In rec.aviation.student Gig 601Xl Builder wrote:
Mxsmanic wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. If that were the case a 747 would have to be producing over 250,000 pounds of force straight down. Why then am I not crushed when a 747 flies over me? At sea level the atmosphere pushes down with about 14.7 pounds of force for every square inch of exposed surface. On the average man, this works out to about 43,000 pounds, all the time. Why aren't your crushed by this? -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Michael Ash wrote:
At sea level the atmosphere pushes down with about 14.7 pounds of force for every square inch of exposed surface. On the average man, this works out to about 43,000 pounds, all the time. Why aren't your crushed by this? I don't know about you but Celine Dion gave me an invisible force-field. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200805/1 |
On Thu, 22 May 2008 10:52:15 -0500, Michael Ash wrote:
In rec.aviation.student Gig 601Xl Builder wrote: Mxsmanic wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. If that were the case a 747 would have to be producing over 250,000 pounds of force straight down. Why then am I not crushed when a 747 flies over me? At sea level the atmosphere pushes down with about 14.7 pounds of force for every square inch of exposed surface. On the average man, this works out to about 43,000 pounds, all the time. Why aren't your crushed by this? Because I eat beans? |
In rec.aviation.student Gezellig wrote:
On Thu, 22 May 2008 10:52:15 -0500, Michael Ash wrote: In rec.aviation.student Gig 601Xl Builder wrote: Mxsmanic wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. If that were the case a 747 would have to be producing over 250,000 pounds of force straight down. Why then am I not crushed when a 747 flies over me? At sea level the atmosphere pushes down with about 14.7 pounds of force for every square inch of exposed surface. On the average man, this works out to about 43,000 pounds, all the time. Why aren't your crushed by this? Because I eat beans? Score yet another point for the musical fruit. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Michael Ash wrote:
At sea level the atmosphere pushes down with about 14.7 pounds of force for every square inch of exposed surface. On the average man, this works out to about 43,000 pounds, all the time. Why aren't your crushed by this? I'm too emotionally stable to be crushed by such a trivial thing. Besides, I push back with equal force. |
Interesting phrase, "pushes down". Why would you think atmospheric
pressure pushes down? On May 22, 11:52 am, Michael Ash wrote: In rec.aviation.student Gig 601Xl Builder wrote: Mxsmanic wrote: Stealth Pilot writes: aeroplanes fly because of lift generated by pressure differences on the wing surfaces. Airplanes fly because the wings divert the air through which they pass downwards, creating a downwash and exerting a force in doing so that engenders an opposite force that is lift. ... these pressure differences are caused by the shape of the aerofoil of the wing ... The air is diverted because the wing has a positve angle of attack. It can be perfectly flat and it will still generate lift. If that were the case a 747 would have to be producing over 250,000 pounds of force straight down. Why then am I not crushed when a 747 flies over me? At sea level the atmosphere pushes down with about 14.7 pounds of force for every square inch of exposed surface. On the average man, this works out to about 43,000 pounds, all the time. Why aren't your crushed by this? -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
On May 22, 5:25*pm, Tina wrote:
Interesting phrase, "pushes down". Why would you think atmospheric pressure pushes down? At sea level the atmosphere pushes down with about 14.7 pounds of force for every square inch of exposed surface. On the average man, this works out to about 43,000 pounds, all the time. Why aren't your crushed by this? Mike Ash He probably picked down since down is as good a direction as any, unless, of course, he was thinking of someone with a big head whose top surface area measures 4.5 feet x 4.5 feet. -Le Chaud Lapin- |
I think you asserted one time or the other you had technical
training. Why then in terms of static fluid pressure would one specify a direction? On May 22, 9:06 pm, Le Chaud Lapin wrote: On May 22, 5:25 pm, Tina wrote: Interesting phrase, "pushes down". Why would you think atmospheric pressure pushes down? At sea level the atmosphere pushes down with about 14.7 pounds of force for every square inch of exposed surface. On the average man, this works out to about 43,000 pounds, all the time. Why aren't your crushed by this? Mike Ash He probably picked down since down is as good a direction as any, unless, of course, he was thinking of someone with a big head whose top surface area measures 4.5 feet x 4.5 feet. -Le Chaud Lapin- |
On May 22, 8:16*pm, Tina wrote:
I think you asserted one time or the other you had technical training. *Why then in terms of static fluid pressure would one specify a direction? The fluid presses in all direction. I was merely pointing out the fact that, if he, or the source of the "43,000" in his post, actually thought that the fluid only presses downward, then "43,000" would have been a much smaller value. -Le Chaud Lapin- |
In rec.aviation.student Tina wrote:
Interesting phrase, "pushes down". Why would you think atmospheric pressure pushes down? It was just bad phrasing. I was thinking about how atmospheric pressure is created by gravity pulling the air down. But of course as you imply, the pressure itself pushes in all directions. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Apology re mxsmanic | terry | Piloting | 96 | February 16th 08 05:17 PM |
I saw Mxsmanic on TV | Clear Prop | Piloting | 8 | February 14th 07 01:18 AM |
Mxsmanic | gwengler | Piloting | 30 | January 11th 07 03:42 AM |
Getting rid of MXSMANIC | [email protected] | Piloting | 33 | December 8th 06 11:26 PM |
Feeling aircraft sensations | Ramapriya | Piloting | 17 | January 12th 06 10:15 AM |
