Mxsmanic , IFR sensations, and some other stuff
Old May 23rd 08, 02:16 AM posted to rec.aviation.piloting,rec.aviation.student
Tina
Default Mxsmanic , IFR sensations, and some other stuff
I think you asserted one time or the other you had technical
training. Why then in terms of static fluid pressure would one
specify a direction?
On May 22, 9:06 pm, Le Chaud Lapin wrote:
On May 22, 5:25 pm, Tina wrote:
Interesting phrase, "pushes down". Why would you think atmospheric
pressure pushes down?
At sea level the atmosphere pushes down with about 14.7 pounds of force
for every square inch of exposed surface. On the average man, this works
out to about 43,000 pounds, all the time. Why aren't your crushed by this?
Mike Ash
He probably picked down since down is as good a direction as any,
unless, of course, he was thinking of someone with a big head whose
top surface area measures 4.5 feet x 4.5 feet.
-Le Chaud Lapin-
Old May 23rd 08, 02:38 AM posted to rec.aviation.piloting,rec.aviation.student
Le Chaud Lapin
training. *Why then in terms of static fluid pressure would one
The fluid presses in all direction.
I was merely pointing out the fact that, if he, or the source of the
"43,000" in his post, actually thought that the fluid only presses
downward, then "43,000" would have been a much smaller value.
-Le Chaud Lapin-
Apology re mxsmanic terry Piloting 96 February 16th 08 05:17 PM
I saw Mxsmanic on TV Clear Prop Piloting 8 February 14th 07 01:18 AM
Mxsmanic gwengler Piloting 30 January 11th 07 03:42 AM
Getting rid of MXSMANIC [email protected] Piloting 33 December 8th 06 11:26 PM
Feeling aircraft sensations Ramapriya Piloting 17 January 12th 06 10:15 AM
