On May 30, 3:01 am, Larry Dighera wrote:
On Thu, 29 May 2008 23:27:49 -0700, C J Campbell wrote in 2008052923274916807-christophercampbell@hotmailcom: On 2008-05-29 12:39:04 -0700, Scott Skylane said: C J Campbell wrote: Personally, I have better things to do than to worry about what other pilots are saying on the radio. Respectfully, CJ, That attitude may well get you killed, and would certainly get you booted out of my cockpit. Happy Flying! Scott Skylane Respectfully, obsessing about whether another pilot is misusing the radio, as Larry does, is far more likely to get you killed and certainly would get you booted out of *my* cockpit. My statement was that I limit my CTAF transmissions to announcing my position and intentions. Please provide the rationale that leads you to believe that that equates to "obsessing about whether another pilot is misusing the radio." You know, I listen to what other pilots have to say on the radio. I simply do not have time to criticize what they say or grade them on their performance. Guys like Larry are one reason that student pilots are afraid of using the radio. They are terrified of offending some radio nanny who is going to stomp all over them for saying "please advise," a phrase that they may hear all the time from professional pilots. Because I stated that I limit my CTAF transmissions to announcing my position and intentions, I would like to know how you managed to infer that I might "stomp all over them." Your conclusion makes no sense to me, and reflects you lack of logic in teaching your students to disregard regulations. I have heard a pilot ream a student over the air on the tower frequency for a solid ten minutes because he thought the student was stumbling on his transmissions too much. How is that for misusing the radio? I hope you're not trying to imply that I might do such a thing, or that such a transmission is permitted by FAA regulations. The pilot who did it should be referred to a FSDO inspector, and if I were the student who was the subject of his abuse, that is exactly what I'd do. It is very difficult to teach proper radio procedures as it is without the extremely rude and even violent discussion that frequently pervades news groups like this. If you are experiencing difficulty instructing your students in the proper use of radio communications as a result of the discussion that takes place in this newsgroup, your instruction technique need work. The source of your difficulty may be your choice to instruct your students to deviate from federal regulations, but such a conclusion is unlikely, as it would require YOU to take responsibility for YOUR PROBLEM instead of ridiculously blaming the newsgroup. Limiting your communication to simply announcing your position is stupid and dangerous. Obviously we have a difference of opinion. My opinion is compliant with FAA guidelines, yours is not. Perhaps you'd care to explain why your instruction is contrary to FAA recommendations, and what leads you to believe that compliance with FARs is stupid and dangerous? There is absolutely no reason not to be clear in who is going to be landing first, for example. While I am fully aware that it is common practice for aircraft participating in the CTAF self-announcement position broadcast system at uncontrolled air fields to negotiate via two-way radio, despite it being neither recommended in FAA published Advisory Circulars, AIM nor being mentioned in federal regulations, my view is that if such negotiation hadn't been conducted in this incident http://www.wfaa.com/sharedcontent/dws/wfaa/latestnews/stories/wfaa080..., the mishap may not have occurred. Are you are able to appreciate the logic of that point of view in this mishap? Can you appreciate, that deviating from FARs causes a safety hazard? 91.113 dictates that the pilot farther along toward the runway threshold on final approach will be landing first unless some arrogant know-it-all decides to deviate from federal regulations. Implicit in that analysis is the question, by what authority is the airman who negotiates right-of-way, contrary to what the Administrator has codified in federal regulation 91.113(g), empowered to override those regulations? Are you able to cite a regulation, other than 91.3(b), or another authoritative source that grants an airman that authority to deviate from federal regulations? If there is any doubt about another pilot's intentions you should be free to ask rather than be silent for fear of 'misusing' the radio. Why would there be any doubt? The right-of-way is established in FAR 91.113. Only those pilots who deviate from it create doubt. If ALL comply with 91.113, the FAA believes that pattern operations will be orderly and safe, or it seems to me they would have mentioned negotiating deviations from regulations as being appropriate in their literature and regulations. Similarly, I think it is better to say "I don't see you" instead of keeping silent and hitting someone mid-air. What leads you to believe that saying "I don't see you" prevents MACs. I beg you; please do attempt enlighten me on this subject. I swear, there seem to be an awful lot of idiots around here who are determined to be 'right,' even if it kills them. People who are so fanatical about not breaking some imagined rule prohibiting air-to-air communication that they are willing to die to prove a point are, IMHO, psychologically unfit to be pilots. Actually, I think it is those pilots who believe they know better than the FAA, and deviate from FAA guidelines, or fail to appreciate the wisdom inherent in the FARs who are operationally unfit to be pilots. In the accident cited above, the Stinson pilot attempted to deviate from 91.113(g). That attempt to deviate from FAA regulations resulted in his attempting to takeoff while another aircraft was on final approach. If he had complied with 91.113(g), and waited for the landing traffic, it would not have landed on top of him. Even you, in your current mental state should be capable of seeing the fundamental truth in that, hopefully. Agreed Larry Maybe I got lucky, but in my ground school a controller came in and did a 1 hour lecture and removed all ambiguity on radio com. He stressed "clarity and brevity", and what he needed to know, succintly. Made complete common sense to me. Ken |
needed to know, succintly Clarity and brevity are not one of Larry's strong points. He also lacks a little in the departments of flexibility and accepting the opinions of others. |
On Fri, 30 May 2008 06:59:17 -0500, "Viperdoc"
wrote in : He stressed "clarity and brevity", and what he needed to know, succintly Clarity and brevity are not one of Larry's strong points. He also lacks a little in the departments of flexibility and accepting the opinions of others. Colonel, please state how you believe 'accepting the opinions of others' relates to participation in the self-announce position and intention broadcasts on CTAF at uncontrolled airports, the subject of the article to which you followed up. You're just still smarting from being enlightened about MOA airspace not being reserved for the exclusive use of military pilots, and the inapplicability of MARSA to civilian flights, as you apparently believed. Don't take it personally, Jim. We all participate on Usenet to learn, don't we? Unfortunately, attacking the author of an article, instead of addressing the points contained within the article, does not contribute to the discussion. Rather, such personal attacks serve to underscore the attacker's lack of a reasonable rebuttal, and frustration at the inadequacy of their ability to articulate their thoughts. |
On Fri, 30 May 2008 13:05:44 GMT, Larry Dighera wrote:
You're just still smarting from being enlightened about MOA airspace not being reserved for the exclusive use of military pilots, and the inapplicability of MARSA to civilian flights, as you apparently believed. Don't take it personally, Jim. We all participate on Usenet to learn, don't we? A little nonsense Now and then Relished by The wisest men. ~W. Wonka -- Home is heaven and orgies are vile, But I like an orgy, once in a while. |
"Ken S. Tucker" wrote in
: Actually, I think it is those pilots who believe they know better than the FAA, and deviate from FAA guidelines, or fail to appreciate the wisdom inherent in the FARs who are operationally unfit to be pilots. Actually, it is the pilots who don't understand that rules are for the guidance of wise men and the obedience of fools, to quote Douglass Bader, that are a problem. In the accident cited above, the Stinson pilot attempted to deviate from 91.113(g). You don't know that. Fool. That attempt to deviate from FAA regulations resulted in his attempting to takeoff while another aircraft was on final approach. If he had complied with 91.113(g), and waited for the landing traffic, it would not have landed on top of him. Even you, in your current mental state should be capable of seeing the fundamental truth in that, hopefully. Agreed Larry Maybe I got lucky, but in my ground school a controller came in and did a 1 hour lecture and removed all ambiguity on radio com. He stressed "clarity and brevity", and what he needed to know, succintly. Made complete common sense to me. You're an idiot. Clear and brief enough for you? Bertie |
US Navy Test Pilot School F/A-18 turning onto final approach at KNPA today | Tom Callahan | Aviation Photos | 0 | November 2nd 07 09:45 PM |
US Navy Test Pilot School F/A-18 turning onto final approach at KNPA today | Tom Callahan | Aviation Photos | 0 | November 2nd 07 09:44 PM |
US Navy Test Pilot School F/A-18 on final approach at KNPA today | Tom Callahan | Aviation Photos | 0 | November 2nd 07 09:44 PM |
Sport Pilot Final | Gilan | Home Built | 34 | August 13th 04 03:20 PM |
Sport Pilot Final | Gilan | Piloting | 19 | July 22nd 04 04:38 PM |
