
Stealth Pilot writes:
aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. |
![]() "Mxsmanic" wrote in message ... Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. So near, and yet so far... ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. God! Grant me strength! Peter |
On May 21, 12:56 pm, Mxsmanic wrote:
Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. So you're saying the sky does suck after all? What about rocket propulsion in a vacuum? How does that work? |
Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. There is an interesting article in Flying magazine by Peter Garrison that talks about lift theory. I thought that one of the most interesting points he made was that the lift force generated by an airfoil is greater at the optimum angle of attack than would be the force imparted to it if you were to move it through the air perpendicular to the air flow at the same speed. I agree that a flat wing will produce lift at a positive AOA even without an airfoil shape - it just won't be as efficient as it would otherwise be if it were shaped like an airfoil, and talk about pitch divergent... Oh yeah, the article also pretty much discounts Bernoulli as having anything to do with why a wing produces lift. BDS |
BDS wrote:
On May 21, 12:56 pm, Mxsmanic wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. There is an interesting article in Flying magazine by Peter Garrison that talks about lift theory. I thought that one of the most interesting points he made was that the lift force generated by an airfoil is greater at the optimum angle of attack than would be the force imparted to it if you were to move it through the air perpendicular to the air flow at the same speed. I agree that a flat wing will produce lift at a positive AOA even without an airfoil shape - it just won't be as efficient as it would otherwise be if it were shaped like an airfoil, and talk about pitch divergent... Oh yeah, the article also pretty much discounts Bernoulli as having anything to do with why a wing produces lift. BDS Any article that "discounts Bernoulli" as having anything to do with lift is incorrect. I just can't understand why there is so much trouble in the pilot community understanding that Newton and Bernoulli do NOT conflict in any way whatsoever, and that each explanation is correct in itself. Newton AND Bernoulli are BOTH present simultaneously on th wing at any moment lift is being created. EACH creates the other and EACH is a complete explanation for how lift is created. You can use either Newton or Bernoulli to explain lift, but the correct way to explain it is to explain how both are correct. In other words, anytime you have lift being created you have a Newton explanation AND a Bernoulli explanation occurring at the SAME TIME! -- Dudley Henriques |
"BDS" wrote:
There is an interesting article in Flying magazine by Peter Garrison that talks about lift theory. [...] Oh yeah, the article also pretty much discounts Bernoulli as having anything to do with why a wing produces lift. The Bernoulli equations aren't wrong. It is a simply a case that they apply ONLY to a set of streamlines. Once the streamlines are determined, the Bernoulli equation should be able to tell you the lift of an airfoil. Explanations that point to Bernoulli and then fail to discuss how and whence the streamlines are determined for a problem are bound to lead to confusion and misunderstanding. |
BDS writes:
I agree that a flat wing will produce lift at a positive AOA even without an airfoil shape - it just won't be as efficient as it would otherwise be if it were shaped like an airfoil, and talk about pitch divergent... Non-flat airfoil shapes help to increase the range of usable AOAs and reduce drag, but a positive AOA is still required to generate lift. Oh yeah, the article also pretty much discounts Bernoulli as having anything to do with why a wing produces lift. It is a common misconception. |
Apology re mxsmanic | terry | Piloting | 96 | February 16th 08 05:17 PM |
I saw Mxsmanic on TV | Clear Prop | Piloting | 8 | February 14th 07 01:18 AM |
Mxsmanic | gwengler | Piloting | 30 | January 11th 07 03:42 AM |
Getting rid of MXSMANIC | [email protected] | Piloting | 33 | December 8th 06 11:26 PM |
Feeling aircraft sensations | Ramapriya | Piloting | 17 | January 12th 06 10:15 AM |
