On Tue, 10 Jun 2008 11:24:39 -0700 (PDT), Tina
wrote: Thanks again. My intelligent but ignorant guess is designing canards so that they stall first should not take a genius, but there may be traps I don't see. The world is safe, though, since I don't design airplane. The landing issue you raised is pretty neat, since most of us -- especially Mooney drivers -- are careful about airspeed on final and in the flare, and like to land with the wings almost stalled. But in the case of a canard if that stalls first I think the airplane would very enthusiastically want to pitch forward hard enough to bend the nosewheel! I haven't flown a canard, but my son has done a lot of flying in one that was under development. You are right... you don't want to stall the canard on landing. You fly it all the way to the ground. Three problems with the canard, as my son saw it, was lack of forward visibility on landing, drag from the canard in cruise flight (a fixed canard has to have its AOA greater than the wing and enough surface to generate lift) and ice shedding off the wings through the propelllor. Piaggio solved the drag problem, partially, with a three surface aircraft and a relatively small canard. I believe Beechcraft attempted to solve it with a variable sweep canard, but I could be wrong. At least with the stabilizer still flying the nose might be able to be put down more gently. You've provided some nice insights, thanks. My son says canard landings are like the "Little girl with the curl in the middle of her forehead"... when they are good, they are very very good, but when they are bad they are horrid. :-) Ron Kelley |
On Jun 11, 12:45 am, Ron wrote:
On Tue, 10 Jun 2008 11:24:39 -0700 (PDT), Tina wrote: Thanks again. My intelligent but ignorant guess is designing canards so that they stall first should not take a genius, but there may be traps I don't see. The world is safe, though, since I don't design airplane. The landing issue you raised is pretty neat, since most of us -- especially Mooney drivers -- are careful about airspeed on final and in the flare, and like to land with the wings almost stalled. But in the case of a canard if that stalls first I think the airplane would very enthusiastically want to pitch forward hard enough to bend the nosewheel! I haven't flown a canard, but my son has done a lot of flying in one that was under development. You are right... you don't want to stall the canard on landing. You fly it all the way to the ground. Three problems with the canard, as my son saw it, was lack of forward visibility on landing, drag from the canard in cruise flight (a fixed canard has to have its AOA greater than the wing and enough surface to generate lift) and ice shedding off the wings through the propelllor. Piaggio solved the drag problem, partially, with a three surface aircraft and a relatively small canard. I believe Beechcraft attempted to solve it with a variable sweep canard, but I could be wrong. At least with the stabilizer still flying the nose might be able to be put down more gently. You've provided some nice insights, thanks. My son says canard landings are like the "Little girl with the curl in the middle of her forehead"... when they are good, they are very very good, but when they are bad they are horrid. :-) Ron Kelley Yes, it seems to me (again, ignorant of the reality) that the airplane has to be flown onto the runway, rather than stalled onto it. When we land the airplane is done flying, period, but flying it on means it's fast enough to take off again. The higher angle of attack causing drag in cruise trade-off is a bit of a surprise since what is gained is aerodynamic positive lift from those little wings in front of the airplane, instead of the negative lift from those wings most of us have on the back end that are increasing the aerodynamic load. Fun discussion, thanks. |
On Wed, 11 Jun 2008 03:28:05 -0700 (PDT), Tina
wrote: On Jun 11, 12:45 am, Ron wrote: On Tue, 10 Jun 2008 11:24:39 -0700 (PDT), Tina wrote: Thanks again. My intelligent but ignorant guess is designing canards so that they stall first should not take a genius, but there may be traps I don't see. The world is safe, though, since I don't design airplane. The landing issue you raised is pretty neat, since most of us -- especially Mooney drivers -- are careful about airspeed on final and in the flare, and like to land with the wings almost stalled. But in the case of a canard if that stalls first I think the airplane would very enthusiastically want to pitch forward hard enough to bend the nosewheel! I haven't flown a canard, but my son has done a lot of flying in one that was under development. You are right... you don't want to stall the canard on landing. You fly it all the way to the ground. Three problems with the canard, as my son saw it, was lack of forward visibility on landing, drag from the canard in cruise flight (a fixed canard has to have its AOA greater than the wing and enough surface to generate lift) and ice shedding off the wings through the propelllor. Piaggio solved the drag problem, partially, with a three surface aircraft and a relatively small canard. I believe Beechcraft attempted to solve it with a variable sweep canard, but I could be wrong. At least with the stabilizer still flying the nose might be able to be put down more gently. You've provided some nice insights, thanks. My son says canard landings are like the "Little girl with the curl in the middle of her forehead"... when they are good, they are very very good, but when they are bad they are horrid. :-) Ron Kelley Yes, it seems to me (again, ignorant of the reality) that the airplane has to be flown onto the runway, rather than stalled onto it. When we land the airplane is done flying, period, but flying it on means it's fast enough to take off again. The higher angle of attack causing drag in cruise trade-off is a bit of a surprise since what is gained is aerodynamic positive lift from those little wings in front of the airplane, instead of the negative lift from those wings most of us have on the back end that are increasing the aerodynamic load. True, but remember all lift, whether up or down is drag. The balancing "down lift" from the elevator is much less than the load bearing "up lift" of the canard. Fun discussion, thanks. Yes, the time my son spent with canard aircraft brought out all sorts of interesting information about canards and the history of trying to scale up Rutan's original concept Beech Starship. The smaller true canards like the Long-eze are pretty good aircraft. However there is a reason why we don't see large (six plus passenger) true canards. It's the relationship between CG, fuel load, payload and range. Apparently in the scale up process there is a point where it is no longer practical. Ron Kelley |
![]() Yes, the time my son spent with canard aircraft brought out all sorts of interesting information about canards and the history of trying to scale up Rutan's original concept Beech Starship. The smaller true canards like the Long-eze are pretty good aircraft. However there is a reason why we don't see large (six plus passenger) true canards. It's the relationship between CG, fuel load, payload and range. Apparently in the scale up process there is a point where it is no longer practical. Ron Kelley Would it not also be true that passive stability is not as important in larger modern airplanes? I would guess (again, I admit being ignorant of the realities) that adding a 10% aerodynamically induced increased load on bigger aircraft would be avoided for efficiency reasons? It might be better to have enough fly by wire and computer induced stability instead. I don't know enough about this stuff to even find the back of an envelope, let alone do a calculation there. |
On Jun 12, 5:08 am, Tina wrote:
Yes, the time my son spent with canard aircraft brought out all sorts of interesting information about canards and the history of trying to scale up Rutan's original concept Beech Starship. The smaller true canards like the Long-eze are pretty good aircraft. However there is a reason why we don't see large (six plus passenger) true canards. It's the relationship between CG, fuel load, payload and range. Apparently in the scale up process there is a point where it is no longer practical. Ron Kelley Hmm, how the XB-70 or this, http://en.wikipedia.org/wiki/Boeing_Sonic_Cruiser I think the aircraft business is extremely conservative. KISS applies, also canards are difficult for the average pilot to understand, (Hey man, you got that thar tail on the wrong end :-). Would it not also be true that passive stability is not as important in larger modern airplanes? I would guess (again, I admit being ignorant of the realities) that adding a 10% aerodynamically induced increased load on bigger aircraft would be avoided for efficiency reasons? It might be better to have enough fly by wire and computer induced stability instead. I don't know enough about this stuff to even find the back of an envelope, let alone do a calculation there. Canards are NOT simple, I've designed quite a few, and studied others, especially Rutan's. I find they can be optimised for a given air speed and are much better than the conventional lay-out. The main problem is designing the stall. Ken |
On Thu, 12 Jun 2008 09:43:07 -0700 (PDT), "Ken S. Tucker"
wrote: On Jun 12, 5:08 am, Tina wrote: Yes, the time my son spent with canard aircraft brought out all sorts of interesting information about canards and the history of trying to scale up Rutan's original concept Beech Starship. The smaller true canards like the Long-eze are pretty good aircraft. However there is a reason why we don't see large (six plus passenger) true canards. It's the relationship between CG, fuel load, payload and range. Apparently in the scale up process there is a point where it is no longer practical. Ron Kelley Hmm, how the XB-70 or this, http://en.wikipedia.org/wiki/Boeing_Sonic_Cruiser True, the XB-70 was a qualified success of a large canard type aircraft. Most of it's problems were due to system failures and trying to fly at Mach 3.0. The only control issues I know of were related to overly sensitive pitch response to control inputs. Ref: http://www.labiker.org/xb70.html As far as I know the Boeing Sonic Cruiser hasn't gone beyond the artists concept stage. I guess it's no accident that all the current crop of passenger jets look alike. That could be partially due to the reluctance of any large airframe manufacturer to take a gamble on trying to certify any new "radical" design. Who knows. Personally, I am intrigued by the three surface aircraft like the Piaggio. They seem to have done pretty good with their design. One wonders if given enough time, money and talent, there is some room for improvement there. I think the aircraft business is extremely conservative. KISS applies, also canards are difficult for the average pilot to understand, (Hey man, you got that thar tail on the wrong end :-). Would it not also be true that passive stability is not as important in larger modern airplanes? I would guess (again, I admit being ignorant of the realities) that adding a 10% aerodynamically induced increased load on bigger aircraft would be avoided for efficiency reasons? It might be better to have enough fly by wire and computer induced stability instead. I don't know enough about this stuff to even find the back of an envelope, let alone do a calculation there. Canards are NOT simple, I've designed quite a few, and studied others, especially Rutan's. I find they can be optimised for a given air speed and are much better than the conventional lay-out. The main problem is designing the stall. Ken Anyone who can design a successful canard aircraft has my respect. I didn't learn a whole lot about the design aspects from my son (he was in flight test, not design), but what we did learn was everything interacted with everything else. The job was interesting, but didn't last long. Ron Kelley |
On Jun 12, 9:53 pm, Ron wrote:
On Thu, 12 Jun 2008 09:43:07 -0700 (PDT), "Ken S. Tucker" wrote: On Jun 12, 5:08 am, Tina wrote: Yes, the time my son spent with canard aircraft brought out all sorts of interesting information about canards and the history of trying to scale up Rutan's original concept Beech Starship. The smaller true canards like the Long-eze are pretty good aircraft. However there is a reason why we don't see large (six plus passenger) true canards. It's the relationship between CG, fuel load, payload and range. Apparently in the scale up process there is a point where it is no longer practical. Ron Kelley Hmm, how the XB-70 or this, http://en.wikipedia.org/wiki/Boeing_Sonic_Cruiser True, the XB-70 was a qualified success of a large canard type aircraft. Most of it's problems were due to system failures and trying to fly at Mach 3.0. The only control issues I know of were related to overly sensitive pitch response to control inputs. Ref:http://www.labiker.org/xb70.html Thanks for that link. As far as I know the Boeing Sonic Cruiser hasn't gone beyond the artists concept stage. I guess it's no accident that all the current crop of passenger jets look alike. That could be partially due to the reluctance of any large airframe manufacturer to take a gamble on trying to certify any new "radical" design. Who knows. Personally, I am intrigued by the three surface aircraft like the Piaggio. They seem to have done pretty good with their design. One wonders if given enough time, money and talent, there is some room for improvement there. Yes! That Piaggio is one real impressive piece of aerodynamics, and it sounds very pilot user-friendly. Very remarkable how they utilized the canard. I think the aircraft business is extremely conservative. KISS applies, also canards are difficult for the average pilot to understand, (Hey man, you got that thar tail on the wrong end :-). Would it not also be true that passive stability is not as important in larger modern airplanes? I would guess (again, I admit being ignorant of the realities) that adding a 10% aerodynamically induced increased load on bigger aircraft would be avoided for efficiency reasons? It might be better to have enough fly by wire and computer induced stability instead. I don't know enough about this stuff to even find the back of an envelope, let alone do a calculation there. Canards are NOT simple, I've designed quite a few, and studied others, especially Rutan's. I find they can be optimised for a given air speed and are much better than the conventional lay-out. The main problem is designing the stall. Ken Anyone who can design a successful canard aircraft has my respect. I didn't learn a whole lot about the design aspects from my son (he was in flight test, not design), but what we did learn was everything interacted with everything else. The job was interesting, but didn't last long. Your son sounds like a cool dude. The major PITA is designing aircraft to be efficient at cruise, but safe all the way to stalling, and recoverable. The difficulty is the movement of the Center of Lift forward on the main wing as stall begins. Ron Kelley Regards Ken |
F-100 detail | Pjmac35 | Aviation Photos | 0 | July 26th 07 10:29 AM |
Finding "Neutral" Position on Piper Elevator/Trim Tab | [email protected] | Owning | 10 | December 7th 06 01:43 PM |
Detail pops in too late in FS2004 | CatharticF1 | Simulators | 0 | August 27th 03 03:25 AM |
