#11
On Jun 1, 8:06 pm, Gezellig wrote:
It happens that formulated : In the 1970's Ford sold some cars with "Ram-Air Induction" systems. A scoop mounted on the carb that stuck out above the hood, to ram vast volumes of air into the carb and get way more horsepower. That's what they wanted you to believe. At 60 mph the pressure recovery would have been laughably tiny, but Ford's profits were impressive. Had a Trans Am, scoop was reversed, facing the windshield, had a flap that opened when MP increased. They claimd that the reversed position was at the low pressure point at the base of the windshield hence enhancing the rammed air effect. I don't know, it was cool, the scoop assembly was attached to the engine so that on acceleration you could see the engine sitting down on its mounts as the scopp popped open and lowere ever so slightly. Locating the scoop at the low-pressure point wouldn't do much for ram-air effect, would it? I think the real idea would have been to make sure the driver heard that thing sucking loudly so it sounded like a real powerhouse I once converted a 14 foot outboard runabout to a 13 foot inboard Cracker Box with a Chev 283 straight-shaft setup. The exhausts were water-cooled and exited through the transom. Made so much noise that I made two mufflers and quieted it right down. The carb's flame arrestor stuck up far enough that I had a scoop on the deck, facing away from the cockpit (which was at the back). Everything else was covered. I dropped my Dad off on a gravel bar on a lake once, so he could fish off it while I ran to the far end of the lake to try the fishing there, three or four miles away. He told me he knew when I was coming back; he could hear that Rochester Quadrajet four-barrel open up and suck vast quantities of air; the boat got one mile per gallon at full throttle with that huge carb. But went real fast. I sold it years ago and I bet it don't go real fast no more, with fuel prices the way they are now. Dan |
On Jun 1, 7:59 pm, wrote:
On Jun 1, 8:06 pm, Gezellig wrote: It happens that formulated : In the 1970's Ford sold some cars with "Ram-Air Induction" systems. A scoop mounted on the carb that stuck out above the hood, to ram vast volumes of air into the carb and get way more horsepower. That's what they wanted you to believe. At 60 mph the pressure recovery would have been laughably tiny, but Ford's profits were impressive. Had a Trans Am, scoop was reversed, facing the windshield, had a flap that opened when MP increased. They claimd that the reversed position was at the low pressure point at the base of the windshield hence enhancing the rammed air effect. I don't know, it was cool, the scoop assembly was attached to the engine so that on acceleration you could see the engine sitting down on its mounts as the scopp popped open and lowere ever so slightly. Locating the scoop at the low-pressure point wouldn't do much for ram-air effect, would it? I think the real idea would have been to make sure the driver heard that thing sucking loudly so it sounded like a real powerhouse I once converted a 14 foot outboard runabout to a 13 foot inboard Cracker Box with a Chev 283 straight-shaft setup. The exhausts were water-cooled and exited through the transom. Made so much noise that I made two mufflers and quieted it right down. The carb's flame arrestor stuck up far enough that I had a scoop on the deck, facing away from the cockpit (which was at the back). Everything else was covered. I dropped my Dad off on a gravel bar on a lake once, so he could fish off it while I ran to the far end of the lake to try the fishing there, three or four miles away. He told me he knew when I was coming back; he could hear that Rochester Quadrajet four-barrel open up and suck vast quantities of air; the boat got one mile per gallon at full throttle with that huge carb. But went real fast. I sold it years ago and I bet it don't go real fast no more, with fuel prices the way they are now. Dan I confess to enjoying ancedotal stories. As a monster nut brat I got some tin cans together and built a pulse jet, complete with a flapping duct input, and used a hair dryer for my air input source, in my parents downstairs fireplace. So I pour in some gas into the thing, lite it up, turn on the hair dryer and holy poop, the duct starts fluttering and flames are fluttering out the ass end! It worked! It buzzed! I probably used a pint of gasoline per minute of operation, but that wasn't the point, it was actually seeing the damn thing in operation. Hands on is good stuff. Ken |
On Jun 1, 6:35�am, Tina wrote:
What makes me wonder about it is, even at 60 mph holding your hand out of the window of a car subjects it to a significant backward pressure, so the energy must be there. The energy is there and in a simplified discussion it is called stagnation pressure, the sum of static pressure and ram air pressure. As you go faster, static stays the same, ram goes up with the square of velocity, as discussed already. Your airspeed indicator uses the two pressures and does the math for you. On the Tango 2, a homebuilt, we have a ram air scoop below the spinner and a Y-valve and door for filtered or ram air. When I go to ram air at 150 kias, my manifold pressure goes up about .6 inch. Theoretically I should recover 1.08 inches. I only have a single buttlerfly Y-valve; we think some of the air is following the path of least resistance and going back up the filtered tube. Another Tango 2 has a double butterfly Y-valve that close off the escape route back through the filter. His ram rise is about 1.1 or 1.2 inches, which is more than stagnation. We put his ram air tube a little lower and closer to the prop as discussed in SPEED WITH ECONOMY by Ken Paser. This seems to capture the increased pressure behind the blade as it passes the inlet, timed with the intake valve opening. When we are side by side, flat out, when he goes ram air he pulls away from me. I normally don't go ram until I climb above the haze layer and my power drops below %75. At that point the power goes up about 4-5% and I can feel the acceleration. As someone else mentioned, you can't put a funnel out there and get even more boost. Any excess will just flow around the inlet and possibly increase drag. We don't know if our setup is optimum, but it helps. Other homebuilters I've talked to report similar results. Oh, for a wind tunnel and a lot of money. Denny Team Tango |
![]() wrote in message ... On Jun 1, 8:06 pm, Gezellig wrote: It happens that formulated : The biggest performance advantage to ram air was always recognized as COLD air, not increased pressure. That's why racers began using the base of the windshield for an intake, instead of forward a scoop. They could get plenty of cold air without increasing the frontal area of the vehicle. It's actually a HIGH pressure area, hence the reason so many vehicles have there fresh air intakes located there. |
![]() "Bertie the Bunyip" wrote in message ... Didn't know any production aircraft had that. Well, to some extent almost every lightplane does . that's why the carb air intake faces forwards in most of them.Everything is a balancing act with an airplane. More air = more drag. You could try putting a couple of woks with tubes out the back to boost your MP, but you're going to pay for it. !Moooney must have spotted an area of the cowl that would not penalise you in this way and decided to utilise it. Really clever homebuilders do a lot of this kind of stuff as well as, and probably more more importantly, dealing with cooling drag. Have you put the other speed mods on your airplane? I think there's nearly ten knots available in seals and various other tidy it up fairings. Bertie Dumb ass. Its because the size of the scoop increases volume (not pressure), and you already have too much. |
