Mechanics of Elevator Trim. In Detail.
Old June 9th 08, 09:26 AM posted to rec.aviation.student,rec.aviation.piloting
Andy Hawkins
Default Mechanics of Elevator Trim. In Detail.
Hi.
Le Chaud wrote:
Again, this isn't rocket science, but I suspect that other students,
like I, had misconception of how it might work, even though it is
written in the book how it should work.
A student who's actually sat in an aircraft and carried out the pre-flight
should have little doubt as to what moving the trim wheel actually does.
In the Warrior I fly, we're taught to put in full back elevator, then wind
the trim through the limits of its travel, watching the trim tab to ensure
it moves as it should.
Similarly, in the 'Aircraft General and Principles of Flight' exam we have
to sit in the UK, the operation of trim is expected to be understood.
Andy
Old June 9th 08, 05:38 PM posted to rec.aviation.student,rec.aviation.piloting
Le Chaud Lapin
On Jun 9, 3:26*am, Andy Hawkins wrote:
Hi.
That's interesting. How do you see the trim tab fromm the cockpit?
I've been in Tomahawk and DA-20. I did preflight on DA-20, but didn't
test trim.
-Le Chaud Lapin-
Old June 10th 08, 09:28 AM posted to rec.aviation.student,rec.aviation.piloting
Andy Hawkins
Hi,
Umm...you move your head?
On a PA28, the trim tab runs most of the length of the moving tailplane.
Pull the yoke back with your left hand, look over your left shoulder and
move the trim wheel through the extent of its travel with you right hand and
watch what happens.
test trim.
Then you didn't do the pre-flight correctly.
Andy
F-100 detail Pjmac35 Aviation Photos 0 July 26th 07 10:29 AM
Finding "Neutral" Position on Piper Elevator/Trim Tab [email protected] Owning 10 December 7th 06 01:43 PM
Detail pops in too late in FS2004 CatharticF1 Simulators 0 August 27th 03 03:25 AM
