Stealth Pilot wrote:
On Fri, 30 May 2008 14:47:17 -0400, Dudley Henriques wrote: the problem and assuming all factors normal with balance and stability issues, what should be expected normally is a phugoid starting nose low as the engine quits to recover the trim speed. I'm assuming no fuel imbalance or rigging issues that could cause a bank input entry into the there is no reason for you to have a fugoid. when you pull off throttle the aircraft simulataneously slows slightly and enters a glide decent. I've never encountered any phugoid tendency in that manouver. I know of one instance where this occurred in real life. a couple of years ago there was a charter flight out of perth in a pressurised twin. there was some pressurisation problem and the pilot wasnt quick enough getting to the mask to stay concious. the end result was that the aircraft climbed way above unpressurised breathing altitude and all on board died. the aircraft crossed australia until somewhere in queensland it ran out of fuel. the aircraft was being tracked by others and the report is that the aircraft entered a gentle glide decent and was destroyed in the impact. there was no report of instability during the last part of the flight. Stealth Pilot Any phugoid in pitch and the time line of that Phugoid will be directly associated with the dynamic stability of that specific aircraft in pitch. It all depends on the specific aircraft. -- Dudley Henriques |
Dudley wrote:
Any phugoid in pitch and the time line of that Phugoid will be directly associated with the dynamic stability of that specific aircraft in pitch. Whenever I see the word "phugoid" I think UA 232. Hilton |
Hilton wrote:
Dudley wrote: Any phugoid in pitch and the time line of that Phugoid will be directly associated with the dynamic stability of that specific aircraft in pitch. Whenever I see the word "phugoid" I think UA 232. Hilton Al Haynes and company. What a magnificent job of flying those guys pulled off that day. Haynes is one of the TRUE professionals in the business. And the guys with him that afternoon were no slouches either. :-) -- Dudley Henriques |
On Sun, 1 Jun 2008 20:43:14 -0700, "Hilton" wrote
in : Dudley wrote: Any phugoid in pitch and the time line of that Phugoid will be directly associated with the dynamic stability of that specific aircraft in pitch. Whenever I see the word "phugoid" I think UA 232. Hilton I once had a former chief engineer with Burroughs demonstrate phugoid oscillation to me by grasping a book by the top in one hand and the bottom in the other, holding it horizontally, and tossing it into the air so that it spun on its long axis. Behold, the top and bottom sides of the book swapped places in mid air. ![]() |
U.S. Navy Plans EPX Intel-Gathering Aircraft | [email protected] | Naval Aviation | 0 | February 23rd 08 02:38 AM |
FOI...lol... CFI oral? | gatt[_2_] | Piloting | 29 | January 5th 08 05:01 PM |
Q: Apple MAC Book (pro) with Intel core 2 duo running Windows XP plus soaring software | Ruud | Soaring | 1 | October 31st 06 01:02 AM |
INTEL BILL CON JOB | Cribsheet | Piloting | 0 | December 7th 04 05:40 PM |
