Perfect loop
Old June 5th 08, 06:03 PM posted to rec.aviation.piloting
Maxwell[_2_]
Default Perfect loop ping Viperdoc
OK **** chokula.
Bertie
Unrelated. Still loosing it.
  #42
Old June 5th 08, 06:03 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Bertie the Bunyip[_25_]
"Maxwell" luv2^fly99@cox.^net wrote in news:y%U1k.3452$QI2.74
@newsfe23.lga:
OK **** chokula.
Bertie
Snort! He thinks h has me on the run!
That's soooo kewt!
God I love usenet.
Bertie
  #43
Old June 5th 08, 06:04 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
"Maxwell" luv2^fly99@cox.^net wrote in news:K0V1k.3453$QI2.1839
@newsfe23.lga:
In any case, related, unrealted, it matters no one jot once I keep you
poasting, fjukkwit...
Bertie
Sure it does. If you lack the intelligence to respond, you just showcase
your ilkness.
Snort!
Bertie
  #44
Maxwell[_2_]
Bertie
your ilkness.
  #45
Old June 5th 08, 06:55 PM posted to rec.aviation.piloting
Ron Garret
In article XoH1k.16394$qP.15098@trnddc03,
TheSmokingGnu wrote:
More_Flaps wrote:
How can I tell if my loops are perfect
circles?
Ask Dudley for technique, but as for the physics: a perfect loop would
have a constant acceleration.
Only in zero G.
Just take an accelerometer with you and
see how consistent you are (preferably one that can discount the Earth's
gravity,
Are there such beasts? I know it's theoretically possible, but it would
be very hard (and expensive) to build such a gadget. Do they really
exist?
rg
  #46
Old June 5th 08, 06:59 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.2600
Viperdoc
Default Educating Maxwell, Part 2
I agree- his spins and snaps are actually cheats- there is no stall break.
On the other hand, he is so smooth that no one notices- he is the master of
energy conservation.
  #47
Old June 5th 08, 07:18 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
circles?
Only in zero G.
gravity,
exist?
rg
Yes. The Naval Test Pilot School uses extremely sensitive accelerometers
on the T38's used for coupling and departure research flights.
Dudley Henriques
  #48
Old June 5th 08, 08:35 PM posted to rec.aviation.piloting
More_Flaps
*TheSmokingGnu wrote:
circles?
Only in zero G.
And only if speed is constant.
Cheers
  #49
Old June 6th 08, 05:54 AM posted to rec.aviation.piloting
K l e i n[_2_]
On Jun 5, 1:35 pm, More_Flaps wrote:
On Jun 6, 5:55 am, Ron Garret wrote: In article XoH1k.16394$qP.15098@trnddc03,
circles?
Only in zero G.
Cheers
It's very simple to do this. Simply incline the loop 90 degrees from
the axis you were thinking of. This has another name - a 360 degree
turn. ;-)
K l e i n
  #50
Old June 6th 08, 04:48 PM posted to rec.aviation.piloting
Ron Garret
circles?
Only in zero G.
gravity,
exist?
rg
It's not so much that they have to be sensitive as that they would have
to incorporate an AHRS (or something equivalent) in order to figure out
which way is down.
And what is a coupling and departure research flight? And why would you
need an accelerometer that compensated for gravity to conduct one?
rg
outside loop niceguy Aviation Photos 13 August 9th 07 06:57 AM
My Ground Loop Reid & Julie Baldwin Piloting 53 December 5th 05 11:29 PM
More likely to ground loop? [email protected] Piloting 16 February 25th 05 03:21 PM
AN-2 performing a loop Maro_SK Aerobatics 1 March 25th 04 08:18 PM
What is a ground loop? Mike Piloting 34 July 30th 03 06:19 PM
