Much better, more light for the same current, LedEngin from Mouser. Less
expensive and the packaging is far superior. Coming up September issue, as I recall. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle wrote in message ... JIm Weir, I noted your article in the current issue of KP on LEDs. I have purchased a small quanity of these. hard to find as they were recalled - lens were coming off in production. 160 lm @ 1000ma http://lumileds.com/pdfs/DS60.pdf My plans are to create a Rudder TE light bar and strobe them. Currently on the shelf with another project ahead of it. Jim Heffelfinger Sacramento |
Jim,
I flew a Bonanza G-36 that the new owner had spent bazillions on. A truly elegant feature it had was some sort of strip of blue white LEDs under the edge of the glare shield. Overall effect was like the old 727s that had some flourescent lamp under there. So of course, I was wondering where one could find a few feet of something similar without paying what Beech paid for it!! LEDs are the obvious solution for this one. BIll Hale On Jun 2, 9:06*am, "RST Engineering" wrote: Much better, more light for the same current, LedEngin from Mouser. *Less expensive and the packaging is far superior. *Coming up September issue, as I recall. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." * * * * --Aristotle wrote in message ... JIm Weir, I noted your article in the current issue of KP on LEDs. I have purchased a small quanity of these. *hard to find as they were recalled *- lens were coming off in production. *160 lm @ 1000ma http://lumileds.com/pdfs/DS60.pdf My plans are to create a Rudder TE light bar and strobe them. Currently on the shelf with another project ahead of it. Jim Heffelfinger Sacramento- Hide quoted text - - Show quoted text - |
Works and looks excellent.
Cheap. Easy to get or build. Pick any two. {;-) Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle " wrote in message ... Jim, I flew a Bonanza G-36 that the new owner had spent bazillions on. A truly elegant feature it had was some sort of strip of blue white LEDs under the edge of the glare shield. Overall effect was like the old 727s that had some flourescent lamp under there. So of course, I was wondering where one could find a few feet of something similar without paying what Beech paid for it!! LEDs are the obvious solution for this one. BIll Hale On Jun 2, 9:06 am, "RST Engineering" wrote: Much better, more light for the same current, LedEngin from Mouser. Less expensive and the packaging is far superior. Coming up September issue, as I recall. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle wrote in message ... JIm Weir, I noted your article in the current issue of KP on LEDs. I have purchased a small quanity of these. hard to find as they were recalled - lens were coming off in production. 160 lm @ 1000ma http://lumileds.com/pdfs/DS60.pdf My plans are to create a Rudder TE light bar and strobe them. Currently on the shelf with another project ahead of it. Jim Heffelfinger Sacramento- Hide quoted text - - Show quoted text - |
![]() " wrote ... ...it had some sort of strip of blue white LEDs under the edge of the glare shield. So of course, I was wondering where one could find a few feet of something similar without paying what Beech paid for it!! About ten years back I saw a vendor at the shows who sold those strips. Not cheap! Can't remember the name, but they also made custom cutout panel covers IIRC. Also, try a google for "electroluminescent strip", should find something in the electrical hobbie arena. Or, look about halfway down this link page for EL Products: http://www.dansdata.com/glowthings.htm Tangent: They (linking further to the chinese vendor), these guys make luminescent dial faces! How COOL would that make your panel look??? |
On 2008-06-03, Mike Isaksen wrote:
" wrote ... ...it had some sort of strip of blue white LEDs under the edge of the glare shield. About ten years back I saw a vendor at the shows who sold those strips. Not cheap! Can't remember the name, but they also made custom cutout panel covers IIRC. Also, try a google for "electroluminescent strip", should find something in the electrical hobbie arena. Different stuff. EL wire/strips aren't LEDs; they use an inverter to produce a signal of about 100 volts at a couple of kilohertz to drive the EL portion. I'd be a little nervous about putting that in an aircraft: seems like a good way to generate lots of RF hash. EL wire is also a royal pain to work with. I should know: that's the glowing stuff on the TRON costume. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (FRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 10 June) |
![]() "Jay Maynard" wrote ... I'd be a little nervous about putting that in an aircraft: seems like a good way to generate lots of RF hash. Yeah, I was wondering about that when I saw the $7 12vdc inverter. But the 1 inch by 12 inch strips are cheap enough to try: http://www.glowhut.com/el-strip--el-panel.html And here's a homebuilder's site that came up: http://www.aircraftextras.com/EL-Panel1.htm from a google "electroluminescent strip airplane". EL wire is also a royal pain to work with. I should know: that's the glowing stuff on the TRON costume. -- I yield to a Master when I see one! ;-) Hey where are you at in the countdown? |
seems like a good way to generate lots of RF hash. Yeah, I was wondering about that when I saw the $7 12vdc inverter. But the 1 inch by 12 inch strips are cheap enough to try: http://www.glowhut.com/el-strip--el-panel.html Yeah. I'd stick a couple of them in the airplane and exercise all of the radios before committing to a full EL illumination system. Hey where are you at in the countdown? The aircraft came out of the paint shop this morning; they're putting the finishing touches on it this week, and test flying it late this week and early next week. I'm going to the factory Tuesday to look it over and take delivery. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (FRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 10 June) |
![]() "Jay Maynard" wrote... I'm going to the factory Tuesday to look it over and take delivery. Nice! Just in time for summer. Wasn't is just last month you were torn which model to get ?!? Time flies,.. now you will too. PS. here's the LED brow lighting you preferred (half way down page): http://www.steinair.com/lights.htm |
![]() "RST Engineering" wrote in message m... Much better, more light for the same current, LedEngin from Mouser. Less expensive and the packaging is far superior. Coming up September issue, as I recall Wow, they have some monster LED's! I didn't see how they deal with getting rid of the heat produced, by say, a 15 watt emitter. It would be a pretty large issue, I'm sure. -- Jim in NC |
It's really pretty easy. One version of the device has the LED bonded to a
PC board and through the PC board to an aluminum puck about a quarter inch in diameter which (and this is the trick) is electrically INSULATED from the diode. Since you generally are going to mount this sucker on the last rib, or another hunk of aluminum out in the wingtip, all you do is bolt the diode/pc board/puck assembly to the aluminum with a very thin layer of thermal grease between the puck and the aluminum. I used a representative scrap of aluminum about 30 square inches and the diode rise over ambient was about 20°C. The allowable rise is well over 90C, so I think I just about sunk it well enough. This was for two 5-watt diodes on the same sink. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle "Morgans" wrote in message ... Wow, they have some monster LED's! I didn't see how they deal with getting rid of the heat produced, by say, a 15 watt emitter. It would be a pretty large issue, I'm sure. -- Jim in NC |
KX-155 LEDs | Steven Barnes | Owning | 21 | July 11th 13 09:04 AM |
LEDs | Hilton | Piloting | 15 | August 21st 07 04:36 AM |
Nav Lights using Luxeon LEDs | Andrew Sarangan | Home Built | 28 | March 7th 06 09:18 PM |
LEDs for Nav Lights - Jim Weir | Scott Gettings | Home Built | 3 | February 17th 04 01:53 AM |
LEDs | Morgans | Home Built | 6 | August 19th 03 03:49 AM |
