On Jun 3, 1:45*pm, Billy Crabs wrote:
On Jun 2, 11:33*pm, Billy Crabs wrote: On Jun 2, 11:08*pm, wrote: On Jun 2, 8:00 pm, Billy Crabs wrote: On Jun 2, 5:12 pm, Tony wrote: Ram air is only as useful the allowing air to get to your carburater faster but is not necessarily used. When your piston is on its intake stroke(vaccum) your combustion chamber can only draw in enough air that is in conjuction to the chambers volume and all other air that is present after the compression stroke is exported to engines smog devices and is recirculated only AFTER being filtered. *All engines come off the assembly lines, be it an airplane motor or a vehicle motor, to draw the amount of air that it needs to run at opptimum performance. *Ram Air is a myth and don't try to throw "turbo" into the conversation because turbo is recircualted exhaust and still has unburnt fuel in the fumes. I think you are quite wrong. Ram air in fact gives us a half inch or so more manifold pressure, and that increases the total weight of the air-fuel mixture in the cylinder. Reduce your 'it doesn't matter argument to an extreme to see how it fails. As for turbos, the turbine is powered by the exhaust gasses coming from the engine, the exhaust gas itself is not reintroduced into the cylinders. The turbine itself could be powered by an electric motor, for that matter. That was the model for my tongue in cheek comment about using a shop vac to increase manifold pressure. The air going into the manifold has the same atmospheric weight as if it was outside the manifold, what makes it denser is the addition of fuel into the air/fuel mixture, unless the air is in a perfect vaccum it will not increase in pressure and most certainly not density and the turbos do reintroduce fuel back into the combustion mixture, If you've ever seen a read out of carbon emissions for a non turbo vehicle it still has enough unburnt fuel to power your vehicle for another 5% of your fuel consumption *and turbos IF powered by a motorized turbine are as useless as ram air because of the statement I made in my previous post. your intake is only as much as the volume of your cylinders * * * * * * Turbocharging can be set to two different levels: Turbonormalizing, which brings manifold pressure to sea level pressure; and boosting, which raises manifold pressures to more than 30" Hg. If an engine is boosted, the air density in the cylinder at the bottom of the intake stroke could be well above atmospheric. I'm sorry to keep disagreeing but, but the pressure in which(if you can call it pressure) goes through a manifold is increased by MAP sensors which measure atmospheric pressure and regulates air fuel mixture, it has nothing to do with "ram air" and I do agree that that the density of the air/mixture is increased by the vaccum caused by a piston at bottom dead center but we were talking about air before it reaches the cylinder and the speed of which it arrives to carburation. * * * * *Dan- Hide quoted text - - Show quoted text -- Hide quoted text - - Show quoted text -- Hide quoted text - - Show quoted text - let me try to explain myself better, the amount of air that is drawn into an engine is in direct coralation to cylinder volume and the cam shafts "lift and duration" A valve can only stay open as long as the cam lobe holds the lifter up, therefore only allowing as much air/fuel as was scientificly formulated for the cylinder. for instance, lets say you have two guys who are going to breath in deep, now even if you are blowing an air hose in their faces, they are only going to be able to inhale as much as there lungs will hold. *Now lets say they are inhaling pot and when they blow out its put into a "turbo", the turbine spins and sends the unused pot back to their lungs, but it's still only as much as they hold in their lungs(cylinder volume)- Hide quoted text - Billy , I think you are confusing volume ( which is certainly fixed) with mass of air. by increasing the pressure you increase the density and therefore have a higher mass of air for the same volume. higher mass of course means more energy for the same volume charge. Terry PPL Downunder |
