Ram air
Old June 3rd 08, 03:26 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Billy Crabs
Default Ram air
On Jun 2, 10:00*pm, Billy Crabs wrote:
On Jun 2, 5:12*pm, Tony wrote:
Ram air is only as useful the allowing air to get to your carburater
faster but is not necessarily used. When your piston is on its intake
stroke(vaccum) your combustion chamber can only draw in enough air
that is in conjuction to the chambers volume and all other air that is
present after the compression stroke is exported to engines smog
devices and is recirculated only AFTER being filtered. *All engines
come off the assembly lines, be it an airplane motor or a vehicle
motor, to draw the amount of air that it needs to run at opptimum
performance. *Ram Air is a myth and don't try to throw "turbo" into
the conversation because turbo is recircualted exhaust and still has
unburnt fuel in the fumes.
I think you are quite wrong. Ram air in fact gives us a half inch or
so more manifold pressure, and that increases the total weight of the
air-fuel mixture in the cylinder. Reduce your 'it doesn't matter
argument to an extreme to see how it fails.
As for turbos, the turbine is powered by the exhaust gasses coming
from the engine, the exhaust gas itself is not reintroduced into the
cylinders. The turbine itself could be powered by an electric motor,
for that matter. That was the model for my tongue in cheek comment
about using a shop vac to increase manifold pressure.
The air going into the manifold has the same atmospheric weight as if
it was outside the manifold, what makes it denser is the addition of
fuel into the air/fuel mixture, unless the air is in a perfect vaccum
it will not increase in pressure and most certainly not density and
the turbos do reintroduce fuel back into the combustion mixture, If
you've ever seen a read out of carbon emissions for a non turbo
vehicle it still has enough unburnt fuel to power your vehicle for
another 5% of your fuel consumption *and turbos IF powered by a
motorized turbine are as useless as ram air because of the statement I
made in my previous post. your intake is only as much as the volume of
your cylinders- Hide quoted text -
- Show quoted text -
I retract that last statement, turbos are not useless, I would be
contradicting myself if I said they were.
