BDS wrote:
There is an interesting article in Flying magazine by Peter Garrison that talks about lift theory. I thought that one of the most interesting points he made was that the lift force generated by an airfoil is greater at the optimum angle of attack than would be the force imparted to it if you were to move it through the air perpendicular to the air flow at the same speed. I first experienced this as a kid, sticking my hand out the car window with the thumb as a leading edge, forming a crude airfoil. When at the right shape and angle of attack, the lift is amazingly strong. I always found it remarkable that when my hand was completely perpendicular to the wind, the force didn't seem as strong. Definitely a visceral lesson in lifting versus stalling. |
On May 22, 11:51 am, gatt wrote:
wrote: On May 21, 12:56 pm, Mxsmanic wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. So you're saying the sky does suck after all? What about rocket propulsion in a vacuum? How does that work? I've repeatedly explained to these guys that camber was just a conspiracy by the aluminum industry to sell more metal. I don't know why Boeing, Cessna, Piper, Beechcraft and everybody else don't listen to Mxmaniac. CAMBER IS A LIE!!! -c No no, aluminium was a conspiracy by Westinghouse and Edison (and proly Tesla too) to sell more electricity via the Bayer process! Or was it the other way 'round? Westinghouse was a conspiracy by the electricity conglomerates to produce more beer cans? Hmmm....let me adjust my Reynolds Cap. |
On May 22, 1:08 pm, Mxsmanic wrote:
writes: What about rocket propulsion in a vacuum? How does that work? Simple action and reaction. Mmmm...but your action has nothing to react against, there's nothing to push down on like you said with downwash producing lift for an airplane wing. |
On Wed, 21 May 2008 19:56:35 +0200, Mxsmanic
wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. downwash occurs after the wing has passed. how does it transmit its effect to the wing? magnetism? |
On May 22, 8:20 am, Stealth Pilot
wrote: On Wed, 21 May 2008 19:56:35 +0200, Mxsmanic wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. downwash occurs after the wing has passed. how does it transmit its effect to the wing? magnetism? Sorta. The girl lift fairies push from underneath whilst the boy lift fairies pull from up top. The obese lift fairies just hang on and thus produce drag. |
On May 23, 5:40*am, wrote:
On May 22, 8:20 am, Stealth Pilot wrote: On Wed, 21 May 2008 19:56:35 +0200, Mxsmanic wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. *It can be perfectly flat and it will still generate lift. downwash occurs after the wing has passed. how does it transmit its effect to the wing? magnetism? Sorta. *The girl lift fairies push from underneath whilst the boy lift fairies pull from up top. *The obese lift fairies just hang on and thus produce drag.- Hide quoted text - No, there are no fat faries -fat faries would not be able to fly and they would die. It's transvestite fairies that produce drag, Cheers |
downwash occurs after the wing has passed. Downwash is the result of the wing's passing. The wing accelerates air above it downwards. That downward movement continues after the wing has passed, and it is called downwash. It is the acceleration that produces the downwash that is responsible for lift. |
Apology re mxsmanic | terry | Piloting | 96 | February 16th 08 05:17 PM |
I saw Mxsmanic on TV | Clear Prop | Piloting | 8 | February 14th 07 01:18 AM |
Mxsmanic | gwengler | Piloting | 30 | January 11th 07 03:42 AM |
Getting rid of MXSMANIC | [email protected] | Piloting | 33 | December 8th 06 11:26 PM |
Feeling aircraft sensations | Ramapriya | Piloting | 17 | January 12th 06 10:15 AM |
