Ram air
Old June 2nd 08, 10:30 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
terry
Default Ram air
On Jun 3, 6:38*am, Billy Crabs wrote:
On Jun 2, 9:28*am, Bertie the Bunyip wrote:
"Maxwell" luv2^fly99@cox.^net wrote in news:jTR0k.192$js1.25
@newsfe24.lga:
Didn't know any production aircraft had that. Well, to some extent
almost every lightplane does . that's why the carb air intake faces
forwards in most of them.Everything is a balancing act with an
airplane. More air = more drag. You could try putting a couple of
woks with tubes out the back to boost your MP, but you're going to
pay for it. !Moooney must have spotted an area of the cowl that
would
not penalise you in this way and decided to utilise it. Really
clever
homebuilders do a lot of this kind of stuff as well as, and
probably
more more importantly, dealing with cooling drag.
Have you put the other speed mods on your airplane? I think there's
nearly ten knots available in seals and various other tidy it up
fairings.
Bertie
Dumb ass.
Its because the size of the scoop increases volume (not pressure),
and
you already have too much.
Nope.
Bertie
How would you know, dumb ass?
I know everything, obviously.
Bertie- Hide quoted text -
- Show quoted text -
Ram air is only as useful the allowing air to get to your carburater
faster but is not necessarily used. When your piston is on its intake
stroke(vaccum) your combustion chamber can only draw in enough air
that is in conjuction to the chambers volume and all other air that is
present after the compression stroke is exported to engines smog
devices and is recirculated only AFTER being filtered. *All engines
come off the assembly lines, be it an airplane motor or a vehicle
motor, to draw the amount of air that it needs to run at opptimum
performance. *Ram Air is a myth and don't try to throw "turbo" into
the conversation because turbo is recircualted exhaust and still has
unburnt fuel in the fumes.- Hide quoted text -
I would think the air getting to the cyclinder faster is important,
given the little time available for the intake to occur. If you
analyse the take off performance data of C172 ( which I have) you can
see quite clearly that for the same air density, better performance
( ie shorter take off distance) is obtained at higher temperatures
( which of course means higher pressure). I , and others, interpret
this as the higher pressure providing a stronger driving force to fill
the cylinder quicker.
Terry
PPL Downunder
Old June 3rd 08, 12:11 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Default Ram air
On Jun 2, 3:30 pm, terry wrote:
On Jun 3, 6:38 am, Billy Crabs wrote:
@newsfe24.lga:
would
clever
probably
fairings.
Bertie
Dumb ass.
and
Nope.
Bertie
devices and is recirculated only AFTER being filtered. All engines
performance. Ram Air is a myth and don't try to throw "turbo" into
Terry
PPL Downunder
Higher air temps mean a lower air viscosity, reducing
induction drag, and faster and more complete vaporization of the fuel.
Dan
Old June 3rd 08, 01:33 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
terry
Default Ram air
@newsfe24.lga:
would
clever
probably
fairings.
Bertie
Dumb ass.
and
Nope.
Bertie
given the little time available for the intake to occur. * If you
analyse the take off performance data of C172 ( which I have) *you can
Terry
PPL Downunder
* * * * * *Higher air temps mean a lower air viscosity, reducing
I thought that also ( the viscosity bit) , but viscosity of air
actually increases with increasing temperature
http://www.engineeringtoolbox.com/ai...ity-d_601.html
the vaporization theory might hold though. I will look into that one.
Terry
PPL Downunder
