On May 27, 6:18*am, Ed Rasimus wrote:
On Mon, 26 May 2008 19:37:55 -0700 (PDT), WaltBJ wrote: SNIP a ton: * The two fastest 'rollers' Iknow of are the F104 Starfighter and the F5 series. The 104 clocks out at about 420 degrees per second - note the Flight Manual limitation is 360 degrees of roll - if below 1/2 G, 180 degrees. This is to stay out of inertial coupling, which is a really good idea.. The F5 series is credited with 450 degrees per second. I have never flown a T38 or an F5. so can't speak to that. I logged time in the T-38 in pilot training and flying some FCF profiles afterward during my years as a UPT instructor, then four years doing instructor training in Fighter Lead-In flying the AT-38B. The T-38 roll-rate is listed at 720 degrees per second. The stick throw is 6" either side of center, with the first 4.5" giving you 50% of aileron deflection and the last 1.5" giving you the full deflection for max rate rolls. Dash-1 restriction is against continuous full deflection rolls with a warning that it is difficult to stop full deflection in less than two rolls. The FCF profile involves rolls left and right with first half-rate and then a full-deflection in each direction. It will make your head spin and if you are not braced, bounce your helmet off the canopy. It has virtually NO tactical utility. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" "Palace Cobra"www.thunderchief.org A spiral or corkscrew as a maneuver allows an escape. You need elevator deflection, while entering the simple aileron roll, as a rule to cause the high angle of attack necessary to slow the aircraft and corkscrew breakoff to the anywhere direction. High angle of attack roll rate is critical to either following the target or breaking off. Matching the target is advised and it is as follows. 1. elevator deflect and roll positive g. 2. As 180 degree roll is passed a person needs to do a single elevator motion. And if you get it wrong the maneuver turns into a dive. 3. SO push on the elevator to mAKE THE FORWARD CORCKSCREW POSSIBLE. So it is a hard thing to get the hang of and it has negative gs. A special modification was to aerodynamics. What can be changed. A dive as arule is always sort of expected. SO a vertical exit from the corkscrew appear the false exit. A fake exit is possible aerodynamically. A simple vertical followed by a return to the corkscrew really making it impossible to follow. ALWAYS lossing the trailing aircraft. |
![]() "Douglas Eagleson" wrote in message ... On May 27, 6:18 am, Ed Rasimus wrote: On Mon, 26 May 2008 19:37:55 -0700 (PDT), WaltBJ The T-38 roll-rate is listed at 720 degrees per second. The stick throw is 6" either side of center, with the first 4.5" giving you 50% of aileron deflection and the last 1.5" giving you the full deflection for max rate rolls. Dash-1 restriction is against continuous full deflection rolls with a warning that it is difficult to stop full deflection in less than two rolls. The FCF profile involves rolls left and right with first half-rate and then a full-deflection in each direction. It will make your head spin and if you are not braced, bounce your helmet off the canopy. It has virtually NO tactical utility. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" "Palace Cobra"www.thunderchief.org A spiral or corkscrew as a maneuver allows an escape. You need elevator deflection, while entering the simple aileron roll, as a rule to cause the high angle of attack necessary to slow the aircraft and corkscrew breakoff to the anywhere direction. Oh great a janitor advising a fighter pilot on air combat tactics Sheesh Keith |
Keith Willshaw wrote:
"Douglas Eagleson" wrote in message ... On May 27, 6:18 am, Ed Rasimus wrote: On Mon, 26 May 2008 19:37:55 -0700 (PDT), WaltBJ The T-38 roll-rate is listed at 720 degrees per second. The stick throw is 6" either side of center, with the first 4.5" giving you 50% of aileron deflection and the last 1.5" giving you the full deflection for max rate rolls. Dash-1 restriction is against continuous full deflection rolls with a warning that it is difficult to stop full deflection in less than two rolls. The FCF profile involves rolls left and right with first half-rate and then a full-deflection in each direction. It will make your head spin and if you are not braced, bounce your helmet off the canopy. It has virtually NO tactical utility. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" "Palace Cobra"www.thunderchief.org A spiral or corkscrew as a maneuver allows an escape. You need elevator deflection, while entering the simple aileron roll, as a rule to cause the high angle of attack necessary to slow the aircraft and corkscrew breakoff to the anywhere direction. Oh great a janitor advising a fighter pilot on air combat tactics Sheesh Keith Maybe he can mop up all enemy resistance. Dan, U.S. Air Force, retired |
Dan wrote:
Keith Willshaw wrote: "Douglas Eagleson" wrote in message ... On May 27, 6:18 am, Ed Rasimus wrote: On Mon, 26 May 2008 19:37:55 -0700 (PDT), WaltBJ The T-38 roll-rate is listed at 720 degrees per second. The stick throw is 6" either side of center, with the first 4.5" giving you 50% of aileron deflection and the last 1.5" giving you the full deflection for max rate rolls. Dash-1 restriction is against continuous full deflection rolls with a warning that it is difficult to stop full deflection in less than two rolls. The FCF profile involves rolls left and right with first half-rate and then a full-deflection in each direction. It will make your head spin and if you are not braced, bounce your helmet off the canopy. It has virtually NO tactical utility. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" "Palace Cobra"www.thunderchief.org A spiral or corkscrew as a maneuver allows an escape. You need elevator deflection, while entering the simple aileron roll, as a rule to cause the high angle of attack necessary to slow the aircraft and corkscrew breakoff to the anywhere direction. Oh great a janitor advising a fighter pilot on air combat tactics Sheesh Keith Maybe he can mop up all enemy resistance. Dan, U.S. Air Force, retired Maybe he's really thinking of a fighter "sweep"? |
Dean A. Markley wrote:
Dan wrote: Maybe he can mop up all enemy resistance. Dan, U.S. Air Force, retired Maybe he's really thinking of a fighter "sweep"? Hmmmm, how long before someone pans that ? -- Cheers Dave Kearton |
"Dave Kearton" wrote...
Maybe he can mop up all enemy resistance. Maybe he's really thinking of a fighter "sweep"? Hmmmm, how long before someone pans that ? Pan Pan! Imminent pun failure! |
JR Weiss wrote:
"Dave Kearton" wrote... Maybe he can mop up all enemy resistance. Maybe he's really thinking of a fighter "sweep"? Hmmmm, how long before someone pans that ? Pan Pan! Imminent pun failure! It's too fine a May day for such things. Dan, U.S. Air Force, retired |
On May 27, 10:53 am, Douglas Eagleson
wrote: On May 27, 6:18 am, Ed Rasimus wrote: On Mon, 26 May 2008 19:37:55 -0700 (PDT), WaltBJ wrote: SNIP a ton: The two fastest 'rollers' Iknow of are the F104 Starfighter and the F5 series. The 104 clocks out at about 420 degrees per second - note the Flight Manual limitation is 360 degrees of roll - if below 1/2 G, 180 degrees. This is to stay out of inertial coupling, which is a really good idea.. The F5 series is credited with 450 degrees per second. I have never flown a T38 or an F5. so can't speak to that. I logged time in the T-38 in pilot training and flying some FCF profiles afterward during my years as a UPT instructor, then four years doing instructor training in Fighter Lead-In flying the AT-38B. The T-38 roll-rate is listed at 720 degrees per second. The stick throw is 6" either side of center, with the first 4.5" giving you 50% of aileron deflection and the last 1.5" giving you the full deflection for max rate rolls. Dash-1 restriction is against continuous full deflection rolls with a warning that it is difficult to stop full deflection in less than two rolls. The FCF profile involves rolls left and right with first half-rate and then a full-deflection in each direction. It will make your head spin and if you are not braced, bounce your helmet off the canopy. It has virtually NO tactical utility. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" "Palace Cobra"www.thunderchief.org A spiral or corkscrew as a maneuver allows an escape. You need elevator deflection, while entering the simple aileron roll, as a rule to cause the high angle of attack necessary to slow the aircraft and corkscrew breakoff to the anywhere direction. What? Read what Walt and Ed wrote. Do consider "inertial coupling". If I understand correctly, doing a serious elevator input while speed rolling will "corkscrew" you into the nearest mud. Anyway release wing tip tanks before execution. High angle of attack roll rate is critical to either following the target or breaking off. Matching the target is advised and it is as follows. 1. elevator deflect and roll positive g. 2. As 180 degree roll is passed a person needs to do a single elevator motion. And if you get it wrong the maneuver turns into a dive. 3. SO push on the elevator to mAKE THE FORWARD CORCKSCREW POSSIBLE. So it is a hard thing to get the hang of and it has negative gs. A special modification was to aerodynamics. What can be changed. A dive as arule is always sort of expected. SO a vertical exit from the corkscrew appear the false exit. A fake exit is possible aerodynamically. A simple vertical followed by a return to the corkscrew really making it impossible to follow. ALWAYS lossing the trailing aircraft. WOWser. What trailing aircraft do you have in mind? vs. F104 or F5, perhaps a Mig21? Doug, I'd like to seriously complete your scenario. Regards Ken |
Douglas Eagleson wrote:
The FCF profile involves rolls left and right with first half-rate and then a full-deflection in each direction. It will make your head spin and if you are not braced, bounce your helmet off the canopy. Nice to know. It has virtually NO tactical utility. Tell that to the F-86 pilots. Dan |
(actually, Ed Rasimus wrote ![]() The FCF profile involves rolls left and right with first half-rate and then a full-deflection in each direction. It will make your head spin and if you are not braced, bounce your helmet off the canopy. Dan wrote: Nice to know. It has virtually NO tactical utility. Tell that to the F-86 pilots. Please keep track of your attributions, Dan, or someone might get the mistaken impression that the Eaglesonbot actually wrote a lucid sentence. Three of 'em, actually. Jeff |
LETS BUILD A MODEL PLANE | adelsonsl | Aviation Photos | 1 | May 16th 07 11:10 PM |
Swedish! | Owning | 3 | March 3rd 06 12:44 AM | |
The end of the Saab Viggen - The legendary Swedish jet fighter | Iwan Bogels | Simulators | 0 | April 19th 05 07:22 PM |
The Very Last Operational New German Fighter Model Of WW2 | Garrison Hilliard | Military Aviation | 13 | January 13th 04 03:31 PM |
RV Quick Build build times... | [email protected] | Home Built | 2 | December 17th 03 03:29 AM |
