Stealth Pilot wrote:
On Tue, 03 Jun 2008 13:17:17 -0400, mixed nuts wrote: Stealth Pilot wrote: On Mon, 02 Jun 2008 19:51:47 -0400, dave hillstrom wrote: On Mon, 2 Jun 2008 14:12:26 -0700 (PDT), Tony wrote: Ram air is only as useful the allowing air to get to your carburater faster but is not necessarily used. When your piston is on its intake stroke(vaccum) your combustion chamber can only draw in enough air that is in conjuction to the chambers volume and all other air that is present after the compression stroke is exported to engines smog devices and is recirculated only AFTER being filtered. All engines come off the assembly lines, be it an airplane motor or a vehicle motor, to draw the amount of air that it needs to run at opptimum performance. Ram Air is a myth and don't try to throw "turbo" into the conversation because turbo is recircualted exhaust and still has unburnt fuel in the fumes. I think you are quite wrong. Ram air in fact gives us a half inch or so more manifold pressure, and that increases the total weight of the air-fuel mixture in the cylinder. Reduce your 'it doesn't matter argument to an extreme to see how it fails. As for turbos, the turbine is powered by the exhaust gasses coming from the engine, the exhaust gas itself is not reintroduced into the cylinders. The turbine itself could be powered by an electric motor, for that matter. That was the model for my tongue in cheek comment about using a shop vac to increase manifold pressure. will you marry me? dave the term is not foo and bar. foo *is* a term from another war and another airforce but the term you've so successfully stuffed up is fubar fubar is a vietnam era acronym of F***ed up beyond all recognition. your sig line is a snafu (situation normal all F***ed up) Yore 'rong. foo and bar are metasyntactic variables. They aren't acronyms (they're metasyntactic variables). Like being the John and Jane Doe of computer engineering - placeholders. Fubar predates WWII. dont agree. foo for instance is a quite infamous cartoon of a guy peeping over a fence with the line 'foo was here' foo is the 'forward observation officer' the guy who used to tootle over the lines in an auster or a cub spotting for artillery and fighters. verrah verrah british ol' chap. verrah verrah courageous flying too boot. You really have no choice in this matter. foo and bar have a formal place in computer science and appear regularly in a large number of RFCs as well as in the scientific literature. If you, or anywon else choose to us these terms in any other context, feel free to do so but, unless yore a computer geek describing algorithms in pseudo-code and contributing new and more wonderful metasyntactic variables to the pool (see reesent psot sigs by won Daev Hillstorm) don't go peeing on our carpet. -- nuts |
Stealth Pilot wrote in
: On Tue, 03 Jun 2008 13:17:17 -0400, mixed nuts wrote: Stealth Pilot wrote: On Mon, 02 Jun 2008 19:51:47 -0400, dave hillstrom wrote: On Mon, 2 Jun 2008 14:12:26 -0700 (PDT), Tony wrote: Ram air is only as useful the allowing air to get to your carburater faster but is not necessarily used. When your piston is on its intake stroke(vaccum) your combustion chamber can only draw in enough air that is in conjuction to the chambers volume and all other air that is present after the compression stroke is exported to engines smog devices and is recirculated only AFTER being filtered. All engines come off the assembly lines, be it an airplane motor or a vehicle motor, to draw the amount of air that it needs to run at opptimum performance. Ram Air is a myth and don't try to throw "turbo" into the conversation because turbo is recircualted exhaust and still has unburnt fuel in the fumes. I think you are quite wrong. Ram air in fact gives us a half inch or so more manifold pressure, and that increases the total weight of the air-fuel mixture in the cylinder. Reduce your 'it doesn't matter argument to an extreme to see how it fails. As for turbos, the turbine is powered by the exhaust gasses coming from the engine, the exhaust gas itself is not reintroduced into the cylinders. The turbine itself could be powered by an electric motor, for that matter. That was the model for my tongue in cheek comment about using a shop vac to increase manifold pressure. will you marry me? dave the term is not foo and bar. foo *is* a term from another war and another airforce but the term you've so successfully stuffed up is fubar fubar is a vietnam era acronym of F***ed up beyond all recognition. your sig line is a snafu (situation normal all F***ed up) Yore 'rong. foo and bar are metasyntactic variables. They aren't acronyms (they're metasyntactic variables). Like being the John and Jane Doe of computer engineering - placeholders. Fubar predates WWII. dont agree. foo for instance is a quite infamous cartoon of a guy peeping over a fence with the line 'foo was here' BY the way, the Foo was here thing was a corruption of th eorignal Kilroy was here. no idea where that started, but it was everywhere for years. Foo was here was a minor variation. Bertie |
On Thu, 5 Jun 2008 16:38:44 +0000 (UTC), Bertie the Bunyip
wrote: Stealth Pilot wrote in : On Tue, 03 Jun 2008 13:17:17 -0400, mixed nuts wrote: Stealth Pilot wrote: On Mon, 02 Jun 2008 19:51:47 -0400, dave hillstrom wrote: On Mon, 2 Jun 2008 14:12:26 -0700 (PDT), Tony wrote: Ram air is only as useful the allowing air to get to your carburater faster but is not necessarily used. When your piston is on its intake stroke(vaccum) your combustion chamber can only draw in enough air that is in conjuction to the chambers volume and all other air that is present after the compression stroke is exported to engines smog devices and is recirculated only AFTER being filtered. All engines come off the assembly lines, be it an airplane motor or a vehicle motor, to draw the amount of air that it needs to run at opptimum performance. Ram Air is a myth and don't try to throw "turbo" into the conversation because turbo is recircualted exhaust and still has unburnt fuel in the fumes. I think you are quite wrong. Ram air in fact gives us a half inch or so more manifold pressure, and that increases the total weight of the air-fuel mixture in the cylinder. Reduce your 'it doesn't matter argument to an extreme to see how it fails. As for turbos, the turbine is powered by the exhaust gasses coming from the engine, the exhaust gas itself is not reintroduced into the cylinders. The turbine itself could be powered by an electric motor, for that matter. That was the model for my tongue in cheek comment about using a shop vac to increase manifold pressure. will you marry me? dave the term is not foo and bar. foo *is* a term from another war and another airforce but the term you've so successfully stuffed up is fubar fubar is a vietnam era acronym of F***ed up beyond all recognition. your sig line is a snafu (situation normal all F***ed up) Yore 'rong. foo and bar are metasyntactic variables. They aren't acronyms (they're metasyntactic variables). Like being the John and Jane Doe of computer engineering - placeholders. Fubar predates WWII. dont agree. foo for instance is a quite infamous cartoon of a guy peeping over a fence with the line 'foo was here' BY the way, the Foo was here thing was a corruption of th eorignal Kilroy was here. no idea where that started, but it was everywhere for years. Foo was here was a minor variation. Bertie they are fascinating pieces of folk history so when I find one out it sticks in the memory. Kilroy was a government guy pressed into the task of inspecting the quality of the hastily built cargo ships the americans turned out for the shipping task to england. he had no way of remembering where he had previously inspected so he developed the habit of chalking 'Kilroy was here" to remind himself of sections he had already inspected. the internal sections were eventually welded into the structure. weeks later when torpedo damage was being repaired the workers would cut away sealed parts and find the mysterious chalk marks "Kilroy was here". the endearing puzzle being how did they get there in sealed sections? the mystery was explained a few years ago in a news radio segment where someone actually tracked down the guy and got him to explain the riddle. Stealth ( liberty ships?) Pilot |
: they are fascinating pieces of folk history so when I find one out it sticks in the memory. Kilroy was a government guy pressed into the task of inspecting the quality of the hastily built cargo ships the americans turned out for the shipping task to england. he had no way of remembering where he had previously inspected so he developed the habit of chalking 'Kilroy was here" to remind himself of sections he had already inspected. the internal sections were eventually welded into the structure. weeks later when torpedo damage was being repaired the workers would cut away sealed parts and find the mysterious chalk marks "Kilroy was here". the endearing puzzle being how did they get there in sealed sections? the mystery was explained a few years ago in a news radio segment where someone actually tracked down the guy and got him to explain the riddle. I always wondered where that came from. You'd still see it as graffiti as late as the 70s. i suppose years form now people will be explaining the origins of "where's the beef" to the bewilderment of the youngsters who won't be able to understand why anyone would eat something infected with e- coli and BSE.. Bertie |
