On May 23, 8:44 pm, Nick Kennedy wrote:
Does anyone out there know how to get the water ballast tanks caps off/open to fill? They have a 1/8 inch hole in them to spin the around, but several us have tried to get them off/open but no luck.. TIA Nick Kennedy If it's the same cap as a single Astir, which I have. I use a L shaped piece of coat hanger wire to lift the cap out. I then tape the plug down, making sure that the hole is not covered. If it's the same system as the G102, then there is no valve in the wing and there is a pipe in the wing that fits into the fuselage (with a Volkswagen shaft seal) and a dump valve in the fuselage. This means that the water will cross fill between wings and you have to keep them level before launch. Todd Smith |
| Thread Tools | |
| Display Modes | |
| Antifreeze that is safe with integral water ballast tanks | Tim Taylor | Soaring | 7 | October 14th 07 06:15 AM |
| Who first used water ballast and when? | John McCullagh | Soaring | 9 | October 18th 06 10:36 AM |
| water ballast leak | Robert Harvey | Soaring | 2 | May 27th 05 04:49 PM |
| Std 102 water ballast plug | Tom Dukerich | Soaring | 3 | April 12th 05 06:10 PM |
| astir cs-77 water ballast | pete83 | Soaring | 4 | May 27th 04 06:21 AM |
