On Jun 3, 10:18 am, "Ken S. Tucker" wrote:
I wonder if ram scoops were ever installed near the prop tips. Probably too expensive for GA, but a WW2 A/C with tips spinning at what(?) 500-600 mph would give a nice pressure boost. I've read dual phase superchargers were used in recon A/C to get the speed and altitude. Airspeed off the tips is the same as the speed off the inner blade areas, due to the pitch washout across the blade span, so there'd be no advantage to having scoops behind the tips. The propeller's blades are flying at an AOA of between 2 and 4 degrees in cruise flight, anywhere between the tips and hub, because of that pitch variation. See Figure 6-4 of this page: http://www.allstar.fiu.edu/aero/flight63.htm Dan |
On Jun 3, 11:18 am, wrote:
On Jun 3, 10:18 am, "Ken S. Tucker" wrote: I wonder if ram scoops were ever installed near the prop tips. Probably too expensive for GA, but a WW2 A/C with tips spinning at what(?) 500-600 mph would give a nice pressure boost. I've read dual phase superchargers were used in recon A/C to get the speed and altitude. Airspeed off the tips is the same as the speed off the inner blade areas, due to the pitch washout across the blade span, so there'd be no advantage to having scoops behind the tips. The propeller's blades are flying at an AOA of between 2 and 4 degrees in cruise flight, anywhere between the tips and hub, because of that pitch variation. See Figure 6-4 of this page:http://www.allstar.fiu.edu/aero/flight63.htm Dan Dan it was a trick question I asked you. It's the basic aerodynamic physics of the standard centifugal supercharger compressor operating principle. I tossed you a zinger, cuz you claimed to be a teacher in a college and I couldn't resist :-), don't worry about it, hardly anyone get's that one correct, and I hope you get a ha-ha-ah from it. I mentioned, "dual phase superchargers" as a hint. Here's the answer: the ram-air pressure acquired at the prop tips is equal to the loss of pressure against the centrifugal force pushing air - via ducting - into the prop center that one obtains at the prop tips. Now you know the rest of the story. Regards Ken |
On Jun 3, 12:56 pm, "Ken S. Tucker" wrote:
Dan it was a trick question I asked you. It's the basic aerodynamic physics of the standard centifugal supercharger compressor operating principle. I tossed you a zinger, cuz you claimed to be a teacher in a college and I couldn't resist :-), don't worry about it, hardly anyone get's that one correct, and I hope you get a ha-ha-ah from it. The prop does not throw air outward. We've been over that one before. The air column actually narrows behind the prop, due to the lowered pressure caused by the air's acceleration. We can see it on cool mornings when the dew point is just below ambient temperature, and the vapor trails off the prop tips outline the periphery of the air column, showing it to be squeezing inward. A centrifugal super/turbocharger does it differently. The air is accelerated outward in the first place, not in an axial manner, and is directed into a divergent duct known as a diffuser, where it is slowed and its pressure raised. A different animal altogther, compared to a propeller. I mentioned, "dual phase superchargers" as a hint. Here's the answer: the ram-air pressure acquired at the prop tips is equal to the loss of pressure against the centrifugal force pushing air - via ducting - into the prop center that one obtains at the prop tips. "Dual-phase supercharger" is a misnomer. They were two-speed affairs, going to a higher gear ratio for higher altitudes. Dan |
On Jun 4, 11:41*am, wrote:
On Jun 3, 12:56 pm, "Ken S. Tucker" wrote: Dan it was a trick question I asked you. It's the basic aerodynamic physics of the standard centifugal supercharger compressor operating principle. I tossed you a zinger, cuz you claimed to be a teacher in a college and I couldn't resist :-), don't worry about it, hardly anyone get's that one correct, and I hope you get a ha-ha-ah from it. * * * * * * The prop does not throw air outward. We've been over that one before. The air column actually narrows behind the prop, due to the lowered pressure caused by the air's acceleration. We can see it on cool mornings when the dew point is just below ambient temperature, and the vapor trails off the prop tips outline the periphery of the air column, showing it to be squeezing inward. * * * * A centrifugal super/turbocharger does it differently. The air is accelerated outward in the first place, not in an axial manner, and is directed into a divergent duct known as a diffuser, where it is slowed and its pressure raised. A different animal altogther, compared to a propeller. I mentioned, "dual phase superchargers" as a hint. Here's the answer: the ram-air pressure acquired at the prop tips is equal to the loss of pressure against the centrifugal force pushing air - via ducting - into the prop center that one obtains at the prop tips. * * * * *"Dual-phase supercharger" is a misnomer. They were two-speed affairs, going to a higher gear ratio for higher altitudes. There are also two stage systems Cheers |
On Jun 3, 5:41 pm, wrote:
The prop does not throw air outward. We've been over that one before. The air column actually narrows behind the prop, due to the lowered pressure caused by the air's acceleration. We can see it on cool mornings when the dew point is just below ambient temperature, and the vapor trails off the prop tips outline the periphery of the air column, showing it to be squeezing inward. More on the narrowing of fluid flows behind propellers: Marine propeller: http://www.aip.org/pt/feb00/maris.htm Helicopter rotor: http://www.camrad.com/CAMRADIIresults.html Behind transport props: http://home.att.net/~polar/130contrail.jpg Behind an F4U's prop: http://people.bath.ac.uk/ensmjc/Research/corsair.gif In no case do we see air (or any other fluid) being thrown out centrifugally. Dan |
"Ken S. Tucker" wrote in
: On Jun 3, 11:18 am, wrote: On Jun 3, 10:18 am, "Ken S. Tucker" wrote: I wonder if ram scoops were ever installed near the prop tips. Probably too expensive for GA, but a WW2 A/C with tips spinning at what(?) 500-600 mph would give a nice pressure boost. I've read dual phase superchargers were used in recon A/C to get the speed and altitude. Airspeed off the tips is the same as the speed off the inner blade areas, due to the pitch washout across the blade span, so there'd be no advantage to having scoops behind the tips. The propeller's blades are flying at an AOA of between 2 and 4 degrees in cruise flight, anywhere between the tips and hub, because of that pitch variation. See Figure 6-4 of this page:http://www.allstar.fiu.edu/aero/flight63.htm Dan Dan it was a trick question I asked you. Bwawhawhhahwhahwhahwhahwhahhwhahwhahwhahwhahwhahhw haw! Bertie |
