gatts post on power off dive speed ????
Old June 9th 08, 02:15 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
Default gatts post on power off dive speed ????
gatts post on the dive spped of a trimmed power off aircraft seems to
have vanished off my free agent.
I experimented in the Tailwind on sunday to see what occurs on power
off.
now mind you the Tailwind isnt the usual FAR23 aircraft. It has no
dihedral, neutral stability and not much inertia. it is however a dead
honest airframe.
I tried the suggestion regarding spiral instability while tootling
over to Cape Naturaliste.
If I set up the tailwind in balanced straight and level flight and
take the hands and feet off everything the aircraft dives off in a
spiral, which you'd expect from a neutrally stable aircraft
encountering a gust.
I tried setting everything up in balance then held my feet still on
the rudders, hands off everything else. the aircraft flew with slight
deviations in almost straight and level flight for 10 minutes or so.
It showed no tendency toward instability which I must say surprised
me.
I then ran out of country and turned around back toward Busselton.
I set the aircraft up again then did the throttle back to idle thing.
as the power came off the tailwind put its nose down and entered an
increasingly steepening turn to the right. I called it quits at that
stage rather than have to walk home some 200 km.
The turn is to be expected because of the rudder offset.
Interesting. I didnt realise that the aircraft would be that stable if
you held the rudder still.
what michael (i think it was he) claimed regarding power off
instability seems correct if the aircraft has no inherent stability.
I think he overstates the tendency to instability for something with
dihedral like the cessna 150 or piper 140. I'd would be interesting to
try it in one of those aircraft.
Stealth Pilot
Old June 9th 08, 03:16 PM posted to rec.aviation.piloting
Michael[_1_]
On Jun 9, 9:15*am, Stealth Pilot
me.
The problem is that while you may think you held your feet still on
the rudders, it is almost impossible to do. You will instinctively
pick up a dropping wing with rudder. Prove it to yourself - hold the
rudders still the same way you did before - but with your eyes
closed. The airplane will dive off just the same as if your feet were
off the rudders. Just don't do it for too long.
Michael
Old June 9th 08, 03:52 PM posted to rec.aviation.piloting
gatt[_5_]
The name of the thread is "CFI Oral intel."
Fascinating. Thanks for the report.
-c
Old June 10th 08, 02:04 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Mon, 9 Jun 2008 07:16:08 -0700 (PDT), Michael
me.
Michael
no movement. the inner soles were pressed together and locked rock
solid.
have you ever flown a Tailwind?
Stealth pilot
Old June 10th 08, 09:47 PM posted to rec.aviation.piloting
More_Flaps
On Jun 11, 1:04*am, Stealth Pilot
me.
the rudders, it is almost impossible to do. *You will instinctively
pick up a dropping wing with rudder. *Prove it to yourself - hold the
closed. *The airplane will dive off just the same as if your feet were
off the rudders. *Just don't do it for too long.
Michael
solid.
A bad idea when landing unless the runway is long and/or you are not
in a tail dragger. If you mean the plane designed by Wittman, which
model number (W0-)
Cheers
Old June 11th 08, 10:37 AM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Tue, 10 Jun 2008 13:47:26 -0700 (PDT), More_Flaps
me.
Michael
solid.
model number (W0-)
Cheers
W8 with the "new improved wing" (look on the plans for an explanation)
Looking for a PIREP - GATTS mbremer216 Instrument Flight Rules 0 June 3rd 06 01:38 AM
PIREP Request - GATTS IFR Training mbremer216 Owning 0 June 2nd 06 02:52 AM
IO 360 Power down (danger, long, rambling post!) Jim Harper Home Built 24 July 11th 04 12:04 AM
Why do constant speed power setting charts limit RPM? Ben Jackson Piloting 6 April 16th 04 03:41 AM
Jet fighter top speed at military power David L. Pulver Military Aviation 18 December 1st 03 07:13 PM
