On Jun 8, 9:17*pm, Michael Henry
wrote: Capt. Geoffrey Thorpe wrote: I assume you are most familiar with the use of a servo tab. Can you name at least two other ways that it is commonly done in light aircraft? The J-3 Cub has a moving stabilizer. Although you specifically said "light aircraft" it's interesting to note that many airliners also us a moving stabilizer. This and another method are mentioned in this article: http://flighttraining.aopa.org/learn.../articles/0209... Yikes - that's it. The answer is in that link. Since no other students responded... ...when I first started used/read about trim tab, I figured it was "more of the same", meaning that there was some complex mechanism in the aircraft where trim tab simply did more of whatever the elevator was doing, but some how figured out how to release pressure on the yoke. Well that's true, but a more correct interpretation is that the trim tab does not participate in elevating the aircraft really, but serves to aerodynamically set the angle of the elevator, at which point the elevator does its job. I learn this in MSFS by trying various movements and watching outside the aircraft how control surfaces responded. The trim tab was moving in opposite direction that I thought it would. I also saw that on C172, there is an asymmetric, with only one tab. All obvious to pilots, but interesting for students, for me at least. -Le Chaud Lapin- |
On Sun, 8 Jun 2008 22:24:07 -0700 (PDT), Le Chaud Lapin
wrote: On Jun 8, 9:17*pm, Michael Henry wrote: Capt. Geoffrey Thorpe wrote: I assume you are most familiar with the use of a servo tab. Can you name at least two other ways that it is commonly done in light aircraft? The J-3 Cub has a moving stabilizer. Although you specifically said "light aircraft" it's interesting to note that many airliners also us a moving stabilizer. This and another method are mentioned in this article: http://flighttraining.aopa.org/learn.../articles/0209... Yikes - that's it. The answer is in that link. Since no other students responded... ...when I first started used/read about trim tab, I figured it was "more of the same", meaning that there was some complex mechanism in the aircraft where trim tab simply did more of whatever the elevator was doing, but some how figured out how to release pressure on the yoke. Well that's true, but a more correct interpretation is that the trim tab does not participate in elevating the aircraft really, but serves to aerodynamically set the angle of the elevator, at which point the elevator does its job. I learn this in MSFS by trying various movements and watching outside the aircraft how control surfaces responded. The trim tab was moving in opposite direction that I thought it would. I also saw that on C172, there is an asymmetric, with only one tab. All obvious to pilots, but interesting for students, for me at least. -Le Chaud Lapin- if you ever read 'Stick and Rudder' by wolfgang langeweische you will find that he refers to flippers for the majority of the book. this is to prevent the mistake you make above where you thought the elevator elevated the aircraft. amazing, I never thought anyone actually made that mistake. Stealth Pilot |
Stealth Pilot wrote in
: On Sun, 8 Jun 2008 22:24:07 -0700 (PDT), Le Chaud Lapin wrote: On Jun 8, 9:17*pm, Michael Henry wrote: Capt. Geoffrey Thorpe wrote: I assume you are most familiar with the use of a servo tab. Can you name at least two other ways that it is commonly done in light aircraft? The J-3 Cub has a moving stabilizer. Although you specifically said "light aircraft" it's interesting to note that many airliners also us a moving stabilizer. This and another method are mentioned in this article: http://flighttraining.aopa.org/learn.../articles/0209 ... Yikes - that's it. The answer is in that link. Since no other students responded... ...when I first started used/read about trim tab, I figured it was "more of the same", meaning that there was some complex mechanism in the aircraft where trim tab simply did more of whatever the elevator was doing, but some how figured out how to release pressure on the yoke. Well that's true, but a more correct interpretation is that the trim tab does not participate in elevating the aircraft really, but serves to aerodynamically set the angle of the elevator, at which point the elevator does its job. I learn this in MSFS by trying various movements and watching outside the aircraft how control surfaces responded. The trim tab was moving in opposite direction that I thought it would. I also saw that on C172, there is an asymmetric, with only one tab. All obvious to pilots, but interesting for students, for me at least. -Le Chaud Lapin- if you ever read 'Stick and Rudder' by wolfgang langeweische you will find that he refers to flippers for the majority of the book. this is to prevent the mistake you make above where you thought the elevator elevated the aircraft. amazing, I never thought anyone actually made that mistake. First hour students do sometimes. I've also seen one guy actually tilt his head back when IO told him to raise the nose on a first flight. Flippers is an archaic term that predates Langeweisch by a couple of decades! It was pretty much dropped mainstream during WW2, I suppose because it didn't sound techie enough. Bertie |
F-100 detail | Pjmac35 | Aviation Photos | 0 | July 26th 07 10:29 AM |
Finding "Neutral" Position on Piper Elevator/Trim Tab | [email protected] | Owning | 10 | December 7th 06 01:43 PM |
Detail pops in too late in FS2004 | CatharticF1 | Simulators | 0 | August 27th 03 03:25 AM |
