" An interesting fact, which is not obvious to many folks,
including some aerobatic pilots (judging by the number of loop into the ground accidents) is that the radius of any turn, up, down, sideways or whatever, is a function of the square of TRUE airspeed, which is of course a function of density altitude and calibrated airspeed. So, if the density altitude increases your true airspeed by 5mph, you get a 5mph^2 impact on your radius. This kind of change in radius can ruin your day if you are playing down near the dirt. This velocity^2 thing is also why the reverse cuban or loop down is a real killer. If you start the pull with X knots too many, you will use X^2 more radius for the 1/2 loop, throw in an increase in TAS of say Y due to density altitude and you are into (X+Y)^2 more radius ... not good. If you have not left margin either in terms of available G or altitude you are either gonna high speed stall on the way down (and hit the ground) or hit it on the arc. I think this may need a little more explaining even if only for my understanding. I am very new to aerobatics. So if I normally commence a loop at 100 knotts but get the entry speed wrong and start at 105 knots then my loop (assume horizontal plane and constant speed for simplicity) will be New_Loop_Diameter=Old_Loop_Diameter x New_Speed ^2 / Old_Speed ^2 i.e. a factor of 1.103. A bad entry of 15 knots over speed would have a factor of 1.323. But a target speed of 200 but entry of 215 would have a factor of 1.156. If my understanding is not correct then please explain why. I prefer to understand the physics/maths before I attempt some of these manoeuvres. Anyone care to formulate what happens when speed ( or "G") are not constant? Yes unfortunately while the radius is a function of velocity ^ 2, it is also a function of a great many other things. The main point is to recognize the non-linear relationship between speed and radius, and to then recognize that density altitude changes produce non-linear effects on radius. I don't recommend you do anything with the math except make a big 'ahhhhhhh' sound and let it cause a sensible sense of dread in you whenever you pull towards the ground. By the way, a minimum radius pull is at a bit above the stall speed so if you pull to just before the buffet you are pretty close regardless of airspeed. Cheers, Peter |
"Peter Ashwood-Smith C-GZRO" wrote in
message om... " An interesting fact, which is not obvious to many folks, including I don't recommend you do anything with the math except make a big 'ahhhhhhh' sound and let it cause a sensible sense of dread in you whenever you pull towards the ground. By the way, a minimum radius pull is at a bit above the stall speed so if you pull to just before the buffet you are pretty close regardless of airspeed. Hopefully someone isn't flying the bottom of a loop near stall speed. Isn't the minimum radius turn going to be accomplished at corner velocity and max-G pull? Al |
![]() "DaBear" wrote in message ... "Peter Ashwood-Smith C-GZRO" wrote in message om... " An interesting fact, which is not obvious to many folks, including I don't recommend you do anything with the math except make a big 'ahhhhhhh' sound and let it cause a sensible sense of dread in you whenever you pull towards the ground. By the way, a minimum radius pull is at a bit above the stall speed so if you pull to just before the buffet you are pretty close regardless of airspeed. Hopefully someone isn't flying the bottom of a loop near stall speed. Isn't the minimum radius turn going to be accomplished at corner velocity and max-G pull? Yes, turn rate (or time in the pull) is also a factor and max turn rate and min turn radius are maximized if married with max available radial g at corner. You should actually throttle up if you're behind corner!!!! But you should never be in this situation going through a topside gate. The airspeed should be married to the known radial g profile for your airplane or a roll exit initiated IMMEDIATELY!! The trick with the gate apex is not to go through at a higher airspeed than the radial g profile you are using for the airplane will allow through the backside commit. If the airspeed is too high through the gate, roll should be used to exit instead of pull. In low altitude demonstration work, the time to do your math is on the ground. All you need to know in the air are your commit numbers. You have them at the top or you don't...period! If you are going through a top gate and ANY of the numbers are off and you don't execute a roll save, you are well on your way to becoming a statistic! I've attended more than a few funerals in the fifty years I've been associated with low altitude acro. It's a totally unforgiving environment! Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the at with what goes there and take out the Z's please! dhenriquesZatZearthZlinkZdotZnet |
speed. Isn't the minimum radius turn going to be accomplished at corner velocity and max-G pull? Yes, turn rate (or time in the pull) is also a factor and max turn rate and min turn radius are maximized if married with max available radial g at corner. You should actually throttle up if you're behind corner!!!! Question: how does one compute or determine cornering velocity for a specific aircraft? Must that be done through flight testing, or is there a mathmatical relationship to the stall speed/etc? Specifically, does anyone know the cornering V for a Decathlon 160-CS? Thanks! |
Ed wrote:
Hopefully someone isn't flying the bottom of a loop near stall speed. Isn't the minimum radius turn going to be accomplished at corner velocity and max-G pull? Yes, turn rate (or time in the pull) is also a factor and max turn rate and min turn radius are maximized if married with max available radial g at corner. You should actually throttle up if you're behind corner!!!! Question: how does one compute or determine cornering velocity for a specific aircraft? Must that be done through flight testing, or is there a mathmatical relationship to the stall speed/etc? Do a Google search for 14cfr23.335.pdf Specifically, does anyone know the cornering V for a Decathlon 160-CS? With the above, you can calculate it for max gross weight. For low speed aircraft I think it is just Va. Look in the aircraft manual, it should have a V-n diagram. |
Thanks for getting this discussion pointed toward the mathmatics, Andrew.
A Google search of "V-n diagram" pulls up some really good articles on recovery from a vertical dive that explain in easy to understand terms. |
Accelerated spin questions | John Harper | Aerobatics | 7 | August 15th 03 07:08 PM |
