On May 23, 1:27 pm, Darryl Ramm wrote:
On May 23, 1:00 pm, Olin wrote: We have a G103 with an esa-systems multi function probe. The probe serves as a static, pitot and total energy ports. The socket that it plugs into is mounted in the vertical stabilizer and Three tubes run forward to service flight instruments. The socket contains three o- rings to keep the three ports separated when the probe is inserted. These o-rings deteriorate over time of course and allow leakage between the ports and erroneous instrument readings. Two of the o-rings are easily replaceable from the front opening. The third o-ring is small (~1/8" ID) and not so easily replaced as it is deep in the socket. Wings & Wheels has a nice diagram of the socket (type UN). It almost looks to me like you have to dig into the vertical stab and remove the socket and disassemble it to remove this o-ring, unless there is a special tool or method to get it out. Any ideas? Perhaps some of you have traveled this road before. Thanks. You have it correct, you cut out the tripple probe mount to do this. Good huh? Obviously try to confirm this is really the problem before doing all this work (i.e. a leakdown test between the rear most and middle ports. I always put a tape over the probe port when not in use to keep dust out. Club ships etc. tied out are often best left with the probles left in them to avoid wear and tear on the O-rings (others may disagree). The annual was just done on my glider - including cleaning the mount and lubricating the o-rings with a very small amount of silicone (make sure this is being done to your glider, more frequently if the probe is inserted/removed a lot). Darryl And I forgot - Tim at Wings and Wheels normally has the ESA o-ring kits which may be less hassle than trying to source elsewhere. Darryl |
Grob gelcoat | Gary Emerson | Soaring | 1 | December 19th 07 05:55 AM |
Grob | Bob O'Rilley | Soaring | 3 | April 29th 05 07:22 PM |
Grob 103 SL | R.W. Carpenter | Soaring | 2 | March 21st 04 10:21 PM |
WTB Grob 109 b | Steve B | Soaring | 10 | July 21st 03 06:54 PM |
GROB 102 | Vorsanger1 | Soaring | 4 | July 11th 03 11:34 PM |
