Thanks to both replies. I was thinking of the F15, so I thought it
might be the center of gravity. I'm going to see if I can find photos of the other models mentioned. "John R Weiss" wrote in message news:La2zb.392545$HS4.3201917@attbi_s01... "miso" wrote... Does the airbrake put it's force on the center of gravity of the plane? If not, how does the pilot compensate for the force? In some airplanes there is a cable interconnect between the airbrake and the elevators that will compensate for pitching moments caused by the airbrakes. Otherwise the pilot simply uses the stick/yoke to compensate for small changes. After a pilot has flown a particular airplane type for a while, he naturally adjusts when he uses the airbrakes. |
![]() "miso" wrote in message om... Thanks to both replies. I was thinking of the F15, so I thought it might be the center of gravity. I'm going to see if I can find photos of the other models mentioned. Yes, a fighter speed brake is completely different from most of the replies you got. A fighter has the speed brake on the fue forward of the tail and it is only similar in name to a "spoiler deployed as a speedbrake". |
On Wed, 3 Dec 2003 08:39:19 -0800, "Tarver Engineering"
wrote: "miso" wrote in message . com... Thanks to both replies. I was thinking of the F15, so I thought it might be the center of gravity. I'm going to see if I can find photos of the other models mentioned. Yes, a fighter speed brake is completely different from most of the replies you got. A fighter has the speed brake on the fue forward of the tail and it is only similar in name to a "spoiler deployed as a speedbrake". John, once again you illustrate the problem with usenet. "on the fue"? "spoiler deployed as a speedbrake"? Seriously, the 102 and 106 certainly didn't have it deployed "forward of the tail" and those are the airplanes you were involved with in the FAT ANG. The 105 didn't have it "forward of the tail" and the F-16 among current equippage doesn't have it "forward of the tail" either. Some do. The F-15 certainly is forward and the F-111 was certainly forward. As for "spoiler deployed as a speedbrake"--that doesn't happen on any fighter type that I've encountered. Certainly some tactical aircraft used spoilers, primarily as a design counter to adverse yaw, but none with spoilers have a choice of control surface or speed brake function. Airliners do. Tell me again about your fighter experience. Speed brakes on fighters are single function surfaces. |
![]() "Ed Rasimus" wrote in message ... On Wed, 3 Dec 2003 08:39:19 -0800, "Tarver Engineering" wrote: "miso" wrote in message . com... Thanks to both replies. I was thinking of the F15, so I thought it might be the center of gravity. I'm going to see if I can find photos of the other models mentioned. Yes, a fighter speed brake is completely different from most of the replies you got. A fighter has the speed brake on the fue forward of the tail and it is only similar in name to a "spoiler deployed as a speedbrake". John, once again you illustrate the problem with usenet. "on the fue"? "spoiler deployed as a speedbrake"? Seriously, the 102 and 106 certainly didn't have it deployed "forward of the tail" and those are the airplanes you were involved with in the FAT ANG. The 105 didn't have it "forward of the tail" and the F-16 among current equippage doesn't have it "forward of the tail" either. Some do. The F-15 certainly is forward and the F-111 was certainly forward. As does the F-18. As for "spoiler deployed as a speedbrake"--that doesn't happen on any fighter type that I've encountered. That does cause one to wonder why there was such a lengthly discussion of airliner type speedbrakes. Certainly some tactical aircraft used spoilers, primarily as a design counter to adverse yaw, but none with spoilers have a choice of control surface or speed brake function. Airliners do. The selection capability is however there for those tactical aircraft using an actual "speed brake", as opposed to a "spoiler deployed as a speedbrake". Tell me again about your fighter experience. Speed brakes on fighters are single function surfaces. Exactly as I wrote, but thanks for playing. |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
