I recall being taught to announce a position when overflying an
airport (assuming you aren't overflying by some ridiculous amount). I announce when overflying to have a look-see before joining the pattern. Someone else might be doing the same thing. Sure, if you're over-flying an airport that you're landing at, announcing is proper procedure. But if you're flying cross-country, it's kinda silly to announce that you're over-flying every airport en route... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" wrote in message ... On May 28, 10:22 am, Dale wrote: In article GYe%j.183758$yE1.50750@attbi_s21, "Jay Honeck" wrote: I really like are the guys who announce that they're "over-flying the field at 4500 feet, heading West..." Is that really so bad? Quite common to use an airport as a waypoint, by making the announcement it may let the other guy at 4500 overflying know to put the paper down. In Canada that kind of report is required if there is a Mandatory Freq. I recall being taught to announce a position when overflying an airport (assuming you aren't overflying by some ridiculous amount). I announce when overflying to have a look-see before joining the pattern. Someone else might be doing the same thing. |
"Jay Honeck" wrote:
Sure, if you're over-flying an airport that you're landing at, announcing is proper procedure. But if you're flying cross-country, it's kinda silly to announce that you're over-flying every airport en route... Depends, IMO. We have several uncontrolled fields in this area. If I'm in the pattern and someone is overflying 500 feet-or-so above (I realize if you're on a x-c, you'd likely be higher, but maybe not), I find it helpful to know if they're going to join the pattern or if they're overflying and continuing on. I prefer the call to not knowing. I heard someone talking about how it isn't necessary to make a call coming into an uncontrolled airport "if it isn't busy". So if 6 people are coming in thinking it isn't busy because it's quiet (there goes that idea!). I absolutely understand not making unnecessary radio calls, but why are some *so* opposed to making a call? |
Shirl wrote:
"Jay Honeck" wrote: Sure, if you're over-flying an airport that you're landing at, announcing is proper procedure. But if you're flying cross-country, it's kinda silly to announce that you're over-flying every airport en route... Depends, IMO. We have several uncontrolled fields in this area. If I'm in the pattern and someone is overflying 500 feet-or-so above (I realize if you're on a x-c, you'd likely be higher, but maybe not), I find it helpful to know if they're going to join the pattern or if they're overflying and continuing on. I prefer the call to not knowing. I heard someone talking about how it isn't necessary to make a call coming into an uncontrolled airport "if it isn't busy". So if 6 people are coming in thinking it isn't busy because it's quiet (there goes that idea!). I absolutely understand not making unnecessary radio calls, but why are some *so* opposed to making a call? The way I taught this was to consider the altitude and use common sense. If crossing high enough that you are well out of the transition area where someone coming out of or descending into an uncontrolled airport would be, no need to say anything. If however, you were crossing en route above the pattern altitude but inside the area right above that....say to within a thousand feet above, where aircraft entering or leaving the area might be present, it's a good idea to let the airport know who you are where you are and where you're headed. -- Dudley Henriques |
On Thu, 29 May 2008 09:52:44 -0400, Dudley Henriques
wrote in : If crossing high enough that you are well out of the transition area where someone coming out of or descending into an uncontrolled airport would be, no need to say anything. If however, you were crossing en route above the pattern altitude but inside the area right above that....say to within a thousand feet above, where aircraft entering or leaving the area might be present, it's a good idea to let the airport know who you are where you are and where you're headed. The Advisory Circular mentions notifying UNICOM stations of over flight of uncontrolled fields, but I find no mention of self-announcing over flight intention on CTAF: AC No: 9042F http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/c54e50252a7fa56d862569d8007804ba/$FILE/ac90-42F.pdf 10 . UNICOM COMMUNICATION PROCEDURES. a. In communicating with a UNICOM station, the flowing practices will help reduce frequency congestion, facilitate a better understanding of pilot intentions, help identify the location of aircraft in. the traffic pattern, and enhance safety of flight: (1) Select the correct CTAF frequency. (2) State the identification of the UNICOM station you are calling in each transmission. (3) Speak slowly and distinctly. (4) Notify the UNICOM station approximately 10 miles from the airport, reporting altitude, aircraft type, aircraft identification, location relative to the airport, and whether -- landing or overflight. Request wind information and runway in use. (5) Report on downwind, base, and final approach. (6) Report leaving the runway. The AIM also mentions notifying UNICOM stations of over flight intent, and while stating intentions on CTAF is mentioned in 4-1-9(g)(1), I find no mention of broadcasting over flight intent on CTAF: http://www.faa.gov/airports_airtraff...4/aim0401.html 4-1-9. Traffic Advisory Practices at Airports Without Operating Control Towers g. Self-Announce Position and/or Intentions 1. General. Self-announce is a procedure whereby pilots broadcast their position or intended flight activity or ground operation on the designated CTAF. This procedure is used primarily at airports which do not have an FSS on the airport. The self-announce procedure should also be used if a pilot is unable to communicate with the FSS on the designated CTAF. Pilots stating, "Traffic in the area, please advise" is not a recognized Self-Announce Position and/or Intention phrase and should not be used under any condition. So, announcing intent to over fly an airport on CTAF is a bit ambiguous. As you have indicated, if it seems prudent, do it. |
Larry Dighera wrote:
The Advisory Circular mentions notifying UNICOM stations of over flight of uncontrolled fields, but I find no mention of self-announcing over flight intention on CTAF: AC No: 9042F http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/c54e50252a7fa56d862569d8007804ba/$FILE/ac90-42F.pdf 10 . UNICOM COMMUNICATION PROCEDURES. a. In communicating with a UNICOM station, the flowing practices will help reduce frequency congestion, facilitate a better understanding of pilot intentions, help identify the location of aircraft in. the traffic pattern, and enhance safety of flight: -- (1) Select the correct CTAF frequency. -- (2) State the identification of the UNICOM station you are calling in each transmission. (3) Speak slowly and distinctly. (4) Notify the UNICOM station approximately 10 miles from the airport, reporting altitude, aircraft type, aircraft identification, location relative to the airport, and whether -- landing or overflight. Request wind information and runway in use. (5) Report on downwind, base, and final approach. (6) Report leaving the runway. What do you mean? It's mentioned in the step 1 of what you posted. |
On Thu, 29 May 2008 10:21:17 -0500, Gig 601Xl Builder
wrote in : Larry Dighera wrote: The Advisory Circular mentions notifying UNICOM stations of over flight of uncontrolled fields, but I find no mention of self-announcing over flight intention on CTAF: AC No: 9042F http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/c54e50252a7fa56d862569d8007804ba/$FILE/ac90-42F.pdf 10 . UNICOM COMMUNICATION PROCEDURES. a. In communicating with a UNICOM station, the flowing practices will help reduce frequency congestion, facilitate a better understanding of pilot intentions, help identify the location of aircraft in. the traffic pattern, and enhance safety of flight: -- (1) Select the correct CTAF frequency. -- (2) State the identification of the UNICOM station you are calling in each transmission. (3) Speak slowly and distinctly. (4) Notify the UNICOM station approximately 10 miles from the airport, reporting altitude, aircraft type, aircraft identification, location relative to the airport, and whether -- landing or overflight. Request wind information and runway in use. (5) Report on downwind, base, and final approach. (6) Report leaving the runway. What do you mean? It's mentioned in the step 1 of what you posted. Indeed. I overlooked that. I guess I didn't expect to see CTAF mentioned under UNICOM. The AIM hast this definition of UNICOM stations: e. Information Provided by Aeronautical Advisory Stations (UNICOM) 1. UNICOM is a nongovernment air/ground radio communication station which may provide airport information at public use airports where there is no tower or FSS. And the Pilot/Controller Glossary provides this definition of CTAF: http://www.faa.gov/airports_airtraff...pubs/PCG/C.HTM COMMON TRAFFIC ADVISORY FREQUENCY (CTAF)- A frequency designed for the purpose of carrying out airport advisory practices while operating to or from an airport without an operating control tower. The CTAF may be a UNICOM, Multicom, FSS, or tower frequency and is identified in appropriate aeronautical publications. (Refer to AC 90-42, Traffic Advisory Practices at Airports Without Operating Control Towers.) (neither CTAF nor UNICOM are mentioned in Part 1 definitions) So while the CTAF _frequency_ may be a UNICOM frequency also, I always considered UNICOM stations to be manned, while I apparently erroneously considered radio operation on CTAF frequencies to be limited to one-way self-announced position and intention broadcasts. Obviously CTAF is only so limited when there is neither an operating UNICOM nor FSS station at the field. Despite my confusion over the nomenclature, these documents seem to be the sole guidance concerning announcing overflight intentions provided by FAA. Neither CTAF nor UNICOM are mentioned in Part 91. |
On Thu, 29 May 2008 10:21:17 -0500, Gig 601Xl Builder wrote in : Larry Dighera wrote: The Advisory Circular mentions notifying UNICOM stations of over flight of uncontrolled fields, but I find no mention of self-announcing over flight intention on CTAF: AC No: 9042F http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/c54e50252a7fa56d862569d8007804ba/$FILE/ac90-42F.pdf 10 . UNICOM COMMUNICATION PROCEDURES. a. In communicating with a UNICOM station, the flowing practices will help reduce frequency congestion, facilitate a better understanding of pilot intentions, help identify the location of aircraft in. the traffic pattern, and enhance safety of flight: -- (1) Select the correct CTAF frequency. -- (2) State the identification of the UNICOM station you are calling in each transmission. (3) Speak slowly and distinctly. (4) Notify the UNICOM station approximately 10 miles from the airport, reporting altitude, aircraft type, aircraft identification, location relative to the airport, and whether -- landing or overflight. Request wind information and runway in use. (5) Report on downwind, base, and final approach. (6) Report leaving the runway. What do you mean? It's mentioned in the step 1 of what you posted. Indeed. I overlooked that. I guess I didn't expect to see CTAF mentioned under UNICOM. The AIM hast this definition of UNICOM stations: e. Information Provided by Aeronautical Advisory Stations (UNICOM) 1. UNICOM is a nongovernment air/ground radio communication station which may provide airport information at public use airports where there is no tower or FSS. And the Pilot/Controller Glossary provides this definition of CTAF: http://www.faa.gov/airports_airtraff...pubs/PCG/C.HTM COMMON TRAFFIC ADVISORY FREQUENCY (CTAF)- A frequency designed for the purpose of carrying out airport advisory practices while operating to or from an airport without an operating control tower. The CTAF may be a UNICOM, Multicom, FSS, or tower frequency and is identified in appropriate aeronautical publications. (Refer to AC 90-42, Traffic Advisory Practices at Airports Without Operating Control Towers.) (neither CTAF nor UNICOM are mentioned in Part 1 definitions) So while the CTAF _frequency_ may be a UNICOM frequency also, I always considered UNICOM stations to be manned, while I apparently erroneously considered radio operation on CTAF frequencies to be limited to one-way self-announced position and intention broadcasts. Obviously CTAF is only so limited when there is neither an operating UNICOM nor FSS station at the field. Despite my confusion over the nomenclature, these documents seem to be the sole guidance concerning announcing overflight intentions provided by FAA. Neither CTAF nor UNICOM are mentioned in Part 91. I did some Googleing of CTAF/UNICOM on Arinav and there are 6100 hits for that exact phrase. I've not flown to a huge number of airports in my career of flying but most of them have been uncontrolled fields and I can't remember a single one since the first big reduction of FSS that didn't use the Unicom as the CTAF. |
On May 29, 8:06 am, Larry Dighera wrote:
On Thu, 29 May 2008 09:52:44 -0400, Dudley Henriques wrote in : If crossing high enough that you are well out of the transition area where someone coming out of or descending into an uncontrolled airport would be, no need to say anything. If however, you were crossing en route above the pattern altitude but inside the area right above that....say to within a thousand feet above, where aircraft entering or leaving the area might be present, it's a good idea to let the airport know who you are where you are and where you're headed. The Advisory Circular mentions notifying UNICOM stations of over flight of uncontrolled fields, but I find no mention of self-announcing over flight intention on CTAF: AC No: 9042F http://www.airweb.faa.gov/Regulatory...ry/rgAdvisoryC... 10 . UNICOM COMMUNICATION PROCEDURES. a. In communicating with a UNICOM station, the flowing practices will help reduce frequency congestion, facilitate a better understanding of pilot intentions, help identify the location of aircraft in. the traffic pattern, and enhance safety of flight: (1) Select the correct CTAF frequency. (2) State the identification of the UNICOM station you are calling in each transmission. (3) Speak slowly and distinctly. (4) Notify the UNICOM station approximately 10 miles from the airport, reporting altitude, aircraft type, aircraft identification, location relative to the airport, and whether -- landing or overflight. Request wind information and runway in use. (5) Report on downwind, base, and final approach. (6) Report leaving the runway. The AIM also mentions notifying UNICOM stations of over flight intent, and while stating intentions on CTAF is mentioned in 4-1-9(g)(1), I find no mention of broadcasting over flight intent on CTAF: http://www.faa.gov/airports_airtraff...ications/atpub... 4-1-9. Traffic Advisory Practices at Airports Without Operating Control Towers g. Self-Announce Position and/or Intentions 1. General. Self-announce is a procedure whereby pilots broadcast their position or intended flight activity or ground operation on the designated CTAF. This procedure is used primarily at airports which do not have an FSS on the airport. The self-announce procedure should also be used if a pilot is unable to communicate with the FSS on the designated CTAF. Pilots stating, "Traffic in the area, please advise" is not a recognized Self-Announce Position and/or Intention phrase and should not be used under any condition. So, announcing intent to over fly an airport on CTAF is a bit ambiguous. As you have indicated, if it seems prudent, do it. Where we flew we used ettiquette. Example: We're approaching an airport and at 5 miles, we'd radio tower "Yankee Yankee Golf approaching from the XXX, intends to enter the circuit. I'd hear, "Roger, your clear". Next I'd key radio just before doing my 30 degree bank to get into the down-wind, so the controller can get an easy visual of me, "YYG turning onto downwind". Same for every other turn, to final. Radio work is 1st for the controller, and secondly for other a/c, he's the boss. Ken |
"Ken S. Tucker" wrote in
: I'd hear, "Roger, your clear". I'm sure you did. You can even hear grammatically correct. Next I'd key radio just before doing my 30 degree bank to get into the down-wind, so the controller can get an easy visual of me, "YYG turning onto downwind". Same for every other turn, to final. Radio work is 1st for the controller, and secondly for other a/c, he's the boss. No, he isn't fjukktard. Bertie |
US Navy Test Pilot School F/A-18 turning onto final approach at KNPA today | Tom Callahan | Aviation Photos | 0 | November 2nd 07 09:45 PM |
US Navy Test Pilot School F/A-18 turning onto final approach at KNPA today | Tom Callahan | Aviation Photos | 0 | November 2nd 07 09:44 PM |
US Navy Test Pilot School F/A-18 on final approach at KNPA today | Tom Callahan | Aviation Photos | 0 | November 2nd 07 09:44 PM |
Sport Pilot Final | Gilan | Home Built | 34 | August 13th 04 03:20 PM |
Sport Pilot Final | Gilan | Piloting | 19 | July 22nd 04 04:38 PM |
