On Jun 2, 10:01 am, "Ken S. Tucker" wrote:
Tina, I think this analysis you posted is good, " It's only a 360 cubic inch engine turning at 2300 RPM or so. Isn't that a demand of, let's see, at 23 inches mp at sea level that's 23/30 * 2300/2 * 360 / 12^3 or 180 cubic feet a minute? " Can't do it that way. You're assuming a volumetric efficiency of 100% which we never attain without considerable boosting. The volumetric efficiency at full throttle and redline RPM at sea level isn't likely to be much more than 50 or 60%. Got to do it using fuel flow. Best power mixture comes at around 12:1 (pounds of air to pounds of fuel) and stoichiometric mixture (no wasted air or fuel) is 15:1. Weight of air at sea level is about .078 pounds per cubic foot, and weight of gasoline is 6 lb per US gallon. An O-320 @ 2700 RPM @ S.L. = Displacement of 15,000 cubic feet per hour. Full throttle fuel flow of 10.3 GPH @ 12:1 best power = 9434 cu. ft./hr (with fixed-pitch prop). 9434 ÷ 15,000 = .629 (62.9%) volumetric efficiency @ sea level. Not very good, is it? Air has viscosity and the drag of the entire induction system, even with the throttle wide open, is significant. Add to that the inertia of the air, and the intake valve's opening and closing causing the stop-go action of the air in the system, and things get slowed down considerably. It's worse in auto engines that turn at high RPM. That's why many have four valves per cylinder, or turbos, or both. Dan |
I think we're close to a stoichiometric mixture at peak egt for a
given rpm, but finding a way of stuffing more O2 into the cylinders would be nice during a climb to altitude. Never the less the back of the envelope number crunching I did and others have commented on pretty much convinced me to let engine optimization to those who know what they are doing. I will not be connecting the exhaust of a shop vac to the intake manifold any time soon! And to be honest I did not use the back of an envelope, but a cell in an Excel spreadsheet being used for a different kind of data analysis. Which reminds me, I had better delete it before I pass that analysis around. me Ken S. Tucker" wrote: Tina, I think this analysis you posted is good, " It's only a 360 cubic inch engine turning at 2300 RPM or so. Isn't that a demand of, let's see, at 23 inches mp at sea level that's 23/30 * 2300/2 * 360 / 12^3 or 180 cubic feet a minute? " Can't do it that way. You're assuming a volumetric efficiency of 100% which we never attain without considerable boosting. The volumetric efficiency at full throttle and redline RPM at sea level isn't likely to be much more than 50 or 60%. Got to do it using fuel flow. Best power mixture comes at around 12:1 (pounds of air to pounds of fuel) and stoichiometric mixture (no wasted air or fuel) is 15:1. Weight of air at sea level is about .078 pounds per cubic foot, and weight of gasoline is 6 lb per US gallon. An O-320 @ 2700 RPM @ S.L. = Displacement of 15,000 cubic feet per hour. Full throttle fuel flow of 10.3 GPH @ 12:1 best power = 9434 cu. ft./hr (with fixed-pitch prop). 9434 ÷ 15,000 = .629 (62.9%) volumetric efficiency @ sea level. Not very good, is it? Air has viscosity and the drag of the entire induction system, even with the throttle wide open, is significant. Add to that the inertia of the air, and the intake valve's opening and closing causing the stop-go action of the air in the system, and things get slowed down considerably. It's worse in auto engines that turn at high RPM. That's why many have four valves per cylinder, or turbos, or both. Dan |
