![]() "John Scott" wrote in message .. . What type of winch was being used? John Scott It was an ex-Canadian Gerhlein style single drum winch with a Chevy 350 V8 and a GM TH400 series transmission. It's a well maintained example of a 1960's style winch. It's not ideal but cheap enough to get started with winch launch. The ~1500' AGL launches it delivered were just fine for contacting thermals. Had we not been in training mode, I could have thermalled away on almost every launch. The power was just right to allow the glider pilot to control airspeed with pitch inputs but it did exhibit tension oscillations whenever the launch was disturbed by a rough gear change or thermals as is typical with this type of winch. We were able to reduce oscillations by using 2nd gear. 2nd gear also eliminates the tendency for the TH400 to make a 3 - 2 downshift near the top of the launch. A modern tension controlled winch would probably increase the release heights to 2000' AGL by holding rope tension nearly perfect. Bill Daniels |
We don't seem to get 'tension oscillations' using basically similar
winches in the UK! Deliberately launching in second gear sounds like a good way of over-reving the winch engine or running out of available cable speed, unless there is a reasonable headwind. Perhaps Bill should have a word with our gearbox supplier? We just launch in 'Drive' without experiencing any of these problems! We weren't told how long the winch run was, but I note that Bill felt that 1500ft launches were usually high enough for contacting thermals. That also mirrors our finding on this side of the pond. More height is alway welcome though! Derek Copeland At 15:39 23 May 2008, Bill Daniels wrote: "John Scott" wrote in message . .. What type of winch was being used? John Scott It was an ex-Canadian Gerhlein style single drum winch with a Chevy 350 V8 and a GM TH400 series transmission. It's a well maintained example of a 1960's style winch. It's not ideal but cheap enough to get started with winch launch. The ~1500' AGL launches it delivered were just fine for contacting thermals. Had we not been in training mode, I could have thermalled away on almost every launch. The power was just right to allow the glider pilot to control airspeed with pitch inputs but it did exhibit tension oscillations whenever the launch was disturbed by a rough gear change or thermals as is typical with this type of winch. We were able to reduce oscillations by using 2nd gear. 2nd gear also eliminates the tendency for the TH400 to make a 3 - 2 downshift near the top of the launch. A modern tension controlled winch would probably increase the release heights to 2000' AGL by holding rope tension nearly perfect. Bill Daniels |
I have no intention of getting into any exchange with Derek who has a
profoundly biased view of winch launch. There is a substantial body of engineering measurements and expert opinion that contradicts just about everything Derek has to say. Knowledgeable people just ignore him since his prupose is just to start arguments. His favorite winch (Which he serves as the chief cheerleader - probably to the great embarassment of the maker.) exibits huge tension oscillations which have been measured by logging tensionmeters. These oscillations are easily felt and disturbing to all pilots - except Derek who seems somehow unable to notice them. If you want to see tension logs of these oscillations, contact me privately. I can link anybody to videos showing this winch downshifting and breaking winch ropes. I can assure everyone that Frank Whiteley can read an engine tachometer better than just about anybody. There was no overrevving of the Faribault winch, it was simply geared too tall to use 3rd gear. Using second gear also eliminated the surging 3-2 downshift near the top of the launch. Bill Daniels "Derek Copeland" wrote in message ... We don't seem to get 'tension oscillations' using basically similar winches in the UK! Deliberately launching in second gear sounds like a good way of over-reving the winch engine or running out of available cable speed, unless there is a reasonable headwind. Perhaps Bill should have a word with our gearbox supplier? We just launch in 'Drive' without experiencing any of these problems! We weren't told how long the winch run was, but I note that Bill felt that 1500ft launches were usually high enough for contacting thermals. That also mirrors our finding on this side of the pond. More height is alway welcome though! Derek Copeland At 15:39 23 May 2008, Bill Daniels wrote: "John Scott" wrote in message ... What type of winch was being used? John Scott It was an ex-Canadian Gerhlein style single drum winch with a Chevy 350 V8 and a GM TH400 series transmission. It's a well maintained example of a 1960's style winch. It's not ideal but cheap enough to get started with winch launch. The ~1500' AGL launches it delivered were just fine for contacting thermals. Had we not been in training mode, I could have thermalled away on almost every launch. The power was just right to allow the glider pilot to control airspeed with pitch inputs but it did exhibit tension oscillations whenever the launch was disturbed by a rough gear change or thermals as is typical with this type of winch. We were able to reduce oscillations by using 2nd gear. 2nd gear also eliminates the tendency for the TH400 to make a 3 - 2 downshift near the top of the launch. A modern tension controlled winch would probably increase the release heights to 2000' AGL by holding rope tension nearly perfect. Bill Daniels |
I am a senior instructor at a major UK gliding club and regularly take
winch launches on Tost and Skylaunch winches, which both have large capacity GM Marine V8 engines and TH400 changing 3 speed automatic gearboxes. To me, and everyone else who launches on them, they give smooth and safe launches. The Skylaunch is the preferable design as it is much more modern and fitted with a semi-automatic form of launch control. The Tost is purely manually controlled. Please see the following videos as examples of this: The one winch launch failure was simulated by the gliding instructor as a training exercise BTW: http://www.youtube.com/watch?v=FCQTkCFqLjc (Tost) http://www.youtube.com/watch?v=F2SD7USG1n4 (Tost and Skylaunch) http://www.youtube.com/watch?v=HNcEtvcnnGc (Skylaunch) Derek Copeland At 16:21 24 May 2008, Bill Daniels wrote: I have no intention of getting into any exchange with Derek who has a profoundly biased view of winch launch. There is a substantial body of engineering measurements and expert opinion that contradicts just about everything Derek has to say. Knowledgeable people just ignore him since his prupose is just to start arguments. His favorite winch (Which he serves as the chief cheerleader - probably to the great embarassment of the maker.) exibits huge tension oscillations which have been measured by logging tensionmeters. These oscillations are easily felt and disturbing to all pilots - except Derek who seems somehow unable to notice them. If you want to see tension logs of these oscillations, contact me privately. I can link anybody to videos showing this winch downshifting and breaking winch ropes. I can assure everyone that Frank Whiteley can read an engine tachometer better than just about anybody. There was no overrevving of the Faribault winch, it was simply geared too tall to use 3rd gear. Using second gear also eliminated the surging 3-2 downshift near the top of the launch. Bill Daniels "Derek Copeland" wrote in message ... We don't seem to get 'tension oscillations' using basically similar winches in the UK! Deliberately launching in second gear sounds like a good way of over-reving the winch engine or running out of available cable speed, unless there is a reasonable headwind. Perhaps Bill should have a word with our gearbox supplier? We just launch in 'Drive' without experiencing any of these problems! We weren't told how long the winch run was, but I note that Bill felt that 1500ft launches were usually high enough for contacting thermals. That also mirrors our finding on this side of the pond. More height is alway welcome though! Derek Copeland |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Clinic Southern Nevada November 11 and 12 | [email protected] | Soaring | 0 | October 31st 06 02:26 AM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Avenal auto-tow ground launch clinic March 6-7 | Mark James Boyd | Soaring | 0 | January 30th 04 08:41 PM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
