On Jun 10, 1:09 pm, Tauno Voipio wrote:
Tina wrote: One point about the lift fairy sitting on the tail I'd like to understand is this -- actually a serious question. As I understand it, nearly aways the tail is exerting a downward force, since the center of lift is aft of the center of gravity on general aviation airplanes (that is true, isn't it -- that the cg is forward of the center of lift?). If so the tail really is imposing an increased load on the airplane, adding to its effective weight. The question I have is, how many pounds of weight is imposed aerodynamically for an airplane that might be loaded with its CG at the forward limit? I don't know where the center of lift is on ga airplanes -- a third of the way aft of the leading edge of the wing is an ok approximation, but a few inches error on an airplane weighing what ours does at max could make a huge change in the required force to overcome the nose heavy moment. A rule of thumb is that the force on the horizontal tail is 5 to 10 per cent of the wing lift. This translates to a loss of 10 to 20 per cent of the raw gross lift availbale from the horizontal airfoils. I'm obviously thinking about increased efficiency -- extra weight added because of either fat people, full fuel, or aerodynamically imposed, all cost horsepower (OK, watts for you purists) to move around. This is the reason why modern military aircraft are designed aerodynamically unstable, and the electronic gnomes of the flight control system have to work all they can do. The loss of gross lift is the proce to pay for simple and safe longitudinal stability. -- Tauno Voipio tauno voipio (at) iki fi Thanks for the rule of thumb, Tauno. I have watched how busy the flippers are on fighters when they are in the flare -- no human pilot is working that hard for control. I knew the fighters are designed to be aerodynamically unstable. So the aerodynamic longitudinal stability the tail provides might cost us 5 to 10%, The obvious question is, do canards buy back that fraction? They would be offering positive lift, and if they stall first would provide the same sort of longitudinal stability, wouldn't they? be |
Tina wrote:
On Jun 10, 1:09 pm, Tauno Voipio wrote: Tina wrote: One point about the lift fairy sitting on the tail I'd like to understand is this -- actually a serious question. As I understand it, nearly aways the tail is exerting a downward force, since the center of lift is aft of the center of gravity on general aviation airplanes (that is true, isn't it -- that the cg is forward of the center of lift?). If so the tail really is imposing an increased load on the airplane, adding to its effective weight. The question I have is, how many pounds of weight is imposed aerodynamically for an airplane that might be loaded with its CG at the forward limit? I don't know where the center of lift is on ga airplanes -- a third of the way aft of the leading edge of the wing is an ok approximation, but a few inches error on an airplane weighing what ours does at max could make a huge change in the required force to overcome the nose heavy moment. A rule of thumb is that the force on the horizontal tail is 5 to 10 per cent of the wing lift. This translates to a loss of 10 to 20 per cent of the raw gross lift availbale from the horizontal airfoils. I'm obviously thinking about increased efficiency -- extra weight added because of either fat people, full fuel, or aerodynamically imposed, all cost horsepower (OK, watts for you purists) to move around. This is the reason why modern military aircraft are designed aerodynamically unstable, and the electronic gnomes of the flight control system have to work all they can do. The loss of gross lift is the proce to pay for simple and safe longitudinal stability. -- Tauno Voipio tauno voipio (at) iki fi Thanks for the rule of thumb, Tauno. I have watched how busy the flippers are on fighters when they are in the flare -- no human pilot is working that hard for control. I knew the fighters are designed to be aerodynamically unstable. So the aerodynamic longitudinal stability the tail provides might cost us 5 to 10%, The obvious question is, do canards buy back that fraction? They would be offering positive lift, and if they stall first would provide the same sort of longitudinal stability, wouldn't they? Yes - they do bring back some, and this is the reasoning behind e.g. Rutan's Voyager, The price is that the canard (front wing) has to stall first unless you want to fall to ground in reverse when the thing stalls. The rumours are that the canards are a PITA to land nicely. -- -Tauno |
Thanks again. My intelligent but ignorant guess is designing canards
so that they stall first should not take a genius, but there may be traps I don't see. The world is safe, though, since I don't design airplane. The landing issue you raised is pretty neat, since most of us -- especially Mooney drivers -- are careful about airspeed on final and in the flare, and like to land with the wings almost stalled. But in the case of a canard if that stalls first I think the airplane would very enthusiastically want to pitch forward hard enough to bend the nosewheel! At least with the stabilizer still flying the nose might be able to be put down more gently. You've provided some nice insights, thanks. On Jun 10, 2:14 pm, Tauno Voipio wrote: Tina wrote: On Jun 10, 1:09 pm, Tauno Voipio wrote: Tina wrote: One point about the lift fairy sitting on the tail I'd like to understand is this -- actually a serious question. As I understand it, nearly aways the tail is exerting a downward force, since theI center of lift is aft of the center of gravity on general aviation airplanes (that is true, isn't it -- that the cg is forward of the center of lift?). If so the tail really is imposing an increased load on the airplane, adding to its effective weight. The question I have is, how many pounds of weight is imposed aerodynamically for an airplane that might be loaded with its CG at the forward limit? I don't know where the center of lift is on ga airplanes -- a third of the way aft of the leading edge of the wing is an ok approximation, but a few inches error on an airplane weighing what ours does at max could make a huge change in the required force to overcome the nose heavy moment. A rule of thumb is that the force on the horizontal tail is 5 to 10 per cent of the wing lift. This translates to a loss of 10 to 20 per cent of the raw gross lift availbale from the horizontal airfoils. I'm obviously thinking about increased efficiency -- extra weight added because of either fat people, full fuel, or aerodynamically imposed, all cost horsepower (OK, watts for you purists) to move around. This is the reason why modern military aircraft are designed aerodynamically unstable, and the electronic gnomes of the flight control system have to work all they can do. The loss of gross lift is the proce to pay for simple and safe longitudinal stability. -- Tauno Voipio tauno voipio (at) iki fi Thanks for the rule of thumb, Tauno. I have watched how busy the flippers are on fighters when they are in the flare -- no human pilot is working that hard for control. I knew the fighters are designed to be aerodynamically unstable. So the aerodynamic longitudinal stability the tail provides might cost us 5 to 10%, The obvious question is, do canards buy back that fraction? They would be offering positive lift, and if they stall first would provide the same sort of longitudinal stability, wouldn't they? Yes - they do bring back some, and this is the reasoning behind e.g. Rutan's Voyager, The price is that the canard (front wing) has to stall first unless you want to fall to ground in reverse when the thing stalls. The rumours are that the canards are a PITA to land nicely. -- -Tauno |
On Tue, 10 Jun 2008 11:24:39 -0700 (PDT), Tina
wrote: Thanks again. My intelligent but ignorant guess is designing canards so that they stall first should not take a genius, but there may be traps I don't see. The world is safe, though, since I don't design airplane. The landing issue you raised is pretty neat, since most of us -- especially Mooney drivers -- are careful about airspeed on final and in the flare, and like to land with the wings almost stalled. But in the case of a canard if that stalls first I think the airplane would very enthusiastically want to pitch forward hard enough to bend the nosewheel! I haven't flown a canard, but my son has done a lot of flying in one that was under development. You are right... you don't want to stall the canard on landing. You fly it all the way to the ground. Three problems with the canard, as my son saw it, was lack of forward visibility on landing, drag from the canard in cruise flight (a fixed canard has to have its AOA greater than the wing and enough surface to generate lift) and ice shedding off the wings through the propelllor. Piaggio solved the drag problem, partially, with a three surface aircraft and a relatively small canard. I believe Beechcraft attempted to solve it with a variable sweep canard, but I could be wrong. At least with the stabilizer still flying the nose might be able to be put down more gently. You've provided some nice insights, thanks. My son says canard landings are like the "Little girl with the curl in the middle of her forehead"... when they are good, they are very very good, but when they are bad they are horrid. :-) Ron Kelley |
On Jun 11, 12:45 am, Ron wrote:
On Tue, 10 Jun 2008 11:24:39 -0700 (PDT), Tina wrote: Thanks again. My intelligent but ignorant guess is designing canards so that they stall first should not take a genius, but there may be traps I don't see. The world is safe, though, since I don't design airplane. The landing issue you raised is pretty neat, since most of us -- especially Mooney drivers -- are careful about airspeed on final and in the flare, and like to land with the wings almost stalled. But in the case of a canard if that stalls first I think the airplane would very enthusiastically want to pitch forward hard enough to bend the nosewheel! I haven't flown a canard, but my son has done a lot of flying in one that was under development. You are right... you don't want to stall the canard on landing. You fly it all the way to the ground. Three problems with the canard, as my son saw it, was lack of forward visibility on landing, drag from the canard in cruise flight (a fixed canard has to have its AOA greater than the wing and enough surface to generate lift) and ice shedding off the wings through the propelllor. Piaggio solved the drag problem, partially, with a three surface aircraft and a relatively small canard. I believe Beechcraft attempted to solve it with a variable sweep canard, but I could be wrong. At least with the stabilizer still flying the nose might be able to be put down more gently. You've provided some nice insights, thanks. My son says canard landings are like the "Little girl with the curl in the middle of her forehead"... when they are good, they are very very good, but when they are bad they are horrid. :-) Ron Kelley Yes, it seems to me (again, ignorant of the reality) that the airplane has to be flown onto the runway, rather than stalled onto it. When we land the airplane is done flying, period, but flying it on means it's fast enough to take off again. The higher angle of attack causing drag in cruise trade-off is a bit of a surprise since what is gained is aerodynamic positive lift from those little wings in front of the airplane, instead of the negative lift from those wings most of us have on the back end that are increasing the aerodynamic load. Fun discussion, thanks. |
On Wed, 11 Jun 2008 03:28:05 -0700 (PDT), Tina
wrote: On Jun 11, 12:45 am, Ron wrote: On Tue, 10 Jun 2008 11:24:39 -0700 (PDT), Tina wrote: Thanks again. My intelligent but ignorant guess is designing canards so that they stall first should not take a genius, but there may be traps I don't see. The world is safe, though, since I don't design airplane. The landing issue you raised is pretty neat, since most of us -- especially Mooney drivers -- are careful about airspeed on final and in the flare, and like to land with the wings almost stalled. But in the case of a canard if that stalls first I think the airplane would very enthusiastically want to pitch forward hard enough to bend the nosewheel! I haven't flown a canard, but my son has done a lot of flying in one that was under development. You are right... you don't want to stall the canard on landing. You fly it all the way to the ground. Three problems with the canard, as my son saw it, was lack of forward visibility on landing, drag from the canard in cruise flight (a fixed canard has to have its AOA greater than the wing and enough surface to generate lift) and ice shedding off the wings through the propelllor. Piaggio solved the drag problem, partially, with a three surface aircraft and a relatively small canard. I believe Beechcraft attempted to solve it with a variable sweep canard, but I could be wrong. At least with the stabilizer still flying the nose might be able to be put down more gently. You've provided some nice insights, thanks. My son says canard landings are like the "Little girl with the curl in the middle of her forehead"... when they are good, they are very very good, but when they are bad they are horrid. :-) Ron Kelley Yes, it seems to me (again, ignorant of the reality) that the airplane has to be flown onto the runway, rather than stalled onto it. When we land the airplane is done flying, period, but flying it on means it's fast enough to take off again. The higher angle of attack causing drag in cruise trade-off is a bit of a surprise since what is gained is aerodynamic positive lift from those little wings in front of the airplane, instead of the negative lift from those wings most of us have on the back end that are increasing the aerodynamic load. True, but remember all lift, whether up or down is drag. The balancing "down lift" from the elevator is much less than the load bearing "up lift" of the canard. Fun discussion, thanks. Yes, the time my son spent with canard aircraft brought out all sorts of interesting information about canards and the history of trying to scale up Rutan's original concept Beech Starship. The smaller true canards like the Long-eze are pretty good aircraft. However there is a reason why we don't see large (six plus passenger) true canards. It's the relationship between CG, fuel load, payload and range. Apparently in the scale up process there is a point where it is no longer practical. Ron Kelley |
![]() Yes, the time my son spent with canard aircraft brought out all sorts of interesting information about canards and the history of trying to scale up Rutan's original concept Beech Starship. The smaller true canards like the Long-eze are pretty good aircraft. However there is a reason why we don't see large (six plus passenger) true canards. It's the relationship between CG, fuel load, payload and range. Apparently in the scale up process there is a point where it is no longer practical. Ron Kelley Would it not also be true that passive stability is not as important in larger modern airplanes? I would guess (again, I admit being ignorant of the realities) that adding a 10% aerodynamically induced increased load on bigger aircraft would be avoided for efficiency reasons? It might be better to have enough fly by wire and computer induced stability instead. I don't know enough about this stuff to even find the back of an envelope, let alone do a calculation there. |
Thanks again. My intelligent but ignorant guess ???? is designing canards so that they stall first should not take a genius, but there may be traps I don't see. The world is safe, though, since I don't design airplane. The landing issue you raised is pretty neat, since most of us -- especially Mooney drivers -- are careful about airspeed on final and in the flare, and like to land with the wings almost stalled. But in the case of a canard if that stalls first I think the airplane would very enthusiastically want to pitch forward hard enough to bend the nosewheel! Basically you want to set up your speeds so the main gear touches before the canard stalls in a fully flying condition about 85/90 kts. This gives a wide margin before the canard stalls and reduces the sensitivity to Xwinds. Easier than a full-stall landing; all control surfaces are fully functional plne is highly maneuverable all the way to the ground. At least with the stabilizer still flying the nose might be able to be put down more gently. You've provided some nice insights, thanks. Thx. lol |
On Tue, 10 Jun 2008 18:14:41 GMT, Tauno Voipio wrote:
Tina wrote: On Jun 10, 1:09 pm, Tauno Voipio wrote: Tina wrote: One point about the lift fairy sitting on the tail I'd like to understand is this -- actually a serious question. As I understand it, nearly aways the tail is exerting a downward force, since the center of lift is aft of the center of gravity on general aviation airplanes (that is true, isn't it -- that the cg is forward of the center of lift?). If so the tail really is imposing an increased load on the airplane, adding to its effective weight. The question I have is, how many pounds of weight is imposed aerodynamically for an airplane that might be loaded with its CG at the forward limit? I don't know where the center of lift is on ga airplanes -- a third of the way aft of the leading edge of the wing is an ok approximation, but a few inches error on an airplane weighing what ours does at max could make a huge change in the required force to overcome the nose heavy moment. A rule of thumb is that the force on the horizontal tail is 5 to 10 per cent of the wing lift. This translates to a loss of 10 to 20 per cent of the raw gross lift availbale from the horizontal airfoils. I'm obviously thinking about increased efficiency -- extra weight added because of either fat people, full fuel, or aerodynamically imposed, all cost horsepower (OK, watts for you purists) to move around. This is the reason why modern military aircraft are designed aerodynamically unstable, and the electronic gnomes of the flight control system have to work all they can do. The loss of gross lift is the proce to pay for simple and safe longitudinal stability. -- Tauno Voipio tauno voipio (at) iki fi Thanks for the rule of thumb, Tauno. I have watched how busy the flippers are on fighters when they are in the flare -- no human pilot is working that hard for control. I knew the fighters are designed to be aerodynamically unstable. So the aerodynamic longitudinal stability the tail provides might cost us 5 to 10%, The obvious question is, do canards buy back that fraction? They would be offering positive lift, and if they stall first would provide the same sort of longitudinal stability, wouldn't they? Yes - they do bring back some, and this is the reasoning behind e.g. Rutan's Voyager, The price is that the canard (front wing) has to stall first unless you want to fall to ground in reverse when the thing stalls. The rumours are that the canards are a PITA to land nicely. Apparently only to those who don't know how to fly one. |
F-100 detail | Pjmac35 | Aviation Photos | 0 | July 26th 07 10:29 AM |
Finding "Neutral" Position on Piper Elevator/Trim Tab | [email protected] | Owning | 10 | December 7th 06 01:43 PM |
Detail pops in too late in FS2004 | CatharticF1 | Simulators | 0 | August 27th 03 03:25 AM |
