#31
Costly and needing to be done on a much more than annual (IIRC 45 day )
cycle. Any ex egress types on here who can remember the inspection interval? -- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) "Gord Beaman" wrote in message ... "Les Matheson" wrote: IIRC the issue with ejection seats is that they must be inspected regularly, as the military specs call for. This is a very expensive proposition and there are few shops that do it. If they can't be inspected and certified, the FAA requires they be inerted. Thanks Les...I was just going to ask why this requirement was made. But isn't that just as any other system requirement?...the a/c must have to be maintained and inspected right?. Seems to me that the FAA is merely giving the owners an 'out' so as to circumvent a very costly inspection right?. -- -Gord. |
#32
![]() "Gord Beaman" wrote in message I understand that ejection seats 'are' allowed but that they 'must' be inspected and maintained in strict accordance with certain rules. This is a 'very' costly procedure and can only be performed by a very few qualified companies. Therefore, the FAA allows civvy owners to remove them if desired. If you want the protection then you pay the piper. Seems quite reasonable to me. Or am I in error? -- -Gord. Mary had an interesting post on this about a year ago. It's not just repacking the silk but also replacing the pyros, which are all specific parts for each seat model and time limited. IIRC some pyros weren't used in large enoough numbers to continue to manufacture them for sensible prices. I've heard of seat overhauls here at $US10-15K apiece. At those prices, I'd punch out anyway - just to get my money's worth. -- Cheers Dave Kearton (it was a joke dammit) |
#33
"Dave Kearton"
wrote: "Gord Beaman" wrote in message I understand that ejection seats 'are' allowed but that they 'must' be inspected and maintained in strict accordance with certain rules. This is a 'very' costly procedure and can only be performed by a very few qualified companies. Therefore, the FAA allows civvy owners to remove them if desired. If you want the protection then you pay the piper. Seems quite reasonable to me. Or am I in error? -- -Gord. Mary had an interesting post on this about a year ago. It's not just repacking the silk but also replacing the pyros, which are all specific parts for each seat model and time limited. IIRC some pyros weren't used in large enoough numbers to continue to manufacture them for sensible prices. I've heard of seat overhauls here at $US10-15K apiece. At those prices, I'd punch out anyway - just to get my money's worth. ![]() reading "Ejection seats aren't allowed in privately owned a/c". That isn't true at all... -- -Gord. |
#34
The NTSB has released its preliminary report on the T-33 crash that
killed pilot Dan Lavigna near Santa Clarita, California, on Nov. 2. Witnesses observed the plane roll over and dive vertically into the ground at the conclusion of a 180 degree turn. Most said the loud whine of the engine attracted their attention. http://www.ntsb.gov/NTSB/brief.asp?e...12X01888&key=1 -- Paul Hirose To reply by email delete INVALID from address. |
#35
Costly and needing to be done on a much more than annual (IIRC 45 day ) cycle. Any ex egress types on here who can remember the inspection interval? I will see if I can find out. As far as the certification goes It's not just irritating paperwork. A friend of mine un-safed the seat in a B-57 and the det cord on the canopy blew, but fortunately not the seat. As it was the end of three fruitless days (this was pre 9-11) of messing around he decided to blow town right there and then and made for the terminal, boots, flightsuit still on. The sniffer machine at security went nuts because he stank of det-cord and there was then loads of explaining as to why someone was wearing a flightsuit, stank of explosives and was covered in bleeding flesh-wounds inflicted by flying Perspex shrapnel. Just remember - visor down before you unsafe the seat. |
#36
funkraum wrote:
As it was the end of three fruitless days (this was pre 9-11) of messing around he decided to blow town right there and then and made for the terminal, boots, flightsuit still on. The sniffer machine at security went nuts because he stank of det-cord and there was then loads of explaining as to why someone was wearing a flightsuit, stank of explosives and was covered in bleeding flesh-wounds inflicted by flying Perspex shrapnel. Nice hangar flying tale but it falls apart when the "pre 9-11" sniffer machine went off. Which airport had sniffer machines at passenger screening points at all much less used them to sniff passenger clothing or carryon baggage? Rick |
#37
In article k.net,
Rick wrote: l. Nice hangar flying tale but it falls apart when the "pre 9-11" sniffer machine went off. Which airport had sniffer machines at passenger screening points at all much less used them to sniff passenger clothing or carryon baggage? A lot of airports were using the "sniffer" prior to 9-11. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
#38
Rick wrote:
Nice hangar flying tale but it falls apart when the "pre 9-11" sniffer machine went off. Which airport had sniffer machines at passenger screening points at all much less used them to sniff passenger clothing or carryon baggage? I have very definite memories of having my bags swabbed and sniffed for explosives at National Airport long before September 2001. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
#39
Rick wrote:
funkraum wrote: Nice hangar flying tale but it falls apart when the "pre 9-11" sniffer machine went off. Which airport had sniffer machines at passenger screening points at all much less used them to sniff passenger clothing or carryon baggage? Just checked the date: It was July 2001 |
