#21
![]() "Gezellig" wrote in message ... On Thu, 29 May 2008 07:21:20 -0700, gatt wrote: One of the folks around the hangar took his CFI practical last week. He had his AGI so they threw out all of the Fundamentals of Instruction stuff entirely during the oral. A question the examiner asked him: "You're flying cross-country and trimmed at 110 knots. You die, and the engine quits. At what airspeed will the aircraft strike the ground? That's easy, gatt. I wouldn't know. Or care. That summs it upp.... |
![]() "Dudley Henriques" wrote in message ... gatt wrote: A question the examiner asked him: "You're flying cross-country and trimmed at 110 knots. You die, and the engine quits. At what airspeed will the aircraft strike the ground?" Another was, "You're turning final and you enter a cross-control stall. Is it better to be in a slip, or a skid?" -c These are reasonable questions. The aircraft would attempt to regain and maintain the trim speed as it descends. Whether or not it had the time to do that before ground impact however would be dependent on the altitude remaining, so depending on the altitude, the airspeed at impact might be short of the trim speed. (This type of question is typical of FAA orals. They're looking for the trim speed answer while completely neglecting the time and altitude factors which to be accurate would have to be in the answer equation. My advice to the person taking the oral would be to give the trim speed answer, get the certificate, put it deep in the wallet and in your pocket, then politely suggest to the fuzz that the altitude should be included in the answer if not in the question itself :-) A slipped cross control stall as relates to spin entry is FAR less pro-spin than a skid entry. -- Dudley Henriques Also need to look at coprs position are you slumped over and placign fwd control pressure on the yoke? is the auto pilot on? lots of questions.... |
![]() "Robert M. Gary" wrote in message ... On May 29, 7:21 am, gatt wrote: One of the folks around the hangar took his CFI practical last week. He had his AGI so they threw out all of the Fundamentals of Instruction stuff entirely during the oral. Huh, that's not right. There is nothing in the PTS that says you get to skip the FOI stuff just because you have an AGI. The only thing you get to skip is showing your FOI exam results. I had my AGI and probably spent 5 hours of my CFI oral on FOI stuff. -Robert, CFII, AGI FOI is my hangup right now.... |
On 2008-05-29, Vaughn Simon wrote:
Those of you who have never broken the monotony of a x-country by exploring the phugoid characteristics of your steed have missed a good opportunity to learn something about your airplane. (Don't forget to see how it differs with CG.) BTW: Some gliders have rather exciting phugoids. Oh? Please enlighten me, since I'm going to ahve a sterling opportunity to do so in the not very distant future. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (FRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 10 June) |
In rec.aviation.student gatt wrote:
A question the examiner asked him: "You're flying cross-country and trimmed at 110 knots. You die, and the engine quits. At what airspeed will the aircraft strike the ground?" In addition to all the other factors discussed, your airspeed will be slightly lower than what you had trimmed due to the weight of your soul departing the aircraft. OK, so I don't really believe that, but I'd love to see what the guy would say if you told him that answer! -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Dudley Henriques presented the following explanation :
A slipped cross control stall as relates to spin entry is FAR less pro-spin than a skid entry. Dudley, I don't understand why that is? Are you assuming 110 nauts? |
Jim formulated on Thursday :
A question the examiner asked him: "You're flying cross-country and trimmed at 110 knots. You die, and the engine quits. At what airspeed will the aircraft strike the ground?" Another was, "You're turning final and you enter a cross-control stall. Is it better to be in a slip, or a skid?" -c Wow. I'm glad I have not been asked the first question. I think I would have given an answer different from that given by the more experienced folks here. On the chance the plane went into a spiral dive, which I understand can happen, I would have thought the plane would attempt to maintain its trim AOA, but not its trim airspeed. I would likely have said the plane would strike the ground -- if it had the necessary altitude, as others have pointed out -- at approximately its trim AOA but at an airspeed that might be a lot higher than its trim airspeed -- if the wings did not come off before that. Jim Thanks, Jim, I am comforted with the fact that we share a common dumminess here. lol |
#28
Gezellig wrote:
Dudley Henriques presented the following explanation : A slipped cross control stall as relates to spin entry is FAR less pro-spin than a skid entry. Dudley, I don't understand why that is? Are you assuming 110 nauts? Not sure what you're asking as the 110 kts is connected to the other question, not the cross controlled stall question as referenced above, but taking a guess......if you check question number one about dying at the controls, the trim speed given was 110 kts. :-) -- Dudley Henriques |
#29
Jim Stewart presented the following explanation :
gatt wrote: One of the folks around the hangar took his CFI practical last week. He had his AGI so they threw out all of the Fundamentals of Instruction stuff entirely during the oral. A question the examiner asked him: "You're flying cross-country and trimmed at 110 knots. You die, and the engine quits. At what airspeed will the aircraft strike the ground?" Another was, "You're turning final and you enter a cross-control stall. Is it better to be in a slip, or a skid?" I'm wondering what the significance of posting this question is. Is it because everyone should know the answer or because on some level it is nonsensical? Can't speak for gatt but the I take it for both. There are nonsensical questions that need to be prepaered for after all its about passing a test to get to the real learning. |
#30
Jim Stewart wrote:
Another was, "You're turning final and you enter a cross-control stall. Is it better to be in a slip, or a skid?" I'm wondering what the significance of posting this question is. They're aviation forums. Some people still actually like to discuss aviation out here. I didn't mean to come off as a smart-ass. As I said, my instructor and I covered this well before I soloed. I assumed that every soloed student would know the answer, let alone a CFI candidate. I guess I was wrong. I don't remember ever talking about this with my instructor. I seem to have known the answer; just can't say where I got the information any more. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
U.S. Navy Plans EPX Intel-Gathering Aircraft | [email protected] | Naval Aviation | 0 | February 23rd 08 02:38 AM |
FOI...lol... CFI oral? | gatt[_2_] | Piloting | 29 | January 5th 08 05:01 PM |
Q: Apple MAC Book (pro) with Intel core 2 duo running Windows XP plus soaring software | Ruud | Soaring | 1 | October 31st 06 01:02 AM |
INTEL BILL CON JOB | Cribsheet | Piloting | 0 | December 7th 04 05:40 PM |
