Mxsmanic , IFR sensations, and some other stuff
Old May 22nd 08, 06:40 PM posted to rec.aviation.piloting,rec.aviation.student
Default Mxsmanic , IFR sensations, and some other stuff
On May 22, 8:20 am, Stealth Pilot
On Wed, 21 May 2008 19:56:35 +0200, Mxsmanic
Stealth Pilot writes:
aeroplanes fly because of lift generated by pressure differences on
the wing surfaces.
Airplanes fly because the wings divert the air through which they pass
downwards, creating a downwash and exerting a force in doing so that engenders
an opposite force that is lift.
... these pressure differences are caused by the shape
of the aerofoil of the wing ...
The air is diverted because the wing has a positve angle of attack. It can be
perfectly flat and it will still generate lift.
downwash occurs after the wing has passed. how does it transmit its
effect to the wing? magnetism?
Sorta. The girl lift fairies push from underneath whilst the boy lift
fairies pull from up top. The obese lift fairies just hang on and
thus produce drag.
Old May 22nd 08, 09:31 PM posted to rec.aviation.piloting,rec.aviation.student
More_Flaps
Sorta. *The girl lift fairies push from underneath whilst the boy lift
fairies pull from up top. *The obese lift fairies just hang on and
thus produce drag.
EXACTLY! *GOD, somebody FINALLY nailed it. *The ones that can't hang on
slam into the elevator and produce downwash.
Noooooooooo! It's the beating of the farie wings that makes downwash!
What do you think anables them to keep the wing up. Really, the
knowledge of simple airyfairey dynamics here is abysmal.
Cheers
Old May 22nd 08, 09:22 PM posted to rec.aviation.piloting,rec.aviation.student
More_Flaps
the wing surfaces.
The air is diverted because the wing has a positve angle of attack. *It can be
thus produce drag.- Hide quoted text -
No, there are no fat faries -fat faries would not be able to fly and
they would die. It's transvestite fairies that produce drag,
Cheers
Old May 22nd 08, 10:00 PM posted to rec.aviation.piloting,rec.aviation.student
george
Must be that built in parasite drag :-)
Apology re mxsmanic terry Piloting 96 February 16th 08 05:17 PM
I saw Mxsmanic on TV Clear Prop Piloting 8 February 14th 07 01:18 AM
Mxsmanic gwengler Piloting 30 January 11th 07 03:42 AM
Getting rid of MXSMANIC [email protected] Piloting 33 December 8th 06 11:26 PM
Feeling aircraft sensations Ramapriya Piloting 17 January 12th 06 10:15 AM
