Pitch vs. trim in flight phases
Old June 3rd 08, 09:55 PM posted to rec.aviation.piloting,rec.aviation.student
More_Flaps
Default Pitch vs. trim in flight phases
On Jun 3, 11:53*pm, Michael wrote:
On May 31, 10:56*am, Tina wrote:
The overlooked or ignored difference is if one turns the trim in the
wrong direction in a real airplane pressure on the yoke increases.
No, this is not universally true. *I've flown airplanes where this is
not true, and clearly so has Robert Moore. *These are certificated
airplanes ranging from light piston singles to transport category
multiengine jets.
Hi Michael,
Here's my understanding : If the yoke gives force feedback of the out
of trim condition (you hold attitude and then trim) then if you turn
the trim the wrong while then holding attitude yoke pressure will
increase -as Tina says. If it doesn't then you are not holding
attitude OR the stick is not connected directly to the elevator
surface (e.g. elevator is hydraulic or trim surface powered). I know
the latter is the case for big planes (where elevator forces are too
large for one armed man power) but what light piston single are you
thinking about?
Cheers
Old June 4th 08, 06:02 PM posted to rec.aviation.piloting,rec.aviation.student
Michael[_1_]
In theory this is right - but in practice you will have to turn it a
long time before the increase is noticeable with certain trim systems.
There is a third option - this is where the trim surface is not
connected to the elevator - which is indeed the case. The yoke forces
come from the elevator not being 'in trail' with the stabilizer in
such a system. Since the angle of the stabilizer changes very little
as trim is applied, the force on the yoke in a given position also
changes very little. If you move the yoke in the correct direction to
maintain the pitch attitude, the force on the yoke will change as it
should - but this is also the case in a primitive sim since the stick
has a spring return.
I know
thinking about?
I'm thinking of the short wing Pipers - the most popular of which was
the TriPacer.
Michael
Typical power settings during cruise and other phases of flight Mxsmanic Piloting 99 October 2nd 06 10:12 AM
Making a pitch trim indicator for a Glasair [email protected] Home Built 5 September 13th 06 02:30 AM
$30,000 pitch links Stuart Fields Home Built 3 January 16th 06 02:13 AM
Cherokee Electric Pitch Trim Jonathan Goodish Owning 4 November 18th 04 02:43 AM
ALTRAK pitch system flight report optics student Home Built 2 September 21st 03 11:49 PM
